| Manifold gasket size | |
Billyz Member
| Subject: Manifold gasket size Thu Oct 04, 2012 11:41 am | |
| Does anyone know the size of the crush gasket for the header pipes? I have 2 that i have found that i didn't use from last year but not sure if they are right size. Outer diameter is 55mm inner is 45 mm. | |
| | | Billyz Member
| Subject: Re: Manifold gasket size Thu Oct 04, 2012 11:43 am | |
| Sorry everyone, its a volusia 2003! | |
| | | Billyz Member
| Subject: Re: Manifold gasket size Thu Oct 04, 2012 3:30 pm | |
| Ok, i've been out and measured the inlet on the old shortcuts, i think it's nearer 59mm. Tried finding some on the net but to no avail. However found some crush gaskets for honda at 59mm . Might give these a try. By the way the front header is defo leaking, no wonder there's a backfire. | |
| Subject: Re: Manifold gasket size Thu Oct 04, 2012 4:31 pm | |
| Sorry Bill not sure on sizing but the part number you are after is 14181-10F00. You could possibly order from HERE or pop in to your local bike shop & they will order it for you. That way you won't have to pay those silly prices. | |
| | | Billyz Member
| Subject: Re: Manifold gasket size Thu Oct 04, 2012 4:56 pm | |
| Blimey, mr I, they are expensive! Nearly £10 each plus £5 postage. But, needs must. Thanks for the info. | |
| Subject: Re: Manifold gasket size Thu Oct 04, 2012 7:58 pm | |
| Try giving wemoto a ring for a pattern part ? nothing on there website for exhaust gaskets but they'll probably have them as they'll be the same size as a different model bike. | |
| Subject: Re: Manifold gasket size Thu Oct 04, 2012 8:22 pm | |
| Had a look and they do them from 28mm up to 61mm £1.27 each plus p&p | |
| | | Billyz Member
| Subject: Re: Manifold gasket size Thu Oct 04, 2012 9:06 pm | |
| Ok, found them. Asbestos or Copper? I think asbestos, and 59mm. Cheers everyone, thanks for your help Mr I and Sim. | |
| Subject: Re: Manifold gasket size Thu Oct 04, 2012 10:12 pm | |
| Yeah Bill they're the alloy/asbestos ones like standard gaskets. | |
| Subject: Re: Manifold gasket size | |
