 Sissy bar & panniers refix / Suzuki Intruder
6 posters
Sissy bar & panniers refix / Suzuki Intruder Empty
PostSubject: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeFri Jan 04, 2013 4:53 pm
Recently a forum member asked how I'd fitted my panniers and sissy bar to the bike, all I'd done was used longer ss dome head allen bolts and bolted through both brackets and put washers in between as spacers, Not only was this an ugly quick fix, It also made the panniers a permanent fixed to the bike as it took ages to remove them ! So today I set about fixing the Sissy bar and Panniers in a more decorative removable way, First of all I had to remove the Panniers from their brackets to gain access to the bolts,then I removed the bolts going through the Sissy Bar,brackets and mudguard, Using the same bolts I screwed them through from within the mudguard (the one nearer the front has a nut welded on the inside of the mudguard) Then tightened them back up using a ss half nut and washer to hold the Sissy bar and mudguard together.(this also acts as a spacer)
Sissy bar & panniers refix / Suzuki Intruder IMAG0111
Doing it this way enables me to leave the Panniers and Brackets fixed together
Sissy bar & panniers refix / Suzuki Intruder IMAG0110
So now I can remove or replace the Panniers within five minutes (4 nuts) instead of a good half hour,I don't often go without them but if I do I can just put the spiked chrome nut's on without panniers and it still looks ok.
Sissy bar & panniers refix / Suzuki Intruder IMAG0107
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeFri Jan 04, 2013 7:47 pm
Very clever that Sim.... hey what's going on? You seem to have FAR too much time on your hands lately for all these mods Sissy bar & panniers refix / Suzuki Intruder 852880 Sissy bar & panniers refix / Suzuki Intruder 852880 Sissy bar & panniers refix / Suzuki Intruder 852880
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeFri Jan 04, 2013 8:00 pm
Two weeks off for xmas Mal Rolling Eyes I can't wait to get back Sissy bar & panniers refix / Suzuki Intruder 852880
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeSat Jan 05, 2013 12:02 pm
Great idea change the bolts over and put them in from the inside instead of running from the outside simbo. Makes life so much easier as they are bastards to get in and out everytime when you put thing on or take things of other wise Sissy bar & panniers refix / Suzuki Intruder 184121345
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeSat Jan 05, 2013 7:06 pm
Good move Sim, I think I will do this myself.
I sometimes think about stripping the bike down a bit and taking off the sissy bar & rear seat but the thought of having to take those bolts out and put them back in more than once has stopped me from doing it as they are twats to get back in. Sissy bar & panniers refix / Suzuki Intruder 3498837457
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeSun Jan 06, 2013 4:45 pm
A good idea is to open the front two holes up,these are the ones that have the nuts welded on the inside,just a send a drill through a little bigger than the bolt, this will save a lot of hassle,when trying to thread a 80/100 mm bolt from the inside.
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeSun Jan 06, 2013 4:51 pm
Another very clever idea.... do you mean just open up the holes in the metalwork - not drilling through the welded nut too? I'm storing these tips up for when I get round to fitting my sissy bar. Sissy bar & panniers refix / Suzuki Intruder 3498837457
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeSun Jan 06, 2013 5:00 pm
You must go through the nut to take advantage of being able to just push the bolt through,instead of spending time with the rear wheel on trying to screw it in.I done this mod months ago and find it much easier,I must admit that I do also take my rear mudgaurd off now and again to clean it from the inside as well.
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeSun Jan 06, 2013 7:37 pm
OK Sissy bar & panniers refix / Suzuki Intruder 433968
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeTue Jan 08, 2013 6:42 pm
Sim where did you get those spiked nuts from mate, I want to invert the bolts myself soon & want those as they are so cool.
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeTue Jan 08, 2013 6:45 pm
I got mine from here Dave http://www.ebay.co.uk/itm/320884571583?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
But they do them at Metric cruisers as well I think Sissy bar & panniers refix / Suzuki Intruder 3498837457
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeTue Jan 08, 2013 7:10 pm
Cheers Sim, just ordered 4. Sissy bar & panniers refix / Suzuki Intruder 433968
PostSubject: re sissy bar & pannier fix   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeWed Jan 09, 2013 8:27 pm
Hi Dave thought this might be of use at some time http://www.custom-fasteners.co.uk/ they supply all kinds of nuts bolts & spares!! Sissy bar & panniers refix / Suzuki Intruder 3498837457
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeWed Jan 09, 2013 10:16 pm
Very handy link. Cheers Sissy bar & panniers refix / Suzuki Intruder 3498837457
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeWed Jan 09, 2013 11:31 pm
Great link thanks, I can see them making my wallet a bit lighter. Sissy bar & panniers refix / Suzuki Intruder 276246
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeWed Jan 09, 2013 11:44 pm
It's in my bookmarks now Sissy bar & panniers refix / Suzuki Intruder 3498837457 Sissy bar & panniers refix / Suzuki Intruder 433968
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeThu Jan 10, 2013 4:59 pm
Thats a brilliant link, not only for all the nuts and bolts which covers everything and a bit more but also all the bike stuff they do. A proper little one stop Sissy bar & panniers refix / Suzuki Intruder 184121345
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder    Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeMon Jan 14, 2013 9:29 pm
Dave you know we only post them to lighten your wallet Sissy bar & panniers refix / Suzuki Intruder 3213823784Sissy bar & panniers refix / Suzuki Intruder 3213823784
PostSubject: Re: Sissy bar & panniers refix / Suzuki Intruder   Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeTue Jan 15, 2013 5:50 am
Well then, well done as your plan seems to be working Sissy bar & panniers refix / Suzuki Intruder 122716118
» Brackets for new panniers, Suzuki M50 / M800
» Lock for detachable panniers ...... 2007 Suzuki M50
» * Suzuki C800, Sissy Bar & Rack * Highway Hawk *
» Suzuki C800 integrated flip up sissy bar Seat
» Azcam's new Saddle bags and Sissy Bar .......... 2013 Suzuki C800C
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby Jack70 Today at 4:35 pm
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Sissy bar & panniers refix / Suzuki Intruder Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
