| | Speedo needle | |
MarcinG Valued VIP Member
| Subject: Speedo needle Sat Oct 12, 2013 9:02 pm | |
| Guys... how the hell do you take the needle off? | |
| Subject: Re: Speedo needle Sat Oct 12, 2013 9:06 pm | |
| I've never tried? I would have thought it just pushed on though :what1: | |
| Subject: Re: Speedo needle Sat Oct 12, 2013 9:11 pm | |
| Well it sits damn tight...
I'll find out soon enough...going to find something to use as leverage. | |
| Subject: Re: Speedo needle Sat Oct 12, 2013 9:16 pm | |
| F*cker doesn't budge.... any more and I'll break it. | |
| Subject: Re: Speedo needle Sat Oct 12, 2013 9:25 pm | |
| You will need to pry it upwards, I have an electrical wire cutter that has a kind of pronged end on it, kind of forked but yes it would be very awkward to just pull it up, but by squeezing it and by kind of getting under the needle as well it will be much easier. | |
| Subject: Re: Speedo needle Sat Oct 12, 2013 9:35 pm | |
| well I tried leverage and nothing... feels like it's one with the rod going down and I'll break the crap inside if I press any harder.... time to give up today I think | |
| Subject: Re: Speedo needle Sat Oct 12, 2013 9:43 pm | |
| You are the one there with the bike, if in doubt of its security it may be better to leave it rather than mess up. | |
| | | smart Valued Member
| Subject: Re: Speedo needle Sat Oct 12, 2013 9:46 pm | |
| Just a thought Marcin why do you want it off | |
| Subject: Re: Speedo needle Sat Oct 12, 2013 9:47 pm | |
| Subject: Re: Speedo needle Sat Oct 12, 2013 9:55 pm | |
| No screws round the back or anything? nothing visible as to how it's been fitted? | |
| Subject: Re: Speedo needle Sat Oct 12, 2013 10:06 pm | |
| nope...at the back there's only the coil that moves it.. I'm fairly sure it should pop off at the top but it looks like it's been glued. I think it sits on a round head. I managed a peek with a knife acting as mirror and I could see black head with an "X" reinforcement. Until I get a confirmation for other K2 user regardin taking it off, I think I'll park that idea for now. Better that than break the needle or mess up the coil. | |
| Subject: Re: Speedo needle Sat Oct 12, 2013 10:15 pm | |
| On the plus side I gave the glass a really good clean from inside and now it's dogs danglies :] | |
| Subject: Re: Speedo needle Sat Oct 12, 2013 10:24 pm | |
| Subject: Re: Speedo needle Sat Oct 12, 2013 10:36 pm | |
| Lol for real? :)
That's exactly like mine...hmm fork....time to raid the kitchen | |
| Subject: Re: Speedo needle Sat Oct 12, 2013 10:50 pm | |
| With the gear you have just bought there could be a side line in this for you on be-spoke faces, good luck | |
| It's off.
Thanks Dave for "fork" method ;D | |
| Subject: Re: Speedo needle Sat Oct 12, 2013 10:56 pm | |
| No problem Marcin, glad I could assist. By the way if you start making faces for members, I will be one of your first paying customers for the newer type of speedo, I know it will probably be slightly different to yours though so I will be happy to wait. | |
| Subject: Re: Speedo needle Sat Oct 12, 2013 11:20 pm | |
| Just realised that I cocked up the needle setup.... That'll be fun to try to set it right. | |
| Subject: Re: Speedo needle Sun Oct 13, 2013 4:15 pm | |
| Rain or no rain, I was eager to find out if the speedo works...so I went for a ride. It doesn't Needle doesn't even budge no matter how fast I go. I'm F.C.U.Ked Off to garage to try to reset it. Update## Well I have done some tests and I made few assumptions: 1. The speedo works on a basis of electric resistance 2. When ignition is turned on, the needle resets to where "0" is With that as a vague basis, I altered the needle positioning to sit at "0" with ignition on. When I spun the wheel the needle hesitates for a fraction of a sec, then goes up quickly to about 4, 5mph and increases steadily up to 10mph (I wasn't able to turn the wheel any faster by hand lol) I guess the next thing to do is to take some satnav, go for a ride and see how much of a discrepancy is between needle and what satnav says...alter, and test again. Lesson learned eh? | |
| Subject: Re: Speedo needle Sun Oct 13, 2013 5:28 pm | |
| Is the needle attached/gripping properly on the spline that it sits on? | |
| Subject: Re: Speedo needle Sun Oct 13, 2013 5:33 pm | |
| Subject: Re: Speedo needle Sun Oct 13, 2013 5:43 pm | |
| Hope you haven't "forked it up" Great idea re the custom speedo face Marcin | |
| Subject: Re: Speedo needle Sun Oct 13, 2013 6:11 pm | |
| Not sure what to say if you have aloud everything to be reset & the needle has been placed on so that it is after the stopper at the zero position and it is not slipping on the spline that moves. Sorry wish I could be of more assistance but it's never easy assisting from a distance. | |
| Subject: Re: Speedo needle Sun Oct 13, 2013 6:22 pm | |
| Should be fine...will test with satnav and see how it goes :] When in doubt: "Honest officer, the speedo was showing 10mph, not 100!!!" | |
| Subject: Re: Speedo needle Sun Oct 13, 2013 6:35 pm | |
| I really hope this all works out for you Marcin, I have always loved images of the grim reaper & have several tattoos on that theme on my arms. Really Really want it at some point & I am hoping one day you'll be the man for just that job. I have my fingers crossed for you. | |
| Subject: Re: Speedo needle Sun Oct 20, 2013 8:27 pm | |
| Marcin do you have any additional tips on getting the speedo clock face out on later models, no worries if you ain't I will do a picture & info thread myself for anyone wishing to do it with a 2009+ model at some point later when I attempt it. | |
| Subject: Re: Speedo needle Sun Oct 20, 2013 8:33 pm | |
| If it's anything like mine Dave, then I'd advise patience and being very careful with 2 screws that hold the speedo face. They're going into soft plastic and you're not supposed to tighten them almost at all, just screw in to the washer (mine got two, out of which 1 is spring washer) Almost threaded mine.
It needs to be just tight enough for the needle to cross over the top of screw. I did that error today actually - the screw was fairly tight but I pushed the needle on too much and speedo wouldn't go past it. | |
| Subject: Re: Speedo needle Sun Oct 20, 2013 8:45 pm | |
| Thanks Marcin, it will probably be next weekend I will be able to actually remove mine but with your honesty of possible problems/issues of which I am extremely thankful, I will be extremely careful. | |
| Subject: Re: Speedo needle Sun Oct 20, 2013 8:51 pm | |
| You're welcome mate. Everything else is a doddle. | |
| Subject: Re: Speedo needle | |
| | | | Speedo needle | |
Latest topics | » Hello by Badger Today at 1:36 pm
