| Temp Light | |
Anarchy2007 Newbie
| Subject: Temp Light Tue Nov 12, 2024 4:19 pm | |
| Hi guys, I have the strangest issue. The temp light on my 2007 Intruder 800 kinda flickers on and off after about 5 min of riding (long before the fan comes on)/ It doesn't stay on and the flickering goes off after a minute or two of riding. If I stop it will start again a minute or two in and stop again after a minute or so. I then stays off for the duration of the ride. I have done the following: - Flushed Radiator numerous Times - Replaced Temp Sensor - Replaced Thermostat - Replaced FAN Switch - Replace Water Pum pump - Replaced Oil Pump - Re did valve clearances - Redone Carbs, main jets 130 / 135, pilot jets 40 / 45 (original front main jet was only 90) - Checked the wiring (Used a 100 OHM Pot on the sensor connector, the TEMP light flickers at around 38 OHMS and stays on solid at around 30 Ohms)
I just can find the issue. Anyone have some advice please?
Last edited by Anarchy2007 on Tue Nov 12, 2024 4:22 pm; edited 1 time in total (Reason for editing : extra info) | |
| | | | Temp Light | |
