 DB levels
Rattler
azcam
Jimmyboy
hogbos
Freemo
shadycowboy
14 posters
shadycowboy
shadycowboy
DB levels Empty
PostSubject: DB levels   DB levels Icon_minitimeFri Sep 13, 2013 12:20 am
So I measured my DB. Who else has done this so we can compare.
I'll have mine remeasured tomorrow, as I have forgotten the idle and the rev numbers though lol.
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeFri Sep 13, 2013 7:22 am
I crashed my app when I tried :)
Freemo
Freemo
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeFri Sep 13, 2013 6:38 pm
If it stops raining I'll test mine again as I can't remember the figures but seem to remember tick over around 98, but check this link out to get an idea https://youtu.be/pSKocP_cg5I
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeFri Sep 13, 2013 7:23 pm
Martin, you're in different league all together my friend DB levels 184121345 DB levels 215375
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeFri Sep 13, 2013 8:17 pm
If you can set off the odd car alarm that probably puts you in the hundreds DB levels 852880
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeFri Sep 13, 2013 8:37 pm
Just copied this from another post in this section, only thing is that the DB level checked was with the normal baffles in as well as HK Quiet baflfles installed as well. He checked it and measured it at 2 different RPM's with V&H Cruzers
Mr Itruder wrote:
The db meter that comes for the IPhone-4 is actually very good source for db levels.
My mate has a proper meter and we cross referenced it against the IPhone. What we found is that the meter gives a very good reading of db level. When placed near to the exhaust but out of the flow just behind the end of the exhaust we found with the V&h Cruzers and HK quiet baffles was that it gave a db level of 95 at tickover but 110 at 3000rpm.
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeFri Sep 13, 2013 9:31 pm
Just done mine, Sorry vicar I Couldn't resist DB levels 852880 Piss poor! 89 at tick over 98 at 3k Embarassed How close to the zorsts are we having the meter? mine was about 3 feet.
hogbos
hogbos
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeFri Sep 13, 2013 9:36 pm
I put my iphone on a stool about 3 feet above the exhaust. DB app read 94db on tick over and 101db at 3000rpm.
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeFri Sep 13, 2013 10:04 pm
Unless we all decide the distance for the measurements, this exercise is no good for comparison purposes.
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeFri Sep 13, 2013 10:09 pm
Yup, that too.
Apparently:
Quote :
Position the sound level meter exactly 20 inches behind and at the same height as the motorcycle's exhaust. The microphone must also be parallel to the ground and positioned at a 45 degree angle when compared to the motorcycle's normal line of travel
Ignoring the fact that the sound meter should be calibrated etc and people will use different ones, that's as close as we can make it I think.
Also would be good if the measurement was taken away from closed spaces, walls etc, so the sound doesn't bounce.
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeFri Sep 13, 2013 10:12 pm
Moved from just above Marcins last post so as to slightly change the text
Also check what your appliance says with regards to this and the app that you will be using. What is right for on will be wrong for another
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeFri Sep 13, 2013 10:18 pm
DB levels 3498837457 I'll try it again Very Happy The Reverend Penny won't be amused! DB levels 410694
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeFri Sep 13, 2013 10:19 pm
Say that you're testing a church bell replacement... new sound for 21st century ;D
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeFri Sep 13, 2013 10:35 pm
That experiment has proved 3 things?
1.. my garage now smells of exhaust fumes.DB levels 4160623885
2.. my neighbour has no sense of humour ? my dog is bigger than his though, so no relevance :shithhappens:
3.. 94db tick over 100db at 3k Embarassed
oops sorry! 4 things? Jo is convinced I'm not normal DB levels 56357
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeFri Sep 13, 2013 10:39 pm
100db at 10:39pm.... hell I don't know many people with such sense of humour haha DB levels 3213823784 DB levels 3213823784
Sim you're perfectly normal...to us DB levels 215375
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 4:54 am
Jo seems to be a pretty level headed lady. But I could be wrong DB levels 2343124779
Jimmyboy
Jimmyboy
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 6:35 am
So what generic distances are we all going to use then? just been reading that db readings should be taken at 1-3 meters from source and not directly at source so with that in mind shall we say to take an accurate comparison we should all place our meter at 1 meter back and 1 meter to the right (when looking at the rear of the bike) and also in an open space so as not to get to much resonance, two readings to be taken i.e 1st @ tick over and 2nd @ half throttle.
How does that sound?
Jim.
hogbos
hogbos
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 10:30 am
Ive redone mine at Jims suggestion and got the same result as I did on the stool I did last night. 94db at tickover and 101db at 3000rpm
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 1:03 pm
annoyed.com... my HTC One X does not record anything higher than 94db, no matter what.
Need to find someone with the (bad) Apple's iPhone :)
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 1:10 pm
DB levels 938687981  ? Tell this old redneck what tickover means.
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 1:21 pm
Idle speed Tex DB levels 3498837457
Freemo
Freemo
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 2:56 pm
Hmmm anyone know where you can buy, at reasonable cost, a db meter that goes beyond 110db as this is as far as my iPhone app goes?
