 Starter Control Relay
3 posters
BigPunishure
BigPunishure
Starter Control Relay Empty
PostSubject: Starter Control Relay   Starter Control Relay Icon_minitimeSat Mar 30, 2013 9:02 pm
I know most people bypass this relay and just use the starter switch to activate the "main" starter" relay. However, Suzuki must have had some reason for using a relay to activate another relay. Even though there are known issues with wiring and connectors, the elimination of a relay cannot be good. The additional load is now being handled by the starter switch.
One of the previous owners already bypassed my SCR (starter control relay). I am in the car audio field so I removed the OE SCR and retro-fitted a Bosch type relay and socket. A Bosch type relay can be found just about anywhere (literally), so if the relay ever gives me trouble (which I doubt due to its very short use during starting), it can be swapped out in 5 minutes.
My relay even had a metal tab which I put on "upside down" so I could reuse the OE rubber mount. Worked out perfect!
How do I upload pix? I have some on Photobucket.
PostSubject: Re: Starter Control Relay   Starter Control Relay Icon_minitimeSat Mar 30, 2013 11:17 pm
Clever stuff. Re piccies, I dont have Photobucket, but if it works like Picasa....... If you go to your Photobucket page, can you right click the web address in your browser bar and copy it? Then click the little 'photo' icon above (just to the left of the LINK icon). Paste your copied info into that and the forum software will put image tags around it.
Worth clicking preview to see if it appears as you expect....
ps.... you sound a very handy bloke to have on the forum Wink
BigPunishure
BigPunishure
PostSubject: Re: Starter Control Relay   Starter Control Relay Icon_minitimeSun Mar 31, 2013 12:35 am
Ok... watch out. I learned how to post pix!
Starter Control Relay Starterrelayretro-fit1_zpsa1ea8908
Starter Control Relay Starterrelayretro-fit2_zps29bde46e
Starter Control Relay Starterrelayretro-fit3_zps392000d8
Starter Control Relay Starterrelayretro-fit4_zps45da1927
Starter Control Relay Starterrelayretro-fit5_zpsb70e8b8f
Starter Control Relay Starterrelayretro-fit6_zpsa78b02f2
Starter Control Relay Starterrelayretro-fit7_zps2d4378ec
Starter Control Relay Starterrelayretro-fit8_zps8b412e24
Starter Control Relay Starterrelayretro-fit9_zps75a79399
Starter Control Relay Starterrelayretro-fit10_zps0f401904
Starter Control Relay Starterrelayretro-fit11_zps5695481b
PostSubject: Re: Starter Control Relay   Starter Control Relay Icon_minitimeSun Mar 31, 2013 10:43 am
Very tidy job Starter Control Relay 184121345
» VZ800 Starter Control Relay
» LED Flasher relay problem?
» Fitting a relay for heated grips.
» Starting problems/Relay?
» Non starter
Starter Control Relay Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Starter Control Relay Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Starter Control Relay Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Starter Control Relay Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Starter Control Relay Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Starter Control Relay Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Starter Control Relay Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Starter Control Relay Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Starter Control Relay Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Starter Control Relay Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Starter Control Relay Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Starter Control Relay Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Starter Control Relay Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Starter Control Relay Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Starter Control Relay Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Starter Control Relay Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Starter Control Relay Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Starter Control Relay Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Starter Control Relay Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Starter Control Relay Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
