 Brake light not working.
5 posters
>>ozzy<<
>>ozzy<<
Brake light not working. Empty
PostSubject: Brake light not working.   Brake light not working. Icon_minitimeSun Jul 31, 2016 7:48 pm
My C800's brake light turns on only by pressing rear brake pedal. Front brake doesn't turn it on. Fuses were changed – every single one – but problem remained. Have anyone experienced the same issue? Thanks for your help.
PostSubject: Re: Brake light not working.   Brake light not working. Icon_minitimeSun Jul 31, 2016 8:00 pm
sticky switch on the front brake lever? does it make a clicking sound when you pull the lever?
>>ozzy<<
>>ozzy<<
PostSubject: Re: Brake light not working.   Brake light not working. Icon_minitimeSun Jul 31, 2016 8:14 pm
I'm not sure at the moment. Tommorow I'll check. I just remembered that horn not working too. Could it be related?
hmac
hmac
PostSubject: Re: Brake light not working.   Brake light not working. Icon_minitimeSun Jul 31, 2016 8:41 pm
Open the switch and give it a spray of ACF50 or WD 40. Fixed mine and cost pennies to try.
PostSubject: Re: Brake light not working.   Brake light not working. Icon_minitimeSun Jul 31, 2016 8:47 pm
I would re-check the fuses if the horn is out as well .... you might have a chaffed cable somewhere causing the problem. Otherwise, as Sim says, likely to be a sticking switch - worth stripping the switch housing down & cleaning out with WD40 or similar as Hmac advised.
>>ozzy<<
>>ozzy<<
PostSubject: Re: Brake light not working.   Brake light not working. Icon_minitimeMon Aug 01, 2016 6:05 pm
QUICK UPDATE: There is "click" sound when pulling front brake lever. WD-40 not applied yet – I'm still at work now.
All fuses have been replaced by brand new ones.
Few days ago, horn made some very short ¼ second silenced beep when I pressed the button. Since then not even that.
PostSubject: Re: Brake light not working.   Brake light not working. Icon_minitimeTue Aug 02, 2016 2:45 am
Had a quick look at the wiring diagram - looks like the horn / front & rear brakes  / speedo, all work off the same fuse (sure someone will confirm/dispute that), so I'd be inclined to look elsewhere if the rear brake lights up & the speedo works.
 Pop a test light into the feed wire to make sure you're getting juice to the horn.  Then run a feed direct to the horn to make sure that's actually working.  Open the switchgear & have a look at the condition of the switch - they can fry.  If it looks dirty, spray some brake cleaner around the contacts.
I'd agree with the others, the brake side certainly sounds like the switch is gummed up - be a cheap fix.
Keep us updated with progress
>>ozzy<<
>>ozzy<<
PostSubject: Re: Brake light not working.   Brake light not working. Icon_minitimeTue Aug 02, 2016 7:55 pm
Thank you all for you effort & valuable tips – the brake light does its job again! Brake light not working. 433968 I only cleaned the switch under the front brake lever and sprayed it by WD-40.
>>ozzy<<
>>ozzy<<
PostSubject: Re: Brake light not working.   Brake light not working. Icon_minitimeTue Aug 02, 2016 8:04 pm
About the horn issue – I tried "the WD-40 hack" on a horn button. It was a quick action after work. I didn't have enough time to clean horn either to spray every connector relevant to it. Nevertheless, it started to make that silenced short sound again. Maybe it needs to be cleaned to, am I wrong?
PostSubject: Re: Brake light not working.   Brake light not working. Icon_minitimeWed Aug 03, 2016 12:30 am
You won't know for certain till you ascertained that the horn is working.  Once you know the horn's working, you can work your way back
» My brake light works, but my tail light does not function..
» Horn Not working on M800
» flashing brake light for Suzuki C800 / M800
» Horn on M800 stopped working
» water temp light and ignition light
Brake light not working. Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Brake light not working. Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Brake light not working. Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Brake light not working. Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Brake light not working. Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Brake light not working. Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Brake light not working. Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Brake light not working. Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Brake light not working. Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Brake light not working. Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Brake light not working. Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Brake light not working. Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Brake light not working. Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Brake light not working. Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Brake light not working. Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Brake light not working. Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Brake light not working. Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Brake light not working. Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Brake light not working. Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Brake light not working. Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
