Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun Feb 24, 2013 4:43 pm
Just did a quick video of how I have mine setup.
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun Feb 24, 2013 6:00 pm
Good video Dave Cracking set up it looks very neat and tidy Good idea with the designated Mpeg player rather than a more expensive unit.
Proudtexson VIP Member
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun Feb 24, 2013 6:48 pm
Nice setup. I like the remote setup on bars. Great video
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun Feb 24, 2013 7:19 pm
nice vid but it lacks a sertan something ? lol good set up nice neat fitting job well done
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun Feb 24, 2013 7:21 pm
Looks great dave, the way you have it setup is very neat and tidy and well thought out and executed for ease of use Its been very interesting to see that the 3 members that have this music system have all set it up very slightly differently
typan Member
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun Feb 24, 2013 7:46 pm
great vid dave,good setup.enjoy your system in the coming months.
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun Feb 24, 2013 9:20 pm
Thanks guys I am very happy indeed with the way it is setup, an excellent buy. The remote control being place where it is was just copied on the way that Phil (typan) did it, that then lead on to the idea for the MP3 player mounting bracket. As always on this site, fantastic ideas often come up and others help you see the wood in the trees.
Sanddancer Valued Member
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Mon Feb 25, 2013 6:10 pm
I must admit, I do like the idea of the Amp unit concealed (and may yet change mine).
I put mine accessible (centre bar mounted) for 2 reasons...
1. I don't think you can change radio stations from the remote (correct me if I'm wrong)
2. The remote did not look as "water resistant" as the Amp unit (In case there was a downpour mid ride)
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Mon Feb 25, 2013 6:25 pm
Sorry Paul just scrolled back and watched your video, looking good. Yes you are right that you can't change the stations from the remote but I will probably only ever use the mp3 player so that is not a concern for me. On that note, I have have just been chatting to Doc Cox and he said not to bother fitting an aerial as I had originally planned as it will be a waist of cash. Much better to extend the aerial wire and just run it around the bike, even coiling it in areas to gain length, as the signal will be much better improved through length of aerial than by installing a shop bought one. As for the remote control, I kind of took the attitude that if it was made for external use, it should be fine. However you have me concerned now so I will open it up at the weekend and fill it with Vaseline.
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Mon Feb 25, 2013 6:39 pm
Thanks Dave. I was looking at aerials so glad I've just read this and not wasted my money.
I'm busy making a cap/cover for the amp unit just for added protection, when parked up etc.
Watch what you're doing with the Vaseline- I don't want you cursing me, if you knack it!
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Mon Feb 25, 2013 6:55 pm
Vaseline is an old trick used by automotive mechanics & electricians. There is nothing better on the market at any price for protecting electrics. Any time I have access to or connect any electrical components together I coat it in a layer of Vaseline. It fully waterproofs and stops corrosion!
Theanos Member
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Thu Mar 14, 2013 8:55 am
I wanted to add something to this conversation, and for anyone interested in pictures, just PM me and let me know!
I recently bought a used pair of the PLMCA10s to put on my Marauder (for $30), and with a handlebar mounted tach, there isn't any room to mount them! Well, in order to get them on, I ended up mounting them to the turn signal stems! I wasn't sure how they would look or act, but after adjusting them so they wouldn't hit the tank when I turned, they look pretty awesome. The other issue I ran into with these is that Pyle Audio seems to think that everyone rides a Harley, so the mounting brackets were too damn big. This was an even easier fix. I went to the hardware store, picked up some plumbing wall brackets, shined them up a little and lined the inside with rubber from an old inner tube. 76 cents was all it cost me! So for $30.76 I got a hell of a speaker system, and I would recommend these to anyone looking for something flashy, but reasonably priced!
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Thu Mar 14, 2013 3:39 pm
Now thats thinking outside the box Ryan, very clever idea. If you have a photobucket account, you can post pictures straight to the site.
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Thu Mar 14, 2013 6:39 pm
Yeah, I'd love to see that set up too.
bigmal Very Valued VIP Member
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Thu Mar 14, 2013 10:59 pm
Cool vid Dave.... great little solution to holding the MP3 player.
I've been racking my brains for some way of holding my phone, so you may just have cracked it.
(seriously, NOT so I can text or talk while riding but just as a means of holding it if I wanted to charge it from the handlebar mounted USB/ciggie lighter while on the move.)
The fact so much of the mp3 is visible should make it easy to remember to grab when you park up too
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Thu Mar 14, 2013 11:20 pm
Yeah it works really well, I have cut the front of the mount so that I can access the controls better. With me I just hate paying for stuff when there is an easy home made solution available.
Theanos Member
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun Mar 17, 2013 4:23 pm
There was enough of an interest in how I did it that I thought I would post a few pictures. I wasn't able to find the brand name of the brackets I used, but I don't think there are any Farm and Fleets in the UK anyway! So, without further ado.. And yes, these pictures were taken today. There is too much of that damn white stuff on the ground here!
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun Mar 17, 2013 4:31 pm
That's really smart - love the colour scheme on your bike too. (sorry COLOR!)
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun Mar 17, 2013 4:34 pm
Nice one. Very interesting to see how everyone on here has them set up in a different way.
