 2002 Volusia running rough
ToeKnee
diesel dave
13 posters
Go to page : 1, 2  Next
ToeKnee
ToeKnee
2002 Volusia running rough Empty
PostSubject: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeSat Oct 24, 2015 8:07 am
I bought back my original 2002 Volusia and in the 8 or 9 years since I had her originally she had done only 900 miles, (6,500 miles since new) all works well but at low throttle in all gears she is as lumpy as a lumpy thing on lumpy day. Once the revs are up no problem it runs and pulls great. I have to ride it with more revs and lower gears around town otherwise it is like riding a bucking bronco! Now I guess its the idle jet/needle clagged up. I have put two doses of Red Ex petrol treatment into the tank about 4 times the normal dosage but its no better.... I am not confident in ripping out a carb etc so any advice tips or local to Tamworth UK someone that knows who or how to do it? Happy to pay someone for their help
Many thanks Tony
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeSat Oct 24, 2015 8:30 pm
Always try the simple things first, Redex is a bikers saviour. Put not a cap full in a tank of petrol but a whole bottle f the stuff in a tank full of fuel. Fill the next tank up with just petrol but the next tank put a whole bottle of Red ex in again. It's worked for me before, worth a thought.
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeSat Oct 24, 2015 9:29 pm
Check your plugs too.
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeSun Oct 25, 2015 5:33 am
Thanks for the advice, I think its more fuel than plugs but I have some ready to fit as well.
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeThu Nov 12, 2015 8:47 pm
Always worth replacing the plug leads as well - they deteriorate over time
diesel dave
diesel dave
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeThu Nov 12, 2015 9:02 pm
seafoam...really good stuff...my vmx was a pain on rough idling and bottom end hesitation slapped a tin in ,ran it for 5 mins,let it stand over night and... wallah,sorted
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeFri Nov 13, 2015 4:59 am
I had not considered the plug leads but it makes sense, Sea Foam, do I put that into the tank or direct in the carb?
diesel dave
diesel dave
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeFri Nov 13, 2015 4:15 pm
Hi toeknee,...i just put it in tank then ran it for 5mins and let it stand,iv read posts before when they have drained carbs and poured it in but that was in really extreme cases of bad running,yanks swear by this stuff
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeFri Nov 13, 2015 7:33 pm
Any places you know I can get this to try?
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeFri Nov 13, 2015 8:02 pm
You can get it off eBay Tony, I'm not sure there's many stockists over here?
http://www.ebay.co.uk/itm/SEA-FOAM-Motor-Purge-Diesel-Petrol-Engine-Injector-Cleaner-Fuel-Stabiliser-/351189584457?hash=item51c487ca49:g:2bAAAOSwQItUEagI
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeFri Nov 13, 2015 8:32 pm
Thanks for the link, I guess its worth a go rather than strip the carb off :)
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeSat Nov 14, 2015 12:19 pm
Must get some of that as well Sim, thanks for the link mate!
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeWed Nov 18, 2015 7:01 am
Ok Seafoam arrived, it says 1 fluid ounce per gallon into the tank, was thinking of emptying the bottle in... is that wise  affraid
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeWed Nov 18, 2015 8:07 am
Probably better following the recommendations on the bottle Tony
diesel dave
diesel dave
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeWed Nov 18, 2015 5:22 pm
I put a quarter tin in about a gall and half i had left in bike Tony,didn't make it smoke or anything
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeThu Nov 19, 2015 7:05 am
Ok thanks I have half a tank so half a tin should be ok??
diesel dave
diesel dave
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeThu Nov 19, 2015 7:09 pm
With most fuel cleaners its always...more the better,iv found that to be mainly true ,with seafoam you can fill the carbs and let stand then just run.Somewere on the tin or on there site it says you can add a certain amount to your oil???? what that achieves i dont know unless it washes the internals.
Hope it cures this for you as well Tony
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeMon Nov 23, 2015 10:18 pm
Well I ran the bike for 5 minutes to get her warm, it just would not tick over unless a bit of choke was on.... I tried turning the throttle stop screw by the Pair Valve housing, tried it back and forth but no change so I put the seafoam in and will leave it overnight.
The throttle stop screw which you turn to increase or decrease tickover.. Which way increases tickover, clockwise?
