 Home grown light bar install C50T
pledge
Farmboy
9 posters
Farmboy
Home grown light bar install C50T Empty
PostSubject: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeSat Oct 22, 2011 7:37 pm
After seeing how others have done their light bars with threaded rod and a few nuts, I thought I'd give it a try. This part will only be the physical install, I'll wire it soon.
Here's what I'm working with: 2 Grote security lights, nicely chrome plated and complete with 2-piece mounts. I also bought a few assorted nuts and washers. The hardware came to $4.00, the lights were around $24.00 each. The light on the left is turned around to show how the mount is attached.
Note also there's only a single wire. It's the power one. Ground (earth) is by mechanical connection.
Home grown light bar install C50T ORBMKejbVCQdjR3VuFLATrvOqEdPUohH
The first thing to do is remove the headlight shell, two screws does it. Disconnect the headlight plug then remove the nut holding each turn signal stalk. When you do this, put a piece of tape on one set of wires (there are two sets per turn signal) when you diisconnect the first signal. If not you run the risk of hooking up backwards eg: right is left, left is right. Minor annoyance but avoidable. Sorry for the blur, but I think you can pick out the greyish duct tape on the two wires.
Home grown light bar install C50T TaJ0v0PgDgGujpmjUBuNT0K6G0V2M9LE
The next thing was to check out the mount. Note that there is a slight hump to this. The idea being if you use this lower part (as I am), you tighten this down and the tension keeps it there. Nice idea, but not workable for this install as the turn signal is going vertical thru this hole. Home grown light bar install C50T LTosKHNQm6tAH4pTmqpC8O0sq0boHSiQ
Notice in the following two photos how it interferes with the nut/signal shaft before flattening. The second photo shows how it fits with no interference after a few surgical whacks with the 2 lb persuader...
This one shows how the bolt (photo purposes only as I'm using threaded rod of the same diameter) interferes with the nut
Home grown light bar install C50T LHf7amwOo1m5apNEKTGkjUaaRgpEJeqN
This shot is after flattening the mount. It now fits snugly even with the kit supplied spacer installed.
Home grown light bar install C50T DNeirUvOgET2IcmLFA53u5QT5ki85eKR
...another view
Home grown light bar install C50T UmBsNQ3F0wN2bLVdBAcmvBDt6dFGUmFh
This is a mockup of how it's going to look on the front of the bike. Note it will mount vertically. I"ll post more when I get it attached to the front of the motorcycle. Comments/observations welcome.
Home grown light bar install C50T GnQdbDn7HpwjED7OwN5A3pFTIdTMhOT2
The install is going to proceed from left to right. Note the threaded rod (3/8") is left it's full length to be cut later. I've calculated thru trial and error that 7 3/4" out from outside of the turn signal mount is the right length for me. It gives me a small but adequate clearance between the turn signal and fork tube.
Home grown light bar install C50T NroIQfmpgF3EkfaGBF6HS7lD6nwn4eJN
A little detail is in order. Note that I'm using a 2" coupling nut, jammed with a regular 3/8" hex nut. This coupler nut is not necessary as 2 - 3/8" nuts will do the same job, but massive impresses me. I saw this done on another thread and think it's a good idea. On the other
side of the signal mount are three regular 3/8" hex nuts jammed against the mount. They measure out to 1" wide. I could have used a coupling
nut, but if 1 is good, 3 must be better! It's barely noticeable. I'll probably cover it with a small piece of wire loom to complete the look.
After this 1" of nuts are the additional 6 3/4" that make up the rest of the light/signal mount with washers applied at all mating nut/surfaces. A 3/8" chrome acorn nut finishes off the end piece.
Home grown light bar install C50T RDsbTRi6NiIIW56bewoHfase2kwQjQwu
Here is the mount in it's finished form. I used a hacksaw to cut the rod to the same length as the other side so all should match up. Looking at
one side from the inside out it goes (for both sides):
3/8" nut - 2" coupler nut - 3/8" washer - signal mount - washer - 3 3/8" nuts - washer - light mount - kit spacer - light mount - washer - acorn nut = 7 & 3/4".
Home grown light bar install C50T KGR9M9f7WariD6AqLfi5VJU740TFWoFT
The finished mechanical install. Wiring is next.
Home grown light bar install C50T Sb69RmCeOM83lcMqKbHuA1mfeBQJsgdc
Home grown light bar install C50T FMcBuB1lVmioMWadu1SFLFHKO5g2Dsfp
Home grown light bar install C50T E6RHnFEtge09MKnE7rqwGKagbnwtLrVl
See the attached drawing and additional photos. The drawcard to this type of light is the shallowness at the back as it doesn't interfere with any part of the windscreen. Incidentally, www.grote.com has a European site.
