 Where is the flasher relay located?
AmericanJambo
7 posters
AmericanJambo
AmericanJambo
Where is the flasher relay located? Empty
PostSubject: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeThu Jul 04, 2013 3:32 pm
Does anyone know where the turn signal flasher relay is located on the Marauder 800? Additionally, does anyone know how many pins it uses? And finally, do they make a direct replacement flasher? I want to swap out the flasher relay so I doesn't have to use load resistors. The load resistors make my signals much dimmer. Thanks guys!
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeThu Jul 04, 2013 4:17 pm
Maintanance & Bike Care Section Hi Jambo have you looked in here.Sorry can't be of any more help.
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeThu Jul 04, 2013 4:57 pm
Wish I could be of more help for your model. so far all I have worked out is the part # of the original 38610-03F00 This may help in position location.
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeThu Jul 04, 2013 5:00 pm
Wouldn't it blow the bulbs without a load resistor?
AmericanJambo
AmericanJambo
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeFri Jul 05, 2013 5:35 am
No, not using resistors won't blow out the bulbs because bulbs are incandescent and already have a load. Now LEDs have a much lower resistance than traditional bulbs, this is why they blink fast and require a load resistor so the flasher relay doesn't think the bulb is blown. The load resistor is wired in parallel, not series so it doesn't reduce the voltage to the LEDs, it just increases the load that the flasher relay sees which allows them to flash at the proper rate.
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeFri Jul 05, 2013 5:25 pm
Very good explanation Jambo.
twenty2
twenty2
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeFri Jul 05, 2013 10:40 pm
Dont know if the location of the relay is the same  on your model that it is on mine, 1998.
My realy is located behind the left side cover.
Yes there is a relay that works with led lights. Bought min on ebay. http://www.ebay.com/itm/SUZUKI-7-PIN-OEM-LED-Indicator-RELAY-WRELED05-/281115521189?pt=UK_Motorcycle_Parts&hash=item4173ca70a5
AmericanJambo
AmericanJambo
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeSat Jul 06, 2013 4:16 am
Thanks 22! I'm sure the electrical system is the same in the 98 as the the 00. I bel
 ieve the only real difference is the routing of the exhausr pipes. So when you say left side cover, are you speaking of the left side neck cover?
twenty2
twenty2
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeSat Jul 06, 2013 8:49 am
I ment the cover tjat is under the seat, begrunda the one om the left side there is relays, fusea and some connectirs.
When you say neck cover you ment the ones in front?
AmericanJambo
AmericanJambo
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeSun Jul 07, 2013 12:57 am
Got ya! I understand. I forgot there were fuses under there! Thanks!
twenty2
twenty2
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeSun Jul 07, 2013 1:03 am
No probs.
Hope you get it the way you want it.
AmericanJambo
AmericanJambo
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeSun Jul 07, 2013 3:49 pm
Yep, I found it. 7 pin design.
22Reed
22Reed
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeFri Jun 27, 2014 7:39 pm
lending this old thred......anyone know where it is on a m800 -2005 ?? guessing on the right side but there alot of simular things there :(
pic whould be great :)
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeFri Jun 27, 2014 8:34 pm
Under the rear Chrome cover on the left side of the bike.
22Reed
22Reed
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeFri Jun 27, 2014 8:39 pm
thanx for fast reply :)
22Reed
22Reed
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeMon Jun 30, 2014 7:54 pm
is it hard to mount a 3way relay if the standard is 7 pins???anyone done that?
22Reed
22Reed
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeTue Jul 01, 2014 10:12 am
stripped the left side. what part is it?? Where is the flasher relay located? 23mvd3o" />
kardax
kardax
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeTue Jul 01, 2014 2:05 pm
It's the black cube on the right, you can check it has 7 pins, when you unplug it (just pull it out).
I recommend you to download service manual from here:
http://www.mediafire.com/?7xtfbz5dzmbycul
and at page 9-35 there is also a picture, and more information about  the flasher relay.
22Reed
22Reed
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeTue Jul 01, 2014 2:19 pm
many thanx Kardax :)
kardax
kardax
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeTue Jul 01, 2014 2:27 pm
Can I ask, why would you want that? Let me guess, you would like to use led bulbs, right? and yes, they blink too fast with the original relay, since to work correctly it requires different load, than led bulbs.
I'm planning myself to change all my indicator bulbs to leds, and for that I already bought a replacement 7-pin relay for Suzuki that I can use for both filament and led bulbs, or even mixing them. At least here in Finland the 7-pin replacement relays for Suzuki bikes are widely available, pricing around 15 euros, like this one (if you are looking for it in Sweden?)
http://ebutik.nccr.se/belysning/blinkers/rela-motstand/blinkers-rela-7-stift-suzuki-12v-005a-10a
I would assume, you can find those from many motorcycle stores...We already did this to my brother's Suzuki Katana, and it really was the easiest way possible to start using led signals.
22Reed
22Reed
PostSubject: Re: Where is the flasher relay located?   Where is the flasher relay located? Icon_minitimeTue Jul 08, 2014 9:35 am
I only woundered if it was hard to do :) the 3 pin relay is 4.9eur and the suzuki 7pin is 30eur.
so I ordered the 7 pin from china :) and some new mirrors with leds in them. way too cheap :)
» LED Flasher relay problem?
» Starter Control Relay
»  VX800 Help please, where is the fan connection located.
» flasher unit,
» MOT Fail. Dead Relay? No Power
Where is the flasher relay located? Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Where is the flasher relay located? Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Where is the flasher relay located? Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Where is the flasher relay located? Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Where is the flasher relay located? Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Where is the flasher relay located? Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Where is the flasher relay located? Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Where is the flasher relay located? Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Where is the flasher relay located? Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Where is the flasher relay located? Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Where is the flasher relay located? Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Where is the flasher relay located? Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Where is the flasher relay located? Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Where is the flasher relay located? Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Where is the flasher relay located? Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Where is the flasher relay located? Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Where is the flasher relay located? Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Where is the flasher relay located? Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Where is the flasher relay located? Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Where is the flasher relay located? Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
