 Redneck installation of grasshopper Back rest
6 posters
Redneck installation of grasshopper Back rest Empty
PostSubject: Redneck installation of grasshopper Back rest   Redneck installation of grasshopper Back rest Icon_minitimeThu Feb 14, 2013 2:43 pm
I finally got my Grasshopper installed after a lot of engineering.
Redneck installation of grasshopper Back rest 6153B475-FD3B-4D20-B64B-BD1B2D9792A1-2896-000005E978A1A348_zps8ffe8ef0
As you can see the bracket only had one hole so that was the first thing I had to correct.
Redneck installation of grasshopper Back rest E9D9B9D5-D396-4CF2-AA5E-6D24B3092696-2896-000005E97C1C28E8_zps43641061
After I drilled bracket to fit
Redneck installation of grasshopper Back rest 4D9E848B-FD7B-400E-829B-F35D6177DD9A-2896-000005E9806622EA_zps3f4b68e9
bracket Installed
Redneck installation of grasshopper Back rest 5D6BCFD5-72F8-491F-AEB3-1FF7F7B9278E-2896-000005E99DDC42EF_zpsd013975f
As you can see that back rest bracket was too long. where the bend is hit me right at my belt line. It was so far forward it pushed nearly up on the tank.
Redneck installation of grasshopper Back rest 1AEFE78F-B7C4-415D-A129-0F3EB4C88D38-2896-000005E9A95FCD1B_zpsf0d314c5
Redneck installation of grasshopper Back rest 7D6D9C60-2BB0-440E-B1BD-FADD2A41587D-2896-000005E997331DC1_zpsa56f9dd0
I had to straighten that first bend. I had to cut the bracket off almost to that bend.
After several cuts and fits And bends I finally got it cut down to where it is comfortable and rides good.
I think I will be satisfied with it now. I have a different seat than original but not a Mustang. I ordered it for a Mustang Seat . That is why it was too long
PostSubject: Redneck installation of grasshopper Back rest    Redneck installation of grasshopper Back rest Icon_minitimeThu Feb 14, 2013 2:56 pm
Thought there was a lot of work to fit it then at the end got the reason why for a different seat but at least you sorted it Redneck installation of grasshopper Back rest 2170595768
PostSubject: Re: Redneck installation of grasshopper Back rest   Redneck installation of grasshopper Back rest Icon_minitimeThu Feb 14, 2013 3:09 pm
I probably should have said that at the first. I guess I should have sent it back but it works ok now.
PostSubject: Re: Redneck installation of grasshopper Back rest   Redneck installation of grasshopper Back rest Icon_minitimeThu Feb 14, 2013 3:45 pm
Good job, glad you sorted it to work for you. The best thing I ever did for comfort before installing the saddlemen profiler was to install a back rest. Makes such a difference, especially when under acceleration to help with comfort. General comfort is just so much better all around when a back rest is fitted at the right height and distance back.
PostSubject: Re: Redneck installation of grasshopper Back rest   Redneck installation of grasshopper Back rest Icon_minitimeThu Feb 14, 2013 8:15 pm
good job tex
PostSubject: Re: Redneck installation of grasshopper Back rest   Redneck installation of grasshopper Back rest Icon_minitimeThu Feb 14, 2013 8:36 pm
Nice job Tex Redneck installation of grasshopper Back rest 2170595768 How about a photo of the Trike with the backrest fitted Redneck installation of grasshopper Back rest 3498837457
Sanddancer
Sanddancer
PostSubject: Re: Redneck installation of grasshopper Back rest   Redneck installation of grasshopper Back rest Icon_minitimeFri Feb 15, 2013 9:38 pm
Well done Tex- good achievement! Redneck installation of grasshopper Back rest 184121345
My turn now....got mine delivered today and also does not fit (which I expected) Going to get some welding done on Monday and hopefully should look good also.
PostSubject: Re: Redneck installation of grasshopper Back rest   Redneck installation of grasshopper Back rest Icon_minitimeFri Feb 15, 2013 10:32 pm
I need to mention that to get it tight enough when I rode it the rubber mounted studs pulled out where the 2 mounting bolts are I had to make a piece of metal with matching holes underneath the fake fender. I didnt want it to burst the fiberglass out I put 2 hex bolts in it and tightened it down on the rubber that the studs were in. Going to make it harder to take seat off now but it is manageable. No step for a stepper. At least it is solid. I will get more pics when it warms up. Good luck on yours Sanddancer. Don't work get a bigger hammer.
» Driver Back Rest
» back rest
» Top Box / Back Rest
» Diy back rest idea
» * Home Made Rider Back Rest Suzuki C800 / C50 *
Redneck installation of grasshopper Back rest Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Redneck installation of grasshopper Back rest Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Redneck installation of grasshopper Back rest Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Redneck installation of grasshopper Back rest Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Redneck installation of grasshopper Back rest Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Redneck installation of grasshopper Back rest Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Redneck installation of grasshopper Back rest Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Redneck installation of grasshopper Back rest Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Redneck installation of grasshopper Back rest Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Redneck installation of grasshopper Back rest Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Redneck installation of grasshopper Back rest Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Redneck installation of grasshopper Back rest Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Redneck installation of grasshopper Back rest Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Redneck installation of grasshopper Back rest Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Redneck installation of grasshopper Back rest Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Redneck installation of grasshopper Back rest Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Redneck installation of grasshopper Back rest Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Redneck installation of grasshopper Back rest Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Redneck installation of grasshopper Back rest Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Redneck installation of grasshopper Back rest Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
