 Fitting a relay for heated grips.
7 posters
Fitting a relay for heated grips. Empty
PostSubject: Fitting a relay for heated grips.   Fitting a relay for heated grips. Icon_minitimeTue Nov 24, 2015 10:32 pm
This one is for Sim and anyone else who wants to prevent heated grips accidentally being left on. I purchased an automotive relay. You can get them at any car shop or Maplins etc for around a fiver or less.
Fitting a relay for heated grips. 02_zps3rfvuyrd
Place under the seat/near the battery.
Connect:
87 to the  +  terminal on the battery
86 to the  –  terminal on the battery
30 to the live on the heated grips
85 to an ignition switched live (eg. horn, brake light switch, number plate light etc)
When you turn off the ignition the circuit is broken and the grips go off even if they are still in the on position! This is the professional method of installing grips. I have not done it on the VL because I don’t ride far in the cold weather. However I installed mine on the DL and it works fine – the method is the same on any bike. Wiring/routing the wires might be a bit fiddly but well worth the effort for peace of mind. The heavy current comes direct from the battery and the relay live is just to switch the circuit on and off. If you have grips wired directly to the battery already, you can still insert this cheap mod any time.  If you have other appliances ( GPS, heated gloves etc) you can wire these into the same relay using a simple distribution block.
Have fun!
PostSubject: Re: Fitting a relay for heated grips.   Fitting a relay for heated grips. Icon_minitimeTue Nov 24, 2015 10:47 pm
Cheers John Fitting a relay for heated grips. 3498837457 Deffo going to do this on Tom's scooter Fitting a relay for heated grips. 433968
PostSubject: Re: Fitting a relay for heated grips.   Fitting a relay for heated grips. Icon_minitimeWed Nov 25, 2015 8:53 pm
Very good post Sir, one for my list.
PostSubject: Re: Fitting a relay for heated grips.   Fitting a relay for heated grips. Icon_minitimeWed Nov 25, 2015 10:32 pm
Very helpful that John, cheers Fitting a relay for heated grips. 3005623951Fitting a relay for heated grips. 3005623951
PostSubject: Re: Fitting a relay for heated grips.   Fitting a relay for heated grips. Icon_minitimeWed Nov 25, 2015 11:07 pm
Glad it's of help guys! I used to have a bike with grips wired direct to the battery and always remembered to turn the switch off when I parked. One day from across the road I saw a dad and his lad admiring my bike close up. When I got there they had gone. At first I was chuffed and then I realised the little perisher had pressed one of the switches (the R&G ones have 3) and could not work out how to turn the unit off so left it on! Made me realise I might be asleep all night sometime in warm weather, not realising the battery was being discharged due to someone fiddling! That's what prompted me to fit a relay.
PostSubject: Re: Fitting a relay for heated grips.   Fitting a relay for heated grips. Icon_minitimeWed Nov 25, 2015 11:10 pm
Good find John!  Fitting a relay for heated grips. 184121345
PostSubject: Re: Fitting a relay for heated grips.   Fitting a relay for heated grips. Icon_minitimeThu Nov 26, 2015 6:42 pm
Good shout John, simple ideas are always the best. Fitting a relay for heated grips. 3005623951 Fitting a relay for heated grips. 2170595768
mally
mally
PostSubject: Re: Fitting a relay for heated grips.   Fitting a relay for heated grips. Icon_minitimeThu Nov 26, 2015 6:56 pm
nice one john ive learnt something
» Has Anyone Fitted Heated Grips
» Starting problems/Relay?
» Symtec Heated Grips Fitted To VZ800
» LED Flasher relay problem?
» Starter Control Relay
Fitting a relay for heated grips. Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Fitting a relay for heated grips. Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Fitting a relay for heated grips. Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Fitting a relay for heated grips. Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Fitting a relay for heated grips. Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Fitting a relay for heated grips. Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Fitting a relay for heated grips. Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Fitting a relay for heated grips. Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Fitting a relay for heated grips. Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Fitting a relay for heated grips. Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Fitting a relay for heated grips. Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Fitting a relay for heated grips. Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Fitting a relay for heated grips. Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Fitting a relay for heated grips. Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Fitting a relay for heated grips. Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Fitting a relay for heated grips. Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Fitting a relay for heated grips. Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Fitting a relay for heated grips. Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Fitting a relay for heated grips. Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Fitting a relay for heated grips. Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
