| Completing stage 1 with K&N air filter | |
Rattler Valued Member
| Subject: Completing stage 1 with K&N air filter Mon Feb 20, 2012 8:57 pm | |
| Hey all. Sorry it's been a while.
I'm wanting to complete my Stage 1 by adding a K&N air filter. Just wondering if any.if you have noticed a big difference in fuel consumption ay all?Cheers. | |
| Subject: Re: Completing stage 1 with K&N air filter Mon Feb 20, 2012 10:25 pm | |
| Hi Rattler must admit have not really noticed,if anything I would of thought it would of gone up a bit,bear in mind I have a fuel processor as well which makes the bike run a bit richer,hope this helps. | |
| Subject: Re: Completing stage 1 with K&N air filter Mon Feb 20, 2012 11:03 pm | |
| Yeah I have a Power Commander which was fitted with the Straighshots. Cheers. | |
| Subject: Re: Completing stage 1 with K&N air filter Tue Feb 21, 2012 9:07 am | |
| It all relative, by adding the K&N you will be increasing the the potential of the engine and exhaust system to run better at the point that the power commander has been adjusted! From there on in its all down to your wrist, and whether you are tapping in to the power increase. No one single mod will add a lot to the power of the bike or the fuel that it uses but a bike that has exhaust, FI controller & K&N will have a definite power increase and potential for extra fuel to be used over the stock bike. I use copious amounts of fuel but I ride the bike within the peak power range most of the time, I am not very good at plodding along.
Might be worth thinking about adding a "Timing Retard Eliminator" as well! | |
| Subject: Re: Completing stage 1 with K&N air filter Tue Feb 21, 2012 12:27 pm | |
| Been trying to find out exactly what the TRE does but can't find much on it. I found a GiPro one but it comes with a gear indicator. Are they available without?
| Subject: Re: Completing stage 1 with K&N air filter Tue Feb 21, 2012 1:41 pm | |
| Yes they are available without a gear indicator, I have a "Healtech X Tre ST-01" fitted to my bike. Its called a TRE because your bike runs from the factory with the timing retarded Basically what the t.r.e. does is it bypasses some of the restriction placed on a lot of modern bikes in part due to emission laws It gives a smother throttle response Improves full throttle response and acceleration Removes top speed limiter Simple operation that works out of the box works with or without tuning modules Installs in about 30 minutes | |
| Subject: Re: Completing stage 1 with K&N air filter Tue Feb 21, 2012 7:13 pm | |
| Where did you get yours from? | |
| | | CycleBiker Member
| Subject: Re: Completing stage 1 with K&N air filter Tue Feb 21, 2012 8:16 pm | |
| Here's the powerband for, I think, an M800: | |
| Subject: Re: Completing stage 1 with K&N air filter Wed Feb 22, 2012 4:10 am | |
| I got mine direct from Healtech nearly two years ago but they now have an on line retailer selling for them. I think you can get them from else where as well but I have never looked. They do not list the M or C 800 for the one without the gear indicator but it is definitely Xtre ST01 that you need if no gear indicator is required. I emailed there tech guy Norbert earlier today in Hungary to ask him why they are not listed for the bike with the gear indicator not required and he said he will update the list as it was a mistake on the site. | |
| Subject: Re: Completing stage 1 with K&N air filter Wed Feb 22, 2012 7:23 am | |
| Thanks for that mate. I'm considering getting one. Do you notice muhich difference? | |
| Subject: Re: Completing stage 1 with K&N air filter Wed Feb 22, 2012 2:31 pm | |
| I would say that all the mods make a difference, none make a massive difference but they all make a difference. I test road a brand new bog standard C800 from the retailer after I had installed the Vance & Hines Cruzers, FI Module, K&N Filter and the TRE out of curiosity to see the difference properly as its kind of hard to judge from memory as you install extras. My bike with all 4 mods done, blew the stock bike away, simple as that! | |
| Subject: Re: Completing stage 1 with K&N air filter | |
