| | NEED HELP WITH A BIG PROBLEM!!! | |
marolvillano Prospect
![marolvillano](https://2img.net/u/2611/31/42/84/avatars/2544-20.jpg)
![NEED HELP WITH A BIG PROBLEM!!! Empty](https://2img.net/i/empty.gif) | Subject: NEED HELP WITH A BIG PROBLEM!!! Tue Oct 11, 2016 4:58 pm | |
| Hi! I'm a beginner with bikes. I have a '97 vx800 and i changed my battery... I asked my dad to install it but he installed it incorrectly, he placed the wires in the wrong way, causing the fuel pump wires toasted. my bike doesn't have a fuse box so now i'm not sure if my CDI, Rectifier, alternator and Ignition coils are still working. can anyone help? you think those parts are still working? | |
![NEED HELP WITH A BIG PROBLEM!!! Empty](https://2img.net/i/empty.gif) | Subject: Re: NEED HELP WITH A BIG PROBLEM!!! Thu Oct 13, 2016 3:14 am | |
| Is your bike a standard bike ? If so, unless someone has really gone to town on the wiring, it will have a fuse box somewhere - you just need to find it. Can you post some picturs of the damage ? | |
| ![Go down](https://2img.net/i/empty.gif) | | pazderski Member
![pazderski](https://2img.net/u/2611/31/42/84/avatars/2692-82.png)
![NEED HELP WITH A BIG PROBLEM!!! Empty](https://2img.net/i/empty.gif) | Subject: Re: NEED HELP WITH A BIG PROBLEM!!! Wed May 24, 2017 4:16 am | |
| look under the seat, or one of the side panels, they may come off look for something with a cover over it, and on most of my bikes if you can locate the starter solenoid it should be rite around that area | |
| ![Go down](https://2img.net/i/empty.gif) | | v-twin Very Valued VIP Member
![v-twin](https://2img.net/u/2611/31/42/84/avatars/1567-4.jpg)
![NEED HELP WITH A BIG PROBLEM!!! Empty](https://2img.net/i/empty.gif) | Subject: Re: NEED HELP WITH A BIG PROBLEM!!! Wed May 24, 2017 7:39 am | |
| The fuse box is under the seat, if it's missing then as katsd has already said someone has butchered the wiring, in which case, you could have done a lot of damage. Post up some photo's of the wiring loom and of under the seat and we will can then see whats what. | |
| ![Go down](https://2img.net/i/empty.gif) | | stingray Very Valued VIP Member
![stingray](https://2img.net/u/2611/31/42/84/avatars/1426-37.jpg)
![NEED HELP WITH A BIG PROBLEM!!! Empty](https://2img.net/i/empty.gif) | Subject: Re: NEED HELP WITH A BIG PROBLEM!!! Wed May 24, 2017 2:30 pm | |
| I find it difficult to believe that anyone would be daft enough to by-pass the fuse box so heres hoping you find it, having said that your fuel pump wasn't protected by a fuse which it should have been, good luck m8, I hope you get it sorted with as little trouble as possible. | |
![NEED HELP WITH A BIG PROBLEM!!! Empty](https://2img.net/i/empty.gif) | Subject: Re: NEED HELP WITH A BIG PROBLEM!!! ![NEED HELP WITH A BIG PROBLEM!!! Icon_minitime](https://2img.net/i/fa/icon_minitime.gif) | |
| ![Go down](https://2img.net/i/empty.gif) | | | NEED HELP WITH A BIG PROBLEM!!! | |
Latest topics | » Hello
» Howdy
» VZ 800 K7