The light is part 64111, 35 watts. I'e included a couple of extra photos to show the rear clearance and mount assembly.
Home grown light bar install C50T URIFv3OquDWdUlBIMEVvSDs5NAnSTa9u
Home grown light bar install C50T EraPtdss5AERmkjPR5Dav5pDd5GqOolV
Home grown light bar install C50T U0saERHmk3UmlvltG47FK9QbNdm5Athr
Home grown light bar install C50T SpiD2qpIColhRMP8uO3bnSN8rJCwBUDu
I got a start on the wiring this evening, here are a couple of photos. Firstly, the components: Electrical connectors, 16g wire, relay, fuses and weatherproof inline fuse carrier.
Home grown light bar install C50T SVPueMa58bA0WGtf3IMJp3l6Q1cKffoW
I didn't see the need to remove the tank completely so I simply removed the passenger/rider seats and propped up the tank with a small can of
dubious contents...
Home grown light bar install C50T Ft1DiwwPiM2qr7ETQ40O5oGNkSvS8JnD
The only lead down here will be to the positive side of the battery leading to the relay. All I have connected are two negative leads for the cruise control. Even if I decide to ground the lights to the battery there should be no problems.
Home grown light bar install C50T Ouhq9IfvjKdhhdhvji38b2DPPmlIwLQF
This is the inline fuse holder. From what I've read on different sites, when coming off the battery, fused power lines should have the fuse as close to the battery as possible -- or practical. I've installed a round connector for the pole.
Home grown light bar install C50T COOt0DbaEm4hTUcuBv7ievTq8F1kWChI
The light baronly requires a spst (single pole single throw)relay, note that I'm using a spdt (double throw). It's no big deal. All it means is that I have the option of connecting two devices using post 87 and 87A. 87A is a closed circuit when no power is being applied. Don't use that connector and its essentially a spst. Can't think of any use for it, maybe switched led's when the key is off? Why do I have this type?
Didn't pay attention when I bought it. Guilty.
Home grown light bar install C50T K9wNGKSJjWL2T0JNKSKL7VJrWpBTO8JJ
The process of wiring up the lights is pretty straightforward -- even for me -- with one small exception. I wanted the lights interrupted during start up, same as the headlight so all current goes to the starter and is not shared by the lights. I found a very long, oft times very confusing thread(s) that all had their arguments/ideas/repetitions.
Eventually, I found that the wire required is a yellow one with a white stripe. This one in particular is in a rubber sleeve leading to a large yellow plastic connector from the left side of the handlebar, not too hard to find. As this photo shows, all I did was use a scotch-lock connector. I put a connector on the other wire to connect to the relay.
Everything worked fine.
Home grown light bar install C50T WeP9jomJKjaIRjARqmRHjUwqddQs7Que
I did not follow go back to battery for ground. It's probably good practice but it works fine this way too, at least for me. I used the ground for the relay switch from the oem white connector that's in the headlight shell. Use the black wire with white stripe if you do. So
why not use the connector directly to power your lights and forget about relays? I found a whole lot of posts that made reference to all the
current going thru the ignition switch and that it would eventually cause it to fail. Good enough for me. This explains the power coming directly from the battery.
My memory for number retention is poor (I had a real good time in the 70's) so I write things down. When it came to the relay, the embossed numbers were not super visible so I wrapped a piece of duct tape around the relay and wrote the contact numbers of the side. Made life a little easier.
Home grown light bar install C50T SclVtqwnlGst0k2qqvN1u8suESAlKDvE
So without further ado, here's how i wired my lights: 1) I connected the fused power wire from the battery to post #30. 2) The interrupt wire coming from the yellow wire/white stripe connects to post #86. 3) I connected the ground from the white aux connector in the headlight shell to post #85. I did not go back to the battery and did not wire the lights to ground. 4) I joined the two power leads from the two lights together and connected to post #87.
And this is how it ended up...
Home grown light bar install C50T DcAR0TUmreqWWN5DS1PwnEARDt4S54b4
thanks for looking in. Hope it was of interest. Comments and observations welcome.
pledge
pledge
PostSubject: Re: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeSat Oct 22, 2011 7:58 pm
So far so good interested in seeing the finished item.Home grown light bar install C50T 184121345
PostSubject: Re: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeSun Oct 23, 2011 9:35 am
Brilliant write up as usual Farmboy Home grown light bar install C50T 1237024881
What size are the lights you have used are they the 5.25" ones?
