 Weak spark
2 posters
smitty3855
smitty3855
Weak spark Empty
PostSubject: Weak spark   Weak spark Icon_minitimeFri Apr 14, 2017 2:28 am
Hey guys I have a problem I cant figure out. My 03 Marauder vz800 has weak spark from both coils, crank it over and spark real weak and then sometimes it will throw a good spark and then back to weak. I have checked connections , put new AGM battery in , new plugs. Could the CDI be bad? I hope not $ Any ideas? Thanks.... Tim
hmac
hmac
Weak spark Empty
PostSubject: Re: Weak spark   Weak spark Icon_minitimeFri Apr 14, 2017 8:10 am
Always try the cheap stuff first. Could be the coils, check them with an ohmeter, check across positive and negative terminals (Primary) should be be from 2 - 6 ohms. Then check from either positive or negative to the plug lead out (secondary) should be between 15 and 30 K- ohms. Hope it's not CDI.
smitty3855
smitty3855
Weak spark Empty
PostSubject: Re: Weak spark   Weak spark Icon_minitimeSun Apr 16, 2017 12:29 am
coils check good. signal coil or pulser coil in side case with stator ohms 178. I read its supposed to be between 170-280 ohms but it was only 40 degrees f when I tested it. My experience with CDI over the years is they work or not, but mine will throw a good spark sometimes. But I don't know what else it could be. Tim
Weak spark Empty
Weak spark
» no spark
» No Spark !
» No spark on 1 cylinder
» Spark plug Cap
» Spark on one cylinder issue.
Weak spark Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Weak spark Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Weak spark Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Weak spark Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Weak spark Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Weak spark Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Weak spark Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Weak spark Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Weak spark Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Weak spark Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Weak spark Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Weak spark Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Weak spark Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Weak spark Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Weak spark Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Weak spark Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Weak spark Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Weak spark Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Weak spark Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Weak spark Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
