 Help with wiring in led lights
6 posters
Help with wiring in led lights Empty
PostSubject: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeThu Mar 21, 2013 4:23 pm
I want add some led strips to the car, what wire or cable do you guys use? I cant see to find anything near the gauge that my led's have come with but the wire is not long enough on them
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeThu Mar 21, 2013 5:18 pm
I use a twin core copper speaker cable for mine. Not sure what a proper automotive electrician would have to say about that though.
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeThu Mar 21, 2013 5:22 pm
Hi CC the load on led's is very low,as Dave says speaker wire is good enough,a lot of people use telephone wire if that is any help.
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeThu Mar 21, 2013 5:26 pm
Good tip Alfie, never thought of telephone wire. Help with wiring in led lights 3498837457
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeThu Mar 21, 2013 6:17 pm
Thank you gents that makes sense Help with wiring in led lights 881924
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeThu Mar 21, 2013 10:33 pm
for the LED strips I put on my panniers, I cannibalised an old phone charger... the wire on that was twin core & nice & lightweight. There was a rating marked on the cable, so I rang the LED supplier & he confirmed it was plenty beefy enough Wink
But if you're doing the daylight running light type things, I'm guessing they'll need something beefier. Maplins sell all kinds of cable???
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeThu Mar 21, 2013 11:16 pm
Maplins don't sell anything for LEDs, it was them in there tech department that originally advised me to use speaker cable.
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeFri Mar 22, 2013 2:22 pm
A good tip for people reading this,if you are soldering wires together,always lay them side by side to solder them, and do not twist them together,this twisting method makes them joints weaker.
Theanos
Theanos
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeSat Mar 23, 2013 8:53 am
Serious tip here, to follow on Alfies: If you want a good joint when you solder wires, get someone to hold the wires for you, especially if you're trying to splice wires while the lights/what-not are mounted. Taking a few minutes to find a willing participant can make all the difference!
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeSat Mar 23, 2013 10:06 am
Here is another one, heat the wire.
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeSat Mar 23, 2013 1:30 pm
Dave this can be done by tinning,ie:heat a bit of solder on each wire before joining,these little tips are great for people learning and we should all keep them coming in to help each other.
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeSat Mar 23, 2013 3:21 pm
Here is another one, don't short cut, use flux.
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeSun Mar 24, 2013 3:47 pm
You should still initially heat the wire even when tinning so as avoid having a cold solder joint.
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeSun Mar 24, 2013 4:12 pm
Good point Dave,I stand corrected. Help with wiring in led lights 3005623951
PostSubject: Re: Help with wiring in led lights    Help with wiring in led lights Icon_minitimeMon Mar 25, 2013 11:00 pm
for anybody new to soldering a joint should look bright when finnished if it looks dull it's a dry joint which is weak & needs redoing Help with wiring in led lights 184121345
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeMon Mar 25, 2013 11:10 pm
That's a great tip. Help with wiring in led lights 3498837457
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeTue Mar 26, 2013 9:08 pm
Excellant tip there Martin,this is what we need,tips and advice.
PostSubject: Re: Help with wiring in led lights   Help with wiring in led lights Icon_minitimeTue Mar 26, 2013 10:56 pm
The great tips that have come out of this thread have been amazing Help with wiring in led lights 433968
» Led wiring.
» wiring problem please help....
» wiring loom
» Spotlight Wiring
» wiring colours
Help with wiring in led lights Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Help with wiring in led lights Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Help with wiring in led lights Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Help with wiring in led lights Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Help with wiring in led lights Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Help with wiring in led lights Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Help with wiring in led lights Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Help with wiring in led lights Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Help with wiring in led lights Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Help with wiring in led lights Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Help with wiring in led lights Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Help with wiring in led lights Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Help with wiring in led lights Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Help with wiring in led lights Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Help with wiring in led lights Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Help with wiring in led lights Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Help with wiring in led lights Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Help with wiring in led lights Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Help with wiring in led lights Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Help with wiring in led lights Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
