 Removing Oil Filter The Wrong Way On An M800
6 posters
Guest
Guest
Removing Oil Filter The Wrong Way On An M800 Empty
PostSubject: Removing Oil Filter The Wrong Way On An M800   Removing Oil Filter The Wrong Way On An M800 Icon_minitimeMon Mar 19, 2012 10:17 pm
I was struggling to take my oil filter off so i did as i have many times before , hammered a screw driver through it to twist it off...
Removing Oil Filter The Wrong Way On An M800 Imag0117
not the best idea granted...but to make things worse a damaged the thread and had to get the tap an die out...what a tit Removing Oil Filter The Wrong Way On An M800 937231058
Removing Oil Filter The Wrong Way On An M800 Imag0118
learn by others mistakes.
PostSubject: Re: Removing Oil Filter The Wrong Way On An M800   Removing Oil Filter The Wrong Way On An M800 Icon_minitimeMon Mar 19, 2012 11:07 pm
Crickey that's a bummer, lucky you were able to fix the thread.
That's the only way I have ever got them off do I guess I have been lucky in the past, because I just would never have given a second thought to where I was hitting the screw driver in to.
PostSubject: Re: Removing Oil Filter The Wrong Way On An M800   Removing Oil Filter The Wrong Way On An M800 Icon_minitimeMon Mar 19, 2012 11:24 pm
Next time I change my filter I'm gonna fit one of these.... (ps... do them in chrome too!)
http://www.knfilters.com/wrenchoff_oilfilter.htm
Guest
Guest
PostSubject: Re: Removing Oil Filter The Wrong Way On An M800   Removing Oil Filter The Wrong Way On An M800 Icon_minitimeTue Mar 20, 2012 12:06 am
Tell me about it Crash... look how long the thread is,i was surprised it was that long, thought i had the screw driver well clear Removing Oil Filter The Wrong Way On An M800 2516569736 .i went and bought one of these http://www.ebay.co.uk/itm/TWO-WAY-OIL-FILTER-WRENCH-REMOVER-63-102mm-CAR-TOOL-/400283573142?pt=UK_Hand_Tools_Equipment&hash=item5d32c29b96
they are very good.
PostSubject: Re: Removing Oil Filter The Wrong Way On An M800   Removing Oil Filter The Wrong Way On An M800 Icon_minitimeTue Mar 20, 2012 2:29 am
Mal I know a couple of members bought up a few of the chrome ones a while back off of eBay, that's do much better with the socket attachment on them. They should all be like that as standard as that would make sense
Pete that's a good looking little tool, I bought a chain filter remover once and that was crap
pledge
pledge
PostSubject: Re: Removing Oil Filter The Wrong Way On An M800   Removing Oil Filter The Wrong Way On An M800 Icon_minitimeTue Mar 20, 2012 8:27 am
[quote="peter perfect"]I was struggling to take my oil filter off
If a bike has been serviced at a bike shop or the dealer they usually tighten it up too much.
PostSubject: Re: Removing Oil Filter The Wrong Way On An M800   Removing Oil Filter The Wrong Way On An M800 Icon_minitimeTue Mar 20, 2012 9:05 pm
I've bought one of these ... works great
http://www.ebay.co.uk/itm/MOTORCYCLE-CAR-OIL-FILTER-WRENCH-REMOVAL-TOOL-74mm-76mm-/310262109496?pt=UK_Motorcycle_Parts&hash=item483d101538
PostSubject: Re: Removing Oil Filter The Wrong Way On An M800   Removing Oil Filter The Wrong Way On An M800 Icon_minitimeTue Mar 20, 2012 11:49 pm
Another handy tool this thread is turning out to be a little gold mine
PostSubject: Re: Removing Oil Filter The Wrong Way On An M800   Removing Oil Filter The Wrong Way On An M800 Icon_minitimeFri Mar 23, 2012 11:50 am
Wow that could so easily have been a real issue, glad you sorted it so easily. K&N is what I use now, I like the fact that the socket attachment is part of the design.
ippikin
ippikin
PostSubject: K&N Oil FilTER   Removing Oil Filter The Wrong Way On An M800 Icon_minitimeTue Jun 26, 2012 3:01 pm
Just came across this thread...... been thinking which oil filter to use. Dave, do you know the K&N part number 'cos I bet
the same filter for M800 as the C800?
PostSubject: Re: Removing Oil Filter The Wrong Way On An M800   Removing Oil Filter The Wrong Way On An M800 Icon_minitimeTue Jun 26, 2012 3:29 pm
Yes mate same one.
I like the K&N filters because they have a nut on top to make fitting and extraction easy with a socket & wrench.
K&N Part number: KN-138C .... Chrome Removing Oil Filter The Wrong Way On An M800 KN-138C K&N Part number: KN-138 .... Black Removing Oil Filter The Wrong Way On An M800 KN-138
E-bay LINK
PostSubject: Re: Removing Oil Filter The Wrong Way On An M800   Removing Oil Filter The Wrong Way On An M800 Icon_minitimeTue Jun 26, 2012 9:49 pm
Little bit dearer than some filters but worth it for the piece of mind and with added bling, happy days
ippikin
ippikin
PostSubject: Re: Removing Oil Filter The Wrong Way On An M800   Removing Oil Filter The Wrong Way On An M800 Icon_minitimeWed Jun 27, 2012 12:13 am
Thank you
» Air Filter Removal M800 "Nekkid Jugs" M800
» * Removing False Swingarm for Suzuki C800 C50 M800 M50 *
» k&n air filter for 2009 onwards c50, c800..m50, m800. know made
» removing plugs
» Removing stickers
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Removing Oil Filter The Wrong Way On An M800 Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