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 3:38 pm
Sorry martin I am no help here as techy things loose me but I did just search and see that Maplins do a meter that runs to 130DB but that ain't cheap it's £29.99 so probably not what your looking for as it will not get enough use to warrant the cost, Hopefully someone will have a cheapo idea that lots can use
Freemo
Freemo
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 3:48 pm
I've seen one on eBay and bid on it, it goes up to 130dB but somehow I think I may be pushing it lol
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 4:36 pm
Martin I think you may be suprised as DB's are funny how they are worked out, 130db is not 30% louder than 100db to think that it is 30db level louder when you consider it against 100db is kind of wrong it can give the wrong impression. 130db is many times louder than 100dbs i believe
wikipedia wrote:
On the decibel scale, the smallest audible sound (near total silence) is 0 dB. A sound 10 times more powerful is 10 dB. A sound 100 times more powerful than near total silence is 20 dB. A sound 1,000 times more powerful than near total silence is 30 dB.
Jimmyboy
Jimmyboy
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 5:12 pm
My test failed !!! my windows phone wouldn't record anything over 70db probs down to the microphone !!!
Just done it with the ipad and got 99db at idle and errrr......well the meter only goes to 110db so its errrrrr well louder than that at half throttle  !!!! lol
Note: my pipes are standard with the baffles removed.
Jim.
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 5:36 pm
Standard pipes with baffles removed and 99db at idle DB levels 249703 Wow they must sound mean, love it affraid
Jimmyboy
Jimmyboy
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 6:17 pm
I really like the look of the standard pipes so the baffle removal mod was great for me......and its cheap too !!! lol
Jim.
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 6:26 pm
DB levels 428386
azcam
azcam
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 7:28 pm
If you like the look of the standard pipes, you should check out the pipes i fitted on my Slip ons thread.
 K02 Silvertails custom pipes. I think there the mutts nuts and with the baffles out they are REALLY LOUD.
Jimmyboy
Jimmyboy
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 7:46 pm
Yeah seen them azcam....I have also seen how much they are new !!!!! lol
Jim.
azcam
azcam
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 7:51 pm
Yeah stung a bit like £460 sheets i paid...
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 8:05 pm
I have 8 - 1/2 inch holes drilled in outer plate. First baffle punched out with 1 inch rod.
96db vs 100
Everyone of the guys I ride with say it sounds good.
oiler
Saint Oiler the 1st
oiler
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSat Sep 14, 2013 10:39 pm
To me, the solution is very simple. Knock a few holes in the end plates, and enjoy.
Rattler
Rattler
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeWed Oct 09, 2013 11:33 pm
I'll do mine tomorrow.
oiler
Saint Oiler the 1st
oiler
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeThu Oct 10, 2013 7:56 am
Hi Rattler   I've no got six holes per end-plate but bafffles intact. Sounds good around town and up to (say) 55mph, any faster and wind noise takes over. Have left baffles due to concerns about MOT and re-sale value, as once their damaged, there's no going back
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeThu Oct 10, 2013 9:27 am
Holes drilled in the end plates can easily have a circular plate put over them like Bluesman did when he traded his bike back in and the holes being put in the internals with a long rod make it sound nicer but can not be seen & mainly just change the pipes to sound better but do not sound like an exhaust that has a leak so both are ok. As for the MOT, no problems have ever been expressed by anyone that has ever done either
oiler
Saint Oiler the 1st
oiler
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeThu Oct 10, 2013 12:34 pm
Thank you for that, Captain. I've returned the heavy hammer (to a Bandit owner) and the long spike (to a Beemer owner), because of my MOT concerns. I now have to agonise all over again. Shall i, Shan't I ? Driving me mad.  One quick question. What are the 800's baffles made of ? It's been suggested to me that they could be stainless steel, and therefore, there's a risk of knocking the end off into the exhaust, causing an unwanted rattle (a well as the better sound). True; false ? Ta
PS I had to borrow said instruments, as oiling a clutch cable never needed such equipment, and I've never done anything since !!
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeThu Oct 10, 2013 1:20 pm
Clive, if my Jardines got MOT'd then I don't see how customised stock one wouldn't.
As for the internal plate...why noone does this with a long ass drill?
Something like 60cm should be long enough? Then you're not risking bending anything or knocking it off or anything like that.
Food for thought.
oiler
Saint Oiler the 1st
oiler
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeThu Oct 10, 2013 1:24 pm
Thanks Marcin, I feel an investment coming on
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeThu Oct 10, 2013 4:57 pm
I would only use a drill bit that was being used in a drill, not to be hit as it has no point so would need to be hit much harder & it could possibly cause just a big dent/bevel in the plates before making the desired hole. It's possible that depending on the way they are put together internally that hitting with a blunt object could cause other damage that so far hitting a hole with a long pointed bar has not shown up or done.
truckie1971
truckie1971
DB levels Empty
PostSubject: Re: DB levels   DB levels Icon_minitimeSun Oct 13, 2013 2:38 pm
Well as a expensive lesson, I've stripped the standard pipes completely,from the end working ire way to the pipe into the baffles you have the tube baffle welded to a plate with holes in.behind that is 2 further plates and on the very end is a round thick mesh filters that's in the intake pipe. The r pipe is easy to clear the other has a little bend which is how I put a hole in the side of my exhaust......doh! In my opinion it's easywe Tobuy some decent after market pipes and it's easy to fit them than muck about with the standard ones !
DB levels Empty
DB levels
» Exhaust noise Levels
DB levels Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
DB levels Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
DB levels Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
DB levels Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
DB levels Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
DB levels Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
DB levels Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
DB levels Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
DB levels Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
DB levels Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
DB levels Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
DB levels Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
DB levels Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
DB levels Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
DB levels Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
DB levels Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
DB levels Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
DB levels Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
DB levels Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
DB levels Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