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun Mar 17, 2013 4:35 pm
Looks good Ryan, good idea fitting the speakers on the indicator stalks
Theanos Member
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun Mar 17, 2013 4:46 pm
Very funny, Mal, but I've watched the Two Ronnies "Fork Handles" skit, so I can decipher Brit fairly well! I was going to mention that the speakers are a little off-kilter, but I didn't want to offend any Scottish sensibilities by using the words off and Kilt in one sentence!
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun Mar 17, 2013 6:51 pm
Forcandles or andles for forks Looks great Ryan
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun Mar 17, 2013 6:58 pm
You'll be telling us you need radiator 'O's next!
Theanos Member
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun Mar 17, 2013 10:55 pm
After a few test runs, I think I need to move the amp. I can tell when the bike is in gear, so I don't need the N. light, but I keep leaving my blinker on cause I can't see the indicator light!
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Mon Mar 18, 2013 3:49 am
Got my amp in same place as yours, and going to move mine as well. Just ordered tool roll to put it in. Moving mine cos I need some space for sat nav I want. Will operate amp from remote like others have done, and will sort a little weather proof cover for it.
Theanos Member
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Mon Mar 18, 2013 6:39 am
I'll probably sew up a treated leather bag and "hang" it right underneath of where it is now. Post pics when you finish yours, Paul.
Right, Im about to order these. (third attempt at buying speakers for the bike) has anyone done a write up or diagram for wiring. I really don't wanna splice anything.
You shouldn’t have to splice anything. The wiring is dead easy... In short, there is a cable that goes from the main unit direct to the battery. Other cables are L & R speakers, Aux cable for ipod, and cable for remote button pad. After various trials, I have settled for the main unit in the side tool compartment (The unit does not have to be accessed if you have one pre set radio station). I have also mounted the remote on the bars with the 2 speakers. There is a simple wiring diagram included in the package, but believe me, you shouldn’t need it.
No, there is an on/off switch on the remote pad and the main unit (called "Mode" button), whichever option you choose to go for. A red L.E.D light indicates power on, on both options. So if the unit is off, no power should be drawn.
You could always wire it to the aux plug in the headlight bucket, then it's only live when the ignition is on? No good if you want music on while your parked though.
That’s a good point. (I wouldn’t of known how to do that). It did cross my mind if some nosy bugger wanted to play with the remote and turn the tunes on, it could drain the battery. I will probably make a little cap/water cover for the remote when parked. Something else to do!
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Wed May 01, 2013 1:32 am
I have my Kuryexpensive speakers hooked direct to the battery because I listen to my Sat Radio and Ipod a lot while I am working. They have their own on/off switch and a little green light thats on when they are on. I have run my Bat. down a couple of times from leaving them on. But once I finally pulled my head out of my ass it hasn't been a problem.
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Wed May 01, 2013 3:22 am
The auxiliary power supply inside the headlight bucket and is rated at 10amps, so more than enough power. Most of us simply use 2 spade connectors to gain access to the power supply. O/B = Live / B/W = Earth. The connector is switched live, so only works when the ignition is on.
shadycowboy Member
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Wed May 15, 2013 3:54 pm
Silly Question, but which color to which part of the aux supply above? My speakers arrived :-)
shadycowboy Member
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Wed May 15, 2013 5:03 pm
Well my Amp doesn't work. Typical.
third time ordering speakers and looks like they are going back.
Tried the aux headlight. Nothing no power light
I have the connections direct to the battery. Nothing no power light.
shadycowboy Member
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Wed May 15, 2013 5:19 pm
Just discovered the problem. The Fuse is blown on the power cable. How can a new amp have a blown fuse!
Bunso Steel Valued Member
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Wed May 15, 2013 5:44 pm
Just got given this set for my birthday, will be installing it on the triumph. I'll make sure to check the power supply fuse if I get any problems!
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Thu May 16, 2013 12:08 am
shadycowboy wrote:
sorted and all working, Radio Crap. Music average to OK pretty distorted. Amazingly turning it UP helps lol
Couldn't expect more from £55
radio just needs a longer antena wire but if your music is not coming through very good untill you turn it up then I would send it back and get a replacement. Where you have it mounted could make a difference though as you may be getting interferance.
Theanos Member
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun May 19, 2013 6:48 am
I'm back. My bike is in the shop, so it's been pretty depressing coming onto the forums.
This system is great, as long as you avoid rain. The biggest issue I've run into is the volume. It would be better suited on a quieter bike than mine, but tunes is tunes. To add onto what everyone is talking about, remember, the unit does NOT stop draining battery unless you disconnect the amp from the power source (i.e. Pulling the power cord from the back of the amp). There is always going to be a little trickle being pulled to maintain the time and the pre-set radio station. The trickle is minimal, as long as your battery is up for it.
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Sun May 19, 2013 10:51 am
The best thing to do with power is to have it run on a switched earth such as the spare port in the headlight bucket
Subject: Re: Pyle PLMCA10 Motorcycle Speaker & Amplifier System Fri May 31, 2013 1:37 pm
Hey guys need a little help installing mine on the Tiger. I have an auxiliary power point at the front of the tank which I'd like to power the amp from as its switched live. However this is not a standard cigarette lighter style socket its like a mini version I have never seen before. Could anybody give me some advice on what adapter I would need for this socket in order to connect the spades from the amp power cable?