If this does not work I will have to get it stripped down at the local garage :O(
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeMon Nov 23, 2015 10:36 pm
Clockwise usually increases the tick over Tony.
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeTue Nov 24, 2015 7:31 pm
Took off the K&N air filter off stock one back on runs rough wont tick over evenly keeps cutting out a few revs and its ok just wont idle even when warm, so much Red Ex and Seafoam in the tank I think thats not helping ;O) I guess next step is get it to a service man and a carb stripdown and clean....
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeTue Dec 01, 2015 10:39 am
Ok just had a chat with the garage that are looking at the bike, carb clean but mixture screw was right out, set to about 1.5 to 2.5 turns as in manual and it wont run on tick over, set it to 3.5 turns and seems to be fine??? No signs of air leaks etc, yet to be test ridden. Spark plugs changed at same time not that makes any difference just they were the original ones!
I am wondering if the diaphragm may be knackered??
watsonchuck1 likes this post
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeTue Dec 01, 2015 10:50 am
Just ordered a Carb repair kit and Diaphragm from  http://www.motorcycleproducts.co.uk/
£42 with next day delivery so at least I know the carb is sorted then.... I hope !!
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeWed Dec 02, 2015 4:47 pm
good luck toeknee, if you can take some pics/video when you strip down the carb might help some others on the forum 2002 Volusia running rough 3498837457  not to mention being really interesting to those of us with Fi.
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeThu Dec 10, 2015 10:04 am
Well I am at a loss, two weeks the garage has had my bike, I bought a carb repair kit and a new diaphragm he fitted it all checked the carb which was clean but cleaned it and checked the jet, but it still wont run smooth on low revs, it stutters and tries to cut out, once the revs are up its ok, he has given up on it as he has no idea what it could be except he thinks its an air leak somewhere....  So I am at a loss what I can do now, he was decent enough to say I owe him nothing for the labour but I would rather have paid a couple of hundred pounds and had a working bike :( :( Not sure where to go now.........
Old Luner
Old Luner
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeThu Dec 10, 2015 3:46 pm
Only thing that springs to mind Tony is that it may be drawing air on the inlet manifold (s), don't know if they're plastic, rubber or alloy on that model but check for cracks if they're rubber or plastic.
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeThu Dec 10, 2015 4:22 pm
Thanks Old Lunar, I think the garage guy was thinking of that, its now on its way to a Suzuki dealer to put it on a diagnostic machine to find out where the problem lies... Hopefully in a non expensive bit :O)
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeThu Dec 10, 2015 8:33 pm
It's a strange one for sure Tony? Hope you get it sorted at minimum expense.
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeFri Dec 11, 2015 8:03 pm
Well things have moved on a bit since my last post.
Ok the mechanic sent the bike to a main Suzuki dealer who was going to do a diagnostic check for £66 then get back to me with a result. Today I had the dealer ring me stating they had spent three hours on it and it was in bits and still no luck they have stripped the carb and are saying that the diaphragm is knackered (new one) saying it was fitted wrong and damaged... they say they think the pipes from the carb are miss-routed basically saying the mechanic I used has knackered things up. I was shocked to hear the bill was already over £200 and they still had no diagnosis of what was actually wrong.... I asked why he did not do as he said after the £66 diagnosis test and call me to update me on things he said the mechanic was enthusistac and got carried away with the time... my money it seems!! They say it is not running on the back cylinder and will ring me tomorrow to let me know what the cause is and a price for the repair... To say I am dissapointed and shocked is an understatement, I phoned my mechanic and told him they are saying he f*cked it up and told him to speak to them tomorrow and sort it out as I am just the mug in the middle here... One pissed owner at the moment frightened as to what the bill will be and if its worth repairing, to think I have done about 100 miles since spending £3,000 buying her........................God I hate bikes tonight :O(
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeFri Dec 11, 2015 8:26 pm
I'd refuse to pay them anything above the £66 for the diagnostic check Tony, their over enthusiastic mechanic had no authorisation to carry out any further work without your agreement, sounds like another main dealer rip off to me  2002 Volusia running rough 2917598063
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeFri Dec 11, 2015 8:54 pm
Tough it out Tony...its not acceptable for them to do that !
