 How To - Headlamp lowbeam cutoff when starting
5 posters
CanadianCruiser
CanadianCruiser
How To - Headlamp lowbeam cutoff when starting Empty
PostSubject: How To - Headlamp lowbeam cutoff when starting   How To - Headlamp lowbeam cutoff when starting Icon_minitimeFri Nov 15, 2013 5:01 pm
Alrighty being as it was a nice day out today I decided to get started on some mods...
First off I hate that when we start the bike 1 there is a delay and sometimes doesn't fire up (takes a couple tries) this is because of an extra relay in the starting system called the Mitsubishi starter control relay.  (Not the Starter relay).  In newer models they deleted this useless module.
How To - Headlamp lowbeam cutoff when starting Img_0710
So I figured I'd kill two birds with one stone.  Delete this module and add a Headlamp lowbeam kill when the start button is pressed.  (eliminates some of the load from battery). It's all done right at the fuse block on the left side.
Needed one 30 amp standard relay, 4 female blade connectors (or relay harness) and butt connectors.
1. Remove left cover.
2. Pull up on Mitsubishi module (it's right beside starter relay) 3 wires going into it.. Yellow/Green, Yellow Black, Black/White
3. cut all 3 and toss the module in your neighbors yard so he runs over it when cutting grass. (only if he ticks you off)
4. Join Y/G & Y/B together with a female blade and connect to pin 85
5. attach a female blade on B/W wire and connect to Pin 86
Now to the fuse block... on my bike the lowbeam is white... looking at the fuse block you will see two white wires right beside each other.. you want the white wire that is on the outside going to the head lamp. (if your not sure pull the fuse #2) turn the key to on, then probe the terminals with a test light or multimeter with it grounded to battery.  One terminal will read 12v (you don't wan this one).
1. Cut white wire (leave lots from fuse block) the end coming from the fuse block.  attach female blade (may need extra wire) and connect it to pin 30.
2. White wire running to bike attach female blade (again may need more wire) and connect to pin 87A
3. Insolate pin 87 with tape or heatshrink.
Now reassemble and your good to go. (my relay had a metal bolt holder so I turned it upside down and inserted it where the old Mitsubishi module went.)
Now you will no longer have a slight delay when starting and the Headlamp will turn off when your pushing the starter button.
* Newer models that don't have the MMM you can still do this mod wiring is the same except for Pin 85 you just need to "T" tap the Y/G wire from the starter and run a ground from Pin 86.*
Enjoy!
How To - Headlamp lowbeam cutoff when starting Img_0711   How To - Headlamp lowbeam cutoff when starting Img_0712    How To - Headlamp lowbeam cutoff when starting Img_0713
PostSubject: Re: How To - Headlamp lowbeam cutoff when starting   How To - Headlamp lowbeam cutoff when starting Icon_minitimeFri Nov 15, 2013 6:29 pm
Wow.... you're going to be a real asset to the site with your expert knowledge and excellent write ups!!!
PostSubject: Re: How To - Headlamp lowbeam cutoff when starting   How To - Headlamp lowbeam cutoff when starting Icon_minitimeFri Nov 15, 2013 6:49 pm
Wow what a great mod and brilliant write up. Thanks for that, what a productive day you have had.
This is a great modification that all bikes need as the battery drain can be enough to stop a bike starting. How To - Headlamp lowbeam cutoff when starting 184121345 How To - Headlamp lowbeam cutoff when starting 184121345 How To - Headlamp lowbeam cutoff when starting 184121345 How To - Headlamp lowbeam cutoff when starting 184121345
PostSubject: Re: How To - Headlamp lowbeam cutoff when starting   How To - Headlamp lowbeam cutoff when starting Icon_minitimeFri Nov 15, 2013 7:22 pm
Good job Canadian Cruiser How To - Headlamp lowbeam cutoff when starting 2170595768 Excellent write up too! How To - Headlamp lowbeam cutoff when starting 276246
PostSubject: Re: How To - Headlamp lowbeam cutoff when starting   How To - Headlamp lowbeam cutoff when starting Icon_minitimeFri Nov 15, 2013 7:43 pm
Excellently planned, written out & explained. Well done gotta add it to my list. How To - Headlamp lowbeam cutoff when starting 276246
PostSubject: Re: How To - Headlamp lowbeam cutoff when starting   How To - Headlamp lowbeam cutoff when starting Icon_minitimeFri Nov 15, 2013 8:34 pm
Dave can you explain what you have done to your lights and why it is that you will be doing this mod as well as it may assist others that have plans to do this mod
PostSubject: Re: How To - Headlamp lowbeam cutoff when starting   How To - Headlamp lowbeam cutoff when starting Icon_minitimeFri Nov 15, 2013 9:15 pm
All I did on my model is splice into one of the headlamp wires and put in a switch which I have hidden on the underside of the side cover under the seat so that I can turn off the main beam & just have the side lights on when required. Very simple to do.
The mod that CanadianCruiser has worked out & written here will be another benefit to my battery saving mods that I have so far done, which also includes fitting a bigger battery ( - LINKY - )
CanadianCruiser
CanadianCruiser
PostSubject: Re: How To - Headlamp lowbeam cutoff when starting   How To - Headlamp lowbeam cutoff when starting Icon_minitimeFri Nov 15, 2013 9:28 pm
Thanks guys...  I can't do the mod you did with just turning off the headlamp... in Canada vehicles need daytime running lights.  Closest thing I can do is add Hazards... (can't link yet but got diagram up on another thread.)
» Poor starting
» Help me please - starting issue.
» Bike not starting
» Starting problems/Relay?
» Non starting VZ800 Marauder
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
How To - Headlamp lowbeam cutoff when starting Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
