 DIY TRE for M800
Gad_ST
6 posters
Gad_ST
Gad_ST
DIY TRE for M800  Empty
PostSubject: DIY TRE for M800    DIY TRE for M800  Icon_minitimeSun Dec 30, 2012 6:06 pm
Hi
Surfing this forum I found this "Timing Retard Eliminator (TRE)" mod, since It was first time I've heard about this I've done some google-ing and I want to to this. Search on this forum did not give me any results.
So I have one question just for conformation. I need to trick ECU to think that is in 4th gear all the time except in neutral? Is this correct for M800 2005?
I will base my TRE on this one. (just find out that i cant post links for 7 days :() i will be posting link in 6 days :)
PostSubject: Re: DIY TRE for M800    DIY TRE for M800  Icon_minitimeSun Dec 30, 2012 6:35 pm
Gad I have just been reading up on making a TRE and it seems to be easy for people that know what they are doing. The issue as I see it is knowing what the OHM value of the suzuki 800 is in the 4th gear position.
As you can see different suzuki's have different OHM values for 4th gear on different bikes
15k ohm resistor for 1000/ TLR.
6.8k ohm resistor for 600/750 & Busa's.
2.7k ohm resister for 1000 vstorm
Here is a link to a Vstorm page that shows how it is done LINK
Gad_ST
Gad_ST
PostSubject: Re: DIY TRE for M800    DIY TRE for M800  Icon_minitimeSun Dec 30, 2012 8:52 pm
just came from garage. m800 in 4th gear is 2.7k. But as I see all schematics are missing blue wire witch is 12V. will post later when i see what I think is missing.
PostSubject: Re: DIY TRE for M800    DIY TRE for M800  Icon_minitimeSun Dec 30, 2012 9:23 pm
This is very interesting, I would never have thought of making these but it would seem they are very easy to put together when you know what you need.
Nice thread Gad. DIY TRE for M800  3498837457
Gad_ST
Gad_ST
PostSubject: Re: DIY TRE for M800    DIY TRE for M800  Icon_minitimeMon Dec 31, 2012 1:41 am
This is original wiring
DIY TRE for M800  Originalwk
and this is with TRE
DIY TRE for M800  Treva
I allready made circuit just need some wires an will test it tomorow if I could stay sober :)
PostSubject: Re: DIY TRE for M800    DIY TRE for M800  Icon_minitimeMon Dec 31, 2012 8:47 am
You are a very clever man Gad, this should be very interesting DIY TRE for M800  3322349030
Good luck with staying sober mate lol!
PostSubject: Re: DIY TRE for M800    DIY TRE for M800  Icon_minitimeMon Dec 31, 2012 3:37 pm
Well thought out Gad.
Gad_ST
Gad_ST
PostSubject: Re: DIY TRE for M800    DIY TRE for M800  Icon_minitimeWed Jan 02, 2013 11:21 am
After sobering up :) I decided to put 4 pole DIP switch, so if something go wrong with transistor or resistor I could easy bypass circuit and connect pink wire directly like It was originaly connected
Gad_ST
Gad_ST
PostSubject: Re: DIY TRE for M800    DIY TRE for M800  Icon_minitimeWed Jan 02, 2013 12:22 pm
DIY TRE for M800  Tre2s
that's it, now I can build it
Gad_ST
Gad_ST
PostSubject: Re: DIY TRE for M800    DIY TRE for M800  Icon_minitimeThu Jan 03, 2013 11:12 am
First part done and tested, everything work ok, ecu did not find any errors (-C00), can't wait to take it on the ride (damn rain). Just orderd OEM connectors of e-bay so to finish it because I don't want to cut original wires.
DIY TRE for M800  Imag0062bx
DIY TRE for M800  Imag0065xo
PostSubject: Re: DIY TRE for M800    DIY TRE for M800  Icon_minitimeThu Jan 03, 2013 11:52 am
can't wait for your test ride DIY TRE for M800  2170595768 It would seem you have the same problem with rain as we do DIY TRE for M800  536894
PostSubject: Re: DIY TRE for M800    DIY TRE for M800  Icon_minitimeThu Jan 03, 2013 5:47 pm
Good on you Gad, looking forwrd to your findings and some pictures hopefully DIY TRE for M800  2170595768
PostSubject: Re: DIY TRE for M800    DIY TRE for M800  Icon_minitimeThu Jan 03, 2013 5:52 pm
good work hope the suns out soon for you or with sum luck the rain stops
Gad_ST
Gad_ST
PostSubject: Re: DIY TRE for M800    DIY TRE for M800  Icon_minitimeSat Jan 26, 2013 7:10 am
Finally connectors arrived, everything is soldered up and sun is shining :) went on the test ride, and all i can say there is a noticeable difference, especially in 2nd and 3rd gear.
PostSubject: Re: DIY TRE for M800    DIY TRE for M800  Icon_minitimeSat Jan 26, 2013 11:28 am
Nice one Gad, sounds very interesting. do you have any pictures of the item and install?
PostSubject: Re: DIY TRE for M800    DIY TRE for M800  Icon_minitimeSat Jan 26, 2013 5:18 pm
That's good to read, a mod well worth doing especially at DIY prices. DIY TRE for M800  3498837457
DIY TRE for M800
» Air Filter Removal M800 "Nekkid Jugs" M800
» M800 BAD registration plate for sale
» My M800:-)
» My new M800
» M800
DIY TRE for M800  Icon_minitimeby MTB59 Today at 6:29 pm
DIY TRE for M800  Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
DIY TRE for M800  Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
DIY TRE for M800  Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
DIY TRE for M800  Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
DIY TRE for M800  Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
DIY TRE for M800  Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
DIY TRE for M800  Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
DIY TRE for M800  Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
DIY TRE for M800  Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
DIY TRE for M800  Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
DIY TRE for M800  Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
DIY TRE for M800  Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
DIY TRE for M800  Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
DIY TRE for M800  Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
DIY TRE for M800  Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
DIY TRE for M800  Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
DIY TRE for M800  Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
DIY TRE for M800  Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
DIY TRE for M800  Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
