 Connectors under the seat - OBD?
mo800
ippikin
8 posters
ippikin
ippikin
Connectors under the seat - OBD? Empty
PostSubject: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeSat Dec 22, 2012 12:12 am
Happy Xmas everyone. Having got some time off to do some fettling (front brake overhaul and valve clearances on the cards) ...... noticed two electrical connectors doing nothing under the seat. Can anyone enlighten me what they are.... and can they be at all useful?
Thanks!
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeSat Dec 22, 2012 2:41 pm
Hi Grob can you take a photo to show us the connectors,
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeSat Dec 22, 2012 8:10 pm
I know what you mean.... when I added some LEDs I was confused by what looked like spare connectors near the battery... didnt risk using them! Could they be for diagnostics?
The plot thickens...
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeSat Dec 22, 2012 10:16 pm
Is this it?
Connectors under the seat - OBD? 2012-05-23%252014.08.06
ippikin
ippikin
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeSun Dec 23, 2012 3:53 pm
Yes!
[quote="bigmal"]Is this it?
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeSun Dec 23, 2012 4:26 pm
Here is wiring around the battery on my 07 m50/800, the main feed which sits in the recess as you can see only serves the rear cluster one connector.(white)The other connectors are what I have fitted ie:alarm spare fuses (taped on batt)I do not know were your other connectors have come from,sorry can not help on that one.
Connectors under the seat - OBD? 2012-12-23142935
mo800
mo800
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeThu Dec 12, 2013 7:34 pm
Hello did you ever find out what the plugs are for,as i have got them on my m800. wont to put a alarm on it.
Hi newbee
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeThu Dec 12, 2013 7:50 pm
I believe Suzuki uses this connector for their on board diagnostics. (OBD)?
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeThu Dec 12, 2013 8:07 pm
Looks like the diagnostic socket to me  :what1: Note to self? Must type quicker  Connectors under the seat - OBD? 1993399755
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeThu Dec 12, 2013 8:18 pm
Connectors under the seat - OBD? 852880
mo800
mo800
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeThu Dec 12, 2013 9:38 pm
cheers have a merry one.
mo800
mo800
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeThu Dec 12, 2013 9:42 pm
I thought diagnostic socket was near the ecu with a cap over it.
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeThu Dec 12, 2013 10:00 pm
The ECU is in the right side panel, I've never seen one in there? the one under the seat which is very close to the ECU has a cap over it.
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeThu Dec 12, 2013 10:10 pm
I do not remember properly now but I do remember taking a cap off of one within that panel when fitting my fuel injection module I believe?
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeThu Dec 12, 2013 10:14 pm
If you're wanting to pick up a live & neutral, see the other thead on here about the connection inside the headlamp bowl... https://www.suzuki800.com/t1916-mid-range-12v-accessory-socket-fitted
but.....  that's only live when you turn the key. if you want a permanent live, you would have to tap into the battery.   I'm sure others on here are far better qualified to offer an opinion on things like whther you should add a separate inline fuse etc....  Connectors under the seat - OBD? 1337224149
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeFri Dec 13, 2013 10:02 am
I have now spent bloody hours researching the connector under the seat and have looked at the manual & electrical map but can see nothing to give me any positive indications. I can find various information from peoples personally beliefs on what this connector is but nothing factual. I have found & read both information that agrees and disagrees with where the OBD connection is and even whether we have one or not due to the ECM's ability to self diagnose and display current error functional codes on the dash itself.
So as of right now, I am none the wiser but can actually see no benefit of an additional OBD diagnosis tool even if they were made to fit our bikes?
Johnmc800 likes this post
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeFri Dec 13, 2013 10:26 am
My OBD diagnostics:
 - does it fire? Yes
 - is it loud? Hell yes
Diagnostics complete, go for a ride.  Connectors under the seat - OBD? 852880
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeFri Dec 13, 2013 12:21 pm
Sound good to me.  Connectors under the seat - OBD? 3498837457
ippikin
ippikin
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeFri Dec 13, 2013 3:08 pm
Thanks for looking Dave. It is a real mystery! I will just have to pretend it's not there!
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeFri Dec 13, 2013 3:46 pm
I thought diagnostics tools just worked by taking a code and telling you what that code means rather than you having to look it up. Cause the Intruders have a code facility displayed as already mentioned wouldn't that be useless to have under most circumstances. I can see why a port would still be there to help mechanics that have the bike stripped down but even on a lot of cars you just get safety pin and bend it and stick one end in one hole and the other end in another hole in the massive port connection plugs they often have under the dash board somewhere to make the codes flash up. So I can see how the small plug under the seat could possibly work if it was for that with a machine to bypass the onboard display as it only require a two port or two wire connection to make it work. Still a bloody mystery tho, so common guys find out the facts rather than peoples opinions and put us out of our misery
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeFri Dec 13, 2013 4:28 pm
I'm still in the thought it's for a diagnostic tool, after 2008/09 there's no tick over screw, so having a diagnostic socket gives mechanics the ability to talk to the ECU and make adjustments to idle speed other running operations above our control, Unless you have the Healtech processor and then you can do it on your own laptop.
I'll get my shovel out and dig a little deeper lol
PostSubject: Re: Connectors under the seat - OBD?   Connectors under the seat - OBD? Icon_minitimeFri Dec 13, 2013 4:36 pm
I have emailed both Healtech and Suzuki to see if I can get a definative answer on the socket in question.
Rayh46 likes this post
» Which connectors on front indicators ?
» Mustang seat vs Saddlemen profiler seat
» New seat
» Mustang seat
» VS800 New Seat
Connectors under the seat - OBD? Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Connectors under the seat - OBD? Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Connectors under the seat - OBD? Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Connectors under the seat - OBD? Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Connectors under the seat - OBD? Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Connectors under the seat - OBD? Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Connectors under the seat - OBD? Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Connectors under the seat - OBD? Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Connectors under the seat - OBD? Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Connectors under the seat - OBD? Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Connectors under the seat - OBD? Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Connectors under the seat - OBD? Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Connectors under the seat - OBD? Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Connectors under the seat - OBD? Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Connectors under the seat - OBD? Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Connectors under the seat - OBD? Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Connectors under the seat - OBD? Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Connectors under the seat - OBD? Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Connectors under the seat - OBD? Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Connectors under the seat - OBD? Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
