| Quietening down aftermarket exhausts | |
| Subject: Quietening down aftermarket exhausts Sat Feb 08, 2014 10:05 pm | |
| - Oiler wrote:
- HH Shorties on my oldIntruder we're too noisy, as we're a pal's V&H Any views please on what's noisy, but not that noisy?
(This is a quote from another section - it's more appropriate here) Apart from modified stock,it's easy to quieten down aftermarket pipes. Take out the baffles and wrap fibre-glass stove rope or ladder tape from a heating supplies firm around the baffles, fix with wire and refit. This is a universal method where you can get any exhaust down to any volume you require. I used it very successfully on my HH Short Cuts. Quiet baffles are available commercially but will give a fixed db reduction. You will find all the info available by searching this section. Hope this helps. | |
| | | oiler Saint Oiler the 1st
| Subject: Re: Quietening down aftermarket exhausts Sat Feb 08, 2014 10:34 pm | |
Apart from modified stock,it's easy to quieten down aftermarket pipes. Take out the baffles and wrap fibre-glass stove rope or ladder tape from a heating supplies firm around the baffles, fix with wire and refit. This is a universal method where you can get any exhaust down to any volume you require. I used it very successfully on my HH Short Cuts. Quiet baffles are available commercially but will give a fixed db reduction. You will find all the info available by searching this section. Hope this helps. Helpful as always. Thanks (and transferred to the correct section too) | |
| | | Jimmyboy Valued Member
| Subject: Re: Quietening down aftermarket exhausts Tue Feb 18, 2014 6:57 am | |
| Best way to quieten after market exhausts is to put the originals back on lol.
Jim. | |
| Subject: Re: Quietening down aftermarket exhausts Tue Feb 18, 2014 5:52 pm | |
| - Jimmyboy wrote:
- Best way to quieten after market exhausts is to put the originals back on lol.
Jim. That's not quiet, that's silent | |
| | | twenty2 Member
| Subject: Re: Quietening down aftermarket exhausts Tue Mar 25, 2014 9:45 pm | |
| I dont know how this solution is as a permanent use, but i have used it for the inspecions that needs to be done one motorbikes every 2 years here in Sweden. I have a pice of pipe with the same outer diameter as the pipes have inner diameter. One end has a welded bottom with 10, 5mm holes in them. I put 2 of those metallic "balls" that is used for cleaning, like "metallic scotch-brite", in the pipe. The inner pipe is fitted at the end of the exhaust and fitted with a screw that goes through the exhaust pipe and in to the inner pip. This reduces the sound level enough to pass through the inspection | |
| Subject: Re: Quietening down aftermarket exhausts Wed Mar 26, 2014 4:46 pm | |
| Good little cheap mod Twenty2. | |
| | | twenty2 Member
| Subject: Re: Quietening down aftermarket exhausts Wed Mar 26, 2014 4:49 pm | |
| Thanks alfie As i said, i dont know how it will work on long term usage. But it lower the sound level enough to get passed through the inspection. | |
| Subject: Re: Quietening down aftermarket exhausts Wed Mar 26, 2014 8:21 pm | |
| Nice one Twenty2 always better to make something up if its just for a purpose day rather than permanent and even for permanent use some times when it is a simple modification | |
| Subject: Re: Quietening down aftermarket exhausts Thu Mar 27, 2014 8:35 am | |
| That worked well Twenty2. | |
| Subject: Re: Quietening down aftermarket exhausts | |
