Subject: Clear Lights on Rear of C800 Sat Jun 25, 2011 3:31 pm
Finally got around to changing my indicator Lenses & Bulbs over from the horrid orange blobs that come as stock! I am much happier now that I have both the rear light & indicators changed over
Before
After
Badger Valued Member
Subject: Re: Clear Lights on Rear of C800 Sat Jun 25, 2011 3:56 pm
That's a classy look.
Subject: Re: Clear Lights on Rear of C800 Sat Jun 25, 2011 4:11 pm
The clear lights look sooooooo much better Mr Intruder Sir, I likes it I see the indicator lenses are slightly smoked which I think looks better the the totally clear as you end up focusing on the orange bulbs!
Can I ask how much and where from?
PS, I love the clear rear led light, much much nicer than stock
Subject: Re: Clear Lights on Rear of C800 Sat Jun 25, 2011 9:03 pm
They are on ebay all the time, I bought the clear led light from them as well. the indicator kit cost £43.50 delivered from Germany. You need two sets at £19.99 plus delivery LINK Well spotted with the smoked lenses & yes your right they make for a more subtle visual than the totally clear
Johnmc800 likes this post
Subject: Re: Clear Lights on Rear of C800 Sun Jun 26, 2011 10:01 pm
Good buy, thanks for the pictures and infomation
snooser Member
Subject: Re: Clear Lights on Rear of C800 Thu Jul 07, 2011 4:51 am
Mr. Intruder, I got inspired from you and got a set for my bike too. Say, did you have a fitting problem too?? I had to cut off half the upper tap so I could twist the new glass in the housing. Otherwise the bottom screw could not hit the hole in the reflecor. This was misplaced "half a hole". But I succeeded. Did you pack the neck of the reflector inside the housing too?
Subject: Re: Clear Lights on Rear of C800 Thu Jul 07, 2011 5:13 am
I found them to be extremely tight, so I smeared wd40 on them and twisted with caution and they went on ok. I did not pack anything
snooser Member
Subject: Re: Clear Lights on Rear of C800 Thu Jul 07, 2011 7:04 am
about packing - its because the original were packed to prevent water getting into the housing. I used ordinary rubber stripes for sealing windows. Believe my c800 has an older model lamphous than you.
Subject: Re: Clear Lights on Rear of C800 Thu Jul 07, 2011 8:26 am
Yes I did notice that the original had a seal and that the replacement did not, however I did not feel that it would be an issue as the replacement is a very tight fit & there is a drain hole in the bottom
Subject: Re: Clear Lights on Rear of C800 Thu Jul 07, 2011 8:54 am
Ghaaaah.. why don't they sell things that fit the things they sell them for? This happens quite a bit ........... Maybe they guessed at the sizes and thought, yea, that will do.
Subject: Re: Clear Lights on Rear of C800 Thu Jul 07, 2011 8:06 pm
I have no complaints, I am very happy with the product. A very tight excellent fit & I would personally recommend it!
snooser Member
Subject: Re: Clear Lights on Rear of C800 Fri Jul 08, 2011 5:37 am
Yes indeed! Looks nice and that bit of modification was just fun ... well, what can you expect from chineese stuff? They will work fine, untill I will go to the "elderly home"
Subject: Re: Clear Lights on Rear of C800 Sat Jul 09, 2011 6:24 pm
Oh No see what you have done
snooser Member
Subject: Re: Clear Lights on Rear of C800 Fri Jul 22, 2011 7:04 pm
sorry, sorry - no golfing!!! EEEhhh - try crocket..
icetechaus Valued Member
Subject: Re: Clear Lights on Rear of C800 Sat Aug 13, 2011 12:08 am
I was getting ready to say that the clears are standard over here but then I did a bit of web crawling and discovered that they aren't. Fortunately for me on my bike they are. Must have been one of the special features for the 09 M50.
Subject: Re: Clear Lights on Rear of C800 Tue Aug 16, 2011 1:56 pm
[img:9846]https://www.suzuki800.com/[/img] Hi Dave I have these indicator bulbs fitted this is were I found them type chrome indicator bulbs in your ebay search engine,mine cost £2.99 a pair.99p postage.As you can see when you are running they look clear,cleans your back end up,and they do flash amber,and are road legal.The right hand one is Chrome and the left is amber,to show you the difference.
Subject: Re: Clear Lights on Rear of C800 Tue Aug 16, 2011 3:14 pm
Alfie is this the one to get before I order (Ebay Link)
Subject: Re: Clear Lights on Rear of C800 Tue Aug 16, 2011 4:14 pm
Sure is Dave recieved mine in a day.You will be pleased.Can you please tell me how to put links from ebay up here for I am always searching for bargains,being a pensioner (60) not 65 yet.
Subject: Re: Clear Lights on Rear of C800 Tue Aug 16, 2011 4:35 pm
Very simple Alfie if you hover over the little icons above the black box that you right in, you will see a little icon that looks like a chain link. when you are hovering over it for a second or two it will say "Link", click on it and you will see 2 red oblong boxes, you place the link address in the top one and type what you want everyone to see in the bottom one. Hope this helps
PS, if you want more editing choice over you posts, click on preview & extra editing icons will appear.