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeFri Dec 11, 2015 9:47 pm
If it was a carb problem? surely it would be running crap on both cylinders not just the back one, they only have one carb feeding both cylinder, has anyone checked over the ignition side of things yet?
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeSat Dec 12, 2015 8:03 am
AGREED. I also would only pay the £66 you had agreed to pay, the fact that their mechanic got carried away and did work without your approval, should be at their expense and not yours.
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeSat Dec 12, 2015 9:47 am
Just to add to my post, the dealer claims that the parts your mechanic fitted were incorrectly fitted and the route of the pipes is incorrect, you only have their word for this, any damaged could have been a result of their mechanic's intervention.
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeSat Dec 12, 2015 9:51 am
if you've only booked it in for a diagnostic check, why did they strip it?  Did they tell you what the diagnostic check would include beforehand?
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeSat Dec 12, 2015 10:35 am
I also feel a mention in the retailers section is advised to warn others.  Did you get round checking the coil & leads?
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeSat Dec 12, 2015 11:18 am
As stated above I'd not pay anymore than the £66- & state that they were in the wrong to do anything else to the bike without your express authorisation & they are now liable to return the bike in the condition it arrived in & not in the dismantled state it is in now!
Old Luner
Old Luner
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeSat Dec 12, 2015 1:31 pm
I agree with the other guys here Tony, they had no authorisation to do anything other than the diagnostic and had absolutely no entitlement to proceed without consulting you.
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeSat Dec 12, 2015 1:41 pm
gutted for you I side with the others in that they should not have gone any further without your permission, if you know and trust your mechanic I might be inclined to take what the dealer said with a pinch of salt . leaves you in a very bad place though be interesting to hear what your mechanic and dealer have to say to each other
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeSun Dec 13, 2015 7:32 pm
Any updates Tony?
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeMon Dec 14, 2015 7:18 am
The dealer service manager rang me Saturday as I was on my way to work, he said the mechanic had been on the bike for over 8 hours up to now and could not find out why the bike was not working on both cylinders,it was obvious they were struggling. I said to them that if they couldnt find the problem being main dealers who could! He said that all of their mechanics were fully trained and that they have one mechanic the senior one who is one of the top ten qualified in the UK for Suzuki. He was going to put that guy onto it Tuesday. He said that they have to find the problem as I think they will feel embarrassed if they do not... I was worried about cost of all this but he said they cant find the fault so they cant charge me for all the hours and it looks at the moment like its stopped at 3 hours charge. However I feel they would like me to take the bike away as is so they can forget it. I want them to continue as if they (main dealer) cant fix it who can! I checked with previous owner who I originally sold the bike to and he has not had any work done on her only service every year and was surprised I had the issues as it was perfect, I spoke to the independent dealer I bought the bike from in the summer, he said they only had the bike a week and only did a service and MOT and pre delivery check, so he could not understand why I was having the problem. I said to both that dealer and previous owner if there was any issues I would not be looking to lay blame but just have a starting point for the main dealer to fix it. I believe that NO Spanner Has Been Used on this bike so it is a one off fault that just happened.
So I am waiting until Tuesday when this top mechanic is going to work on it, I have one nagging concern that the only non standard thing on the bike is a Datatool Alarm that I had fitted when the bike was new in 2002, it was fitted professionally and has worked well, but maybe that is affecting something if its going wrong?? I did tell the Suzuki dealer to disconnect it if they wanted to eliminate it and I was not bothered if they threw it away.
So long update with no news :) Oh I have booked a few extra shifts over Christmas as I am going to need that money for the dealer bill..... Wife wont be happy with me working all over Christmas as she is well pissed with me selling a perfectly good 2003 Volusia so I could buy back my original one...Just hope that it gets sorted and I can keep the cost below £500 ish
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeMon Dec 14, 2015 10:39 am
Couple of questions.  When you bought it, did you test ride it - was there a problem when you first got it, or did the problem begin after you bought it?  If you bought it from an independent dealer, did you get an kind of warranty?  If you bought from a dealer, you have consumer rights - it may be worth approaching him - either it already had the problem, or it developed soon after you bought it.
