 Dual headlights and new signal indicators.
7 posters
Dual headlights and new signal indicators. Empty
PostSubject: Dual headlights and new signal indicators.   Dual headlights and new signal indicators. Icon_minitimeWed Oct 08, 2014 10:32 pm
I have nearly finished the rear fender setup, and while waiting for the new rear lights, I decided to get the dual headlight and front indicator mounted.
I got some nice aluminium clamps for the fork from louis mc shop, and made some small brackets from stainless steel.
The original plan was to make some small angle brackets, and I made some mockups in cardboard.
Dual headlights and new signal indicators. IMAGE_104
Dual headlights and new signal indicators. IMAGE_105
But I did not like the angled part, and that the clamp screw was on the side of the fork.
So I decided to rotate the clamps 90 degress and mount a straight bracket between the two clamp parts.
Dual headlights and new signal indicators. IMAGE_106
Dual headlights and new signal indicators. IMAGE_107
It´s much cleaner looking and have the added benefit, that I now have a free screw in each clamp, meaning I can rotate them 180 degress and use the screw for a potential future screen mount.
I also needed to refit the wires from the original headlight to the left side neckcover.
Dual headlights and new signal indicators. IMAGE_108
Dual headlights and new signal indicators. IMAGE_109
I also didn´t like the matt black finish of the headlights, and sprayed them a couple of times with clear lacquer, and wetsanding in between layers.
The indicators are also from the louis mc shop, and are Xenolen LED Rocket paired with a new indicator relay.
Dual headlights and new signal indicators. IMAGE_110
Dual headlights and new signal indicators. IMAGE_111
Dual headlights and new signal indicators. IMAGE_112
PostSubject: Re: Dual headlights and new signal indicators.   Dual headlights and new signal indicators. Icon_minitimeWed Oct 08, 2014 10:36 pm
That looks great Kim Dual headlights and new signal indicators. 2170595768
PostSubject: Re: Dual headlights and new signal indicators.   Dual headlights and new signal indicators. Icon_minitimeWed Oct 08, 2014 10:46 pm
wow Dual headlights and new signal indicators. 2170595768 That looks the dogs  dogsbDual headlights and new signal indicators. 102087026 Nice job Kim  Dual headlights and new signal indicators. 3498837457
PostSubject: Re: Dual headlights and new signal indicators.   Dual headlights and new signal indicators. Icon_minitimeThu Oct 09, 2014 7:21 am
That looks so very good, the headlights really fit the look of the bike so much better. I would be giving myself a big pat on the back if I was you, great job well done. Dual headlights and new signal indicators. 2645662097 Dual headlights and new signal indicators. 276246
PostSubject: Re: Dual headlights and new signal indicators.   Dual headlights and new signal indicators. Icon_minitimeThu Oct 09, 2014 9:34 am
Looks fantastic, well executed and explained.
PostSubject: Re: Dual headlights and new signal indicators.   Dual headlights and new signal indicators. Icon_minitimeThu Oct 09, 2014 1:13 pm
Looks good Kim! Well done.
azcam
azcam
PostSubject: Re: Dual headlights and new signal indicators.   Dual headlights and new signal indicators. Icon_minitimeThu Oct 09, 2014 3:35 pm
What's the legality with twin head lights. Are you allowed them both on at once? Or is the EU having its say?
PostSubject: Re: Dual headlights and new signal indicators.   Dual headlights and new signal indicators. Icon_minitimeThu Oct 09, 2014 3:37 pm
No problem with dual lamps at all from what I understand.
azcam
azcam
PostSubject: Re: Dual headlights and new signal indicators.   Dual headlights and new signal indicators. Icon_minitimeThu Oct 09, 2014 3:39 pm
Just wondering as all the sport bikes with twins only have one lit up cause of Mr EU knob
PostSubject: Re: Dual headlights and new signal indicators.   Dual headlights and new signal indicators. Icon_minitimeThu Oct 09, 2014 4:13 pm
First of all in the UK no lights are required for a daylight MOT, so Europe has not got us under their wing just yet.The following is all that is said of the lights where fitted in the MOT check list in the UK. Nothing is mentioned regarding the number of lights used.
Headlight:
Must be free of chips or cracks
Headlight must work on main and dip beam
Main beam must shine directly ahead and the dip slightly lower and to the left.
PostSubject: Re: Dual headlights and new signal indicators.   Dual headlights and new signal indicators. Icon_minitimeThu Oct 09, 2014 6:18 pm
The headlight is bought here in DK, and is E marked, so it should be legal.
This is the info from the seller:
Biltema declaration of Conformity
PostSubject: Re: Dual headlights and new signal indicators.   Dual headlights and new signal indicators. Icon_minitimeThu Oct 09, 2014 7:11 pm
Dual headlights and new signal indicators. 428386 My R1 had dual headlights and so did my SV1000s , both on all the time.
azcam
azcam
PostSubject: Re: Dual headlights and new signal indicators.   Dual headlights and new signal indicators. Icon_minitimeThu Oct 09, 2014 7:14 pm
Cool thats good to know. For some reason i thought that you was only allowed to have one headlight on.
Think i was told that this was an Eu rule. Obviously im talking out of my hoop, which is not un common for me.. Dual headlights and new signal indicators. 804997
» problems right signal
» Turn signal help
» Dual headlights
» Front Turning Signal Lights
» Installed turn signal mirrors
Dual headlights and new signal indicators. Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Dual headlights and new signal indicators. Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Dual headlights and new signal indicators. Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Dual headlights and new signal indicators. Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Dual headlights and new signal indicators. Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Dual headlights and new signal indicators. Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Dual headlights and new signal indicators. Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Dual headlights and new signal indicators. Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Dual headlights and new signal indicators. Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Dual headlights and new signal indicators. Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Dual headlights and new signal indicators. Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Dual headlights and new signal indicators. Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Dual headlights and new signal indicators. Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Dual headlights and new signal indicators. Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Dual headlights and new signal indicators. Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Dual headlights and new signal indicators. Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Dual headlights and new signal indicators. Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Dual headlights and new signal indicators. Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Dual headlights and new signal indicators. Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Dual headlights and new signal indicators. Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
