 How to stiffen up front forks and rear suspension
5 posters
typan
typan
How to stiffen up front forks and rear suspension Empty
PostSubject: How to stiffen up front forks and rear suspension   How to stiffen up front forks and rear suspension Icon_minitimeSat Sep 01, 2012 9:28 pm
anyone know how to stiffen up the frontforks on a vl 800 volusia is it a matter of adding more oil etc,also whats the best way to stiffen the rear suspension,i have the spanner from the tool kit but when i tried to turn it a notch or two it was really tough and with there not being much hand room i struggled to even make it move,any ideas guys.thanks in advance
PostSubject: Re: How to stiffen up front forks and rear suspension   How to stiffen up front forks and rear suspension Icon_minitimeSat Sep 01, 2012 9:50 pm
typan wrote:
....whats the best way to stiffen the rear suspension,i have the spanner from the tool kit but when i tried to turn it a notch or two it was really tough and with there not being much hand room i struggled to even make it move,any ideas guys.thanks in advance
I find the best way to lever the pre-load spanner is with a short bit of pipe slipped over the spanner to lengthen it and get more leverage.
PostSubject: Re: How to stiffen up front forks and rear suspension   How to stiffen up front forks and rear suspension Icon_minitimeSun Sep 02, 2012 12:44 am
your best bet is remove the battery and box then it's not to bad How to stiffen up front forks and rear suspension 3498837457
typan
typan
PostSubject: Re: How to stiffen up front forks and rear suspension   How to stiffen up front forks and rear suspension Icon_minitimeMon Sep 03, 2012 7:01 am
thanks bluesman an simbo i did what you said and it made it very easy,also changed the coolent at the same time,thanks for the advice.
CycleBiker
CycleBiker
PostSubject: Re: How to stiffen up front forks and rear suspension   How to stiffen up front forks and rear suspension Icon_minitimeSat Sep 15, 2012 2:11 pm
If the bike is on a lift then the rear suspension adjustment is easier to turn.
In the front forks you should not add more oil as that could cause a seal to blow but you can replace the oil with a heavier weight oil for stiffer fork action.
PostSubject: Re: How to stiffen up front forks and rear suspension   How to stiffen up front forks and rear suspension Icon_minitimeSun Sep 16, 2012 10:33 am
The only way to stiffen up the front suspention is to change the internal spacer as per the recent modification thread. LINK
» VS750 front forks
» Front Forks Sidelined My Holiday
» Rear suspension
» Leaking rear suspension
» Your rear suspension setting
How to stiffen up front forks and rear suspension Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
How to stiffen up front forks and rear suspension Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
How to stiffen up front forks and rear suspension Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
How to stiffen up front forks and rear suspension Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
How to stiffen up front forks and rear suspension Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
How to stiffen up front forks and rear suspension Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
How to stiffen up front forks and rear suspension Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
How to stiffen up front forks and rear suspension Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
How to stiffen up front forks and rear suspension Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
How to stiffen up front forks and rear suspension Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
How to stiffen up front forks and rear suspension Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
How to stiffen up front forks and rear suspension Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
How to stiffen up front forks and rear suspension Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
How to stiffen up front forks and rear suspension Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
How to stiffen up front forks and rear suspension Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
How to stiffen up front forks and rear suspension Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
How to stiffen up front forks and rear suspension Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
How to stiffen up front forks and rear suspension Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
How to stiffen up front forks and rear suspension Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
How to stiffen up front forks and rear suspension Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
