 Oil pressure guage...
4 posters
CanadianCruiser
CanadianCruiser
Oil pressure guage... Empty
PostSubject: Oil pressure guage...   Oil pressure guage... Icon_minitimeWed Jun 25, 2014 2:39 am
Hey guys, I've seen some add an oil Temp gauge but what about an Oil Pressure?  Has anyone done this? if so could an electronic aftermarket one for a car work?
CanadianCruiser
CanadianCruiser
PostSubject: Re: Oil pressure guage...   Oil pressure guage... Icon_minitimeMon Nov 10, 2014 4:49 pm
bump
PostSubject: Re: Oil pressure guage...   Oil pressure guage... Icon_minitimeMon Nov 10, 2014 5:08 pm
Hi CC, I'm not sure on the electronic version because you have to drill and thread a hole in the engine casing for a Boss to be situated? You could utilise the oil filler hole with a blank plug drilled and threaded to take a pressure gauge similar to this? Maybe someone else will chip in with idea's?
Oil pressure guage... 26271d1234118253-direct-mount-oil-pressure-gauge-e22120117
Oil pressure guage... OIL_PRESSURE_GAUGE
CanadianCruiser
CanadianCruiser
PostSubject: Re: Oil pressure guage...   Oil pressure guage... Icon_minitimeMon Nov 10, 2014 5:34 pm
hmm..  ok I was thinking maybe even fit a "T" on the OEM sensor and run a line from there...
PostSubject: Re: Oil pressure guage...   Oil pressure guage... Icon_minitimeMon Nov 10, 2014 7:16 pm
I'm no expert but surely the crankcase ( if thats the right terminology ) or sump will not be under oil pressure ?
I  would of thought oil pressure would be measured at the oil pump outlet ( someone tell me if I'm talking bollocks )
CanadianCruiser
CanadianCruiser
PostSubject: Re: Oil pressure guage...   Oil pressure guage... Icon_minitimeMon Nov 10, 2014 8:41 pm
according to the FSM "check the oil pressure in the following manner."
o Remove the main oil gallery plug.
o lnstall the oil pressure gauge with adaptor in the position shown in the figure
So short of installing a fitting in the Main plug and running a line from there I think the only other option would be where the OEM sender is... same as you would do it in a car...
PostSubject: Re: Oil pressure guage...   Oil pressure guage... Icon_minitimeFri Nov 14, 2014 7:33 pm
An oil pressure gauge seems like work for the sake of work, could be wrong tho I spose
CanadianCruiser
CanadianCruiser
PostSubject: Re: Oil pressure guage...   Oil pressure guage... Icon_minitimeFri Nov 14, 2014 8:08 pm
Not really... I've installed them countless times in cars (Mechanical & Electrical).. It's a fairly simple job.  Hardest part is finding a good spot to tap into.  Found a nice spot, right under the oil filter there is a journal that's just plugged by a bolt.  Remove that bolt and put the line in there.
I personally like the idea of having it.. a lot less work then having to check pressure when there's something wrong (FSM says to connect gauge to main oil drain plug hole costing you $$$ for new oil)
I'll be starting a new thread soon with some of the mods I'm doing along with pics so you can see. (just painted the front rim yesterday lol)
PostSubject: Re: Oil pressure guage...   Oil pressure guage... Icon_minitimeFri Nov 14, 2014 9:09 pm
That's a good enough reason  Oil pressure guage... 3498837457 I'll look forward to your write up
» fuel guage probs
» oil pressure and temperature of VX 800
» VX800 Tyre Pressure
» Oil pressure gauge & test port
Oil pressure guage... Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Oil pressure guage... Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:38 am
Oil pressure guage... Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Oil pressure guage... Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Oil pressure guage... Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Oil pressure guage... Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Oil pressure guage... Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Oil pressure guage... Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Oil pressure guage... Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Oil pressure guage... Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Oil pressure guage... Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Oil pressure guage... Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Oil pressure guage... Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Oil pressure guage... Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Oil pressure guage... Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Oil pressure guage... Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Oil pressure guage... Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Oil pressure guage... Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
Oil pressure guage... Icon_minitimeby flying1 Wed Jul 31, 2024 1:59 pm
Oil pressure guage... Icon_minitimeby gary,, Fri Jul 12, 2024 2:30 pm