We don't have Grote in the UK so knowing the size of them may help others choose an appropriate sized alternative.
pledge
pledge
PostSubject: Re: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeSun Oct 23, 2011 4:19 pm
They look great very good job.
PostSubject: Re: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeSun Oct 23, 2011 7:10 pm
What a great idea & how incredibly cheap that is compared to a shop bought one Home grown light bar install C50T 103551
I think when the price is taken in to consideration you have/are doing an excellent job as it looks great Home grown light bar install C50T 1710857839
PostSubject: Re: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeMon Oct 24, 2011 11:27 pm
Excellant write up and job,well done.
nigj
nigj
PostSubject: Re: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeThu Oct 27, 2011 4:43 pm
Nice pice of work, looks good as well. I might use your idea on my own bike. Have to admit that those lights makes a great improvement when it comes to the bikes appearance.
Nils G Home grown light bar install C50T 2170595768
Farmboy
PostSubject: Re: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeThu Oct 27, 2011 10:44 pm
Thanks for the nice words everybody. For the record, I don't claim originality. This mod is a merging of two or three threads using ideas from each. Just thought it'd be nice for this site to have a 'home' build like this to go along with any internet links. I'll hopefully get the relay/wiring done by the weekend.
PostSubject: Re: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeSun Oct 30, 2011 3:25 pm
The responses below Farmboys instructions on this mod that are above this but below the post will be slightly out of sinc as I have cut the various posts that make up Farmboys instructions and put it all together as one continuing post
PostSubject: Re: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeSun Oct 30, 2011 3:27 pm
Brilliant writeup Farmboy from the very start to the finish and very handy to know how you wired in to the headlight for maximum power to the starter during startup. Looks Brilliant, very well don, a credit to you Home grown light bar install C50T 276246
pledge
pledge
PostSubject: Re: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeSun Oct 30, 2011 5:11 pm
Great job and write up from start to finish.Home grown light bar install C50T 184121345
Farmboy
PostSubject: Re: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeWed Nov 02, 2011 11:11 pm
Having used the light setup for a few days I offer the following adjustments that I will be applying to this build/mod. Though I don't require it, in order to effect horizontal aiming of the lights in this particular type of setup, the next time I would grind or file an oval shape to the holes where the rod goes thru the light mounts...just as a precaution so I'm not potentially blinding oncoming traffic. Secondly, I will be installing an on/off switch to allow me manual control. As wired right now, they are on when the bike is on (except for startup). My thought is to install it out of sight on the bottom of the PAIR valve cover, a low profile on/off round rocker. That way, if I ever remove the lights, the switch will be out of sight and she'll look stock. I saw a bat handle switch mounted on the rear of the headlight shell. No thanks. It would always be on, but could be switched off for whatever reason.
PostSubject: Re: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeTue Nov 08, 2011 3:40 pm
Very clever mod Farmboy, well explained and detailed Home grown light bar install C50T 276246 Home grown light bar install C50T 2170595768
lkwdc50b
Newbie
lkwdc50b
PostSubject: Re: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeMon Nov 21, 2011 9:13 pm
Nice write up, planning on this for upcoming mod. Thanks!
PostSubject: Re: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeMon Nov 21, 2011 9:32 pm
Impressive Home grown light bar install C50T 2170595768
toddh01
toddh01
PostSubject: Home grown light bar install C50T   Home grown light bar install C50T Icon_minitimeTue Sep 18, 2012 6:48 pm
Farmboy, thanks for such a detailed post. I just completed the light bar on my 2006 C50T. It came out perfect and saved me a bunch of $$. Keep up the great work and thanks again.
»  New LED Rear Light & Break Light Idea
» Brake light modulator on C50T
» Screen Mounted Spot Light Project on C50T
» Home built spot light bracket with measurements. Suzuki M50 / M800
» My brake light works, but my tail light does not function..
Home grown light bar install C50T Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Home grown light bar install C50T Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Home grown light bar install C50T Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Home grown light bar install C50T Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Home grown light bar install C50T Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Home grown light bar install C50T Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Home grown light bar install C50T Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Home grown light bar install C50T Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Home grown light bar install C50T Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Home grown light bar install C50T Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Home grown light bar install C50T Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Home grown light bar install C50T Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Home grown light bar install C50T Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Home grown light bar install C50T Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Home grown light bar install C50T Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Home grown light bar install C50T Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Home grown light bar install C50T Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Home grown light bar install C50T Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Home grown light bar install C50T Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Home grown light bar install C50T Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