Don't put too much faith in main dealer - they said they were unable to replace a seal on my diff unit as they "didn't have the right tools" - me & my cousin did it my garage using a cordless impact driver & a spare wheel.  I'd rather use a keen, independent, one-man operation - they have a lot more to lose in the reputation stake.
All the best with it - keep us updated - I'm sure we all feel your pain
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeMon Dec 14, 2015 10:52 am
This needs fixing, if for now other reason than the tension is killing me!!
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeMon Dec 14, 2015 11:13 am
The problem with main dealer mechanic's they are normally not fully trained motorcycle mechanic's, they are trained to do servicing and replacing parts, not finding problems and rectifying them. As already been said in an earlier post a local independent bike shop is the place where you will more than likely find a fully trained good motorcycle mechanic with good fault finding skills
Over the years with both motorcycles and cars this has been my experience. However this is purely my opinion and not intended to offend any main dealer motorcycle mechanics or anybody else.
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeMon Dec 14, 2015 4:39 pm
The Alarms a good shout Tony, someone else had an undiagnosable fault and it turned out to be the alarms immobiliser kicking in. good luck I hope everything turns out ok  2002 Volusia running rough 3498837457
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeWed Dec 16, 2015 4:46 pm
Well Tuesday came and went and no phone call, so I rang them today to be told it was sorted and mechanic was finishing off and doing job card and they would ring me in a bit, said it was a vacuum pipe and fuel pump problem..... well 4 hours later no call, I guess it wasnt that then  2002 Volusia running rough 3307848339
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeWed Dec 16, 2015 4:48 pm
Man - that's so frustrating.  Why don't they just wait till it's running ???? If it is only a vacuum pipe it'd be a right result.  Fingers crossed for you !!
ToeKnee
ToeKnee
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeWed Dec 16, 2015 6:08 pm
Just had a call from the dealer, they have fixed it and done a road test all working good again, apparently they have done the following, carb rebuild, jets and settings redone to proper positions, calibrated throttle and fuel pump, replaced vacuum hoses that were perished replaced the seal/ring on the inlet to rear cylinder that had perished (which is probably why it was drawing air not enough fuel).
I asked the price and sat down ready to hear the bad news, but like the X Factor they would not give me a instant price.... I have to speak to the service manager in the morning "as he was doing a deal on the labour" I was told.... I will take Valium when I get up to ease the pain I may be getting I guess!
I will let you know the cost but as a precaution I have listed the wife on eBay...... sssmily
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeWed Dec 16, 2015 6:51 pm
Sounds like a thorough job, glad you got to the bottom of it Tony  2002 Volusia running rough 3498837457  best buy a rubber ring to sit on now pal? I suspect they'll arse rape you  affraid
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeWed Dec 16, 2015 6:54 pm
Pleased to hear the problem has been sorted, now it's time to put your haggling skills to work. Good luck.
PostSubject: Re: 2002 Volusia running rough   2002 Volusia running rough Icon_minitimeWed Dec 16, 2015 6:59 pm
Point out that they didn't ask you for permission before undertaking so much work.  Mind you - you may be pleasantly surprised - they may actually be concerned about their reputation.  Just in case you're in for a rubber-ringing, what the reserve on the missus ???
Good to hear it's sorted though - the rubber's probably perished through not being used.  At least you'll have a happier Xmas
» HELP ,Rough Running
» Coolant Level 2002 volusia
» False air filter mod / 2002 Suzuki Volusia
» MY RIDE. Bikerdave's .......... 2002 Suzuki Volusia
» Mods fitted to .......... VL800 VOLUSIA 2002
2002 Volusia running rough Icon_minitimeby Jack70 Yesterday at 4:35 pm
2002 Volusia running rough Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
2002 Volusia running rough Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
2002 Volusia running rough Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
2002 Volusia running rough Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
2002 Volusia running rough Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
2002 Volusia running rough Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
2002 Volusia running rough Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
2002 Volusia running rough Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
2002 Volusia running rough Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
2002 Volusia running rough Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
2002 Volusia running rough Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
2002 Volusia running rough Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
2002 Volusia running rough Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
2002 Volusia running rough Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
2002 Volusia running rough Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
2002 Volusia running rough Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
2002 Volusia running rough Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
2002 Volusia running rough Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
2002 Volusia running rough Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
