 VS1400 drive fitting soon
Bigredbus4468
Rattler
10 posters
Go to page : 1, 2  Next
Rattler
Rattler
VS1400 drive fitting soon Empty
PostSubject: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeTue Dec 17, 2013 12:32 am
After several hours over the last few days sanding and polishing my VS1400 drive it's finally done.
I'm taking my stock drive and spacer to be machined in a few days and need to fit the new seals.It should be finished next week.
When the drive arrived it was damaged so I'm pleased with the job I've done on it.
The damage to the drive case.
VS1400 drive fitting soon 20131204_205256
After sanding.
VS1400 drive fitting soon 20131209_210150
Finished. All nice and shiny.
VS1400 drive fitting soon 20131216_234603
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeTue Dec 17, 2013 2:18 am
Looking good Rattler. Looks like new.  VS1400 drive fitting soon 428386
Bigredbus4468
Bigredbus4468
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeTue Dec 17, 2013 8:26 am
Enlighten me. Why are you fitting a 1400 drive please?
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeTue Dec 17, 2013 8:33 am
You are going to fall in love all over again Rattler, glad you are finally getting it done.  VS1400 drive fitting soon 3498837457
Changes the gearing and they are also longer gears, really wakes the bike up.
Read (THIS) in the Modifications done section.
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeTue Dec 17, 2013 4:31 pm
Looking good Rattler  VS1400 drive fitting soon 2170595768
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeTue Dec 17, 2013 9:34 pm
Good job done.  VS1400 drive fitting soon 3498837457
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeTue Dec 17, 2013 10:28 pm
looking nice and shiny VS1400 drive fitting soon 3498837457
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeTue Dec 17, 2013 11:32 pm
Ok I'm confused. I started removing what I think is the seal expecting to find the circlip. Where is it?
This seal seams to be tucked in and is a right pain to get off.
VS1400 drive fitting soon 20131217_231212
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeWed Dec 18, 2013 12:27 am
That's the 800 seal, It's rubber coated metal, where the metal changes colour is the joint of the seal, grip it with some grips and twist and the joint will open up, then prise it off with a large flat screwdriver or similar and it will pull up and away from the shaft and housing, The Circlip is behind that,  don't worry about fucking the seal up, it's already knackered, when your replacing the 1400 seal, It's more like a fork seal that fits within the hole as opposed to over it.
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeWed Dec 18, 2013 12:41 am
Lol so I've just removed the rubber coating. I'll do that tomorrow night.
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeWed Dec 18, 2013 9:16 pm
Is this good enough to give to the guy milling it.VS1400 drive fitting soon Screenshots_2013-12-18-12-55-50
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeWed Dec 18, 2013 9:30 pm
That'll be fine Rattler  VS1400 drive fitting soon 3498837457
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeWed Dec 18, 2013 9:42 pm
Any tips on removing this seal to get to the circlip on the 800 drive? Can't budge the damn thing. Tried loosening it with grips.
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeWed Dec 18, 2013 11:37 pm
I just used a hammer and screwdriver  VS1400 drive fitting soon 852880  It isn't being re fitted, so I just tapped the edge till a gap appeared then prized it gently off with a screwdriver working my way round it till it was removable by hand.
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeWed Dec 18, 2013 11:47 pm
Done it bud after a long while. Can't get the bloody circlip off though. It snapped my circlip pliers.
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeThu Dec 19, 2013 8:41 pm
I was trying to open the circlip not close it. Should have realised by Dave saying he used needle nosed pliers though lol. Still can't get it out though.
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeThu Dec 19, 2013 9:04 pm
So you snapped your Circlip pliers trying to open it up instead of squeezing it together and lifting it out, Even when you squeeze it together it's pretty tight to get out, tough little circlip that one.
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeThu Dec 19, 2013 10:22 pm
Yeah lol. Just took it round to my Chairman's and he had some better pliers and managed to get it out.
Gonna take the drive shaft tomorrow evening.
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeThu Dec 19, 2013 10:58 pm
Nice one!  VS1400 drive fitting soon 3498837457
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Dec 20, 2013 8:33 am
Looking at the diagram from the workshop manual..the spring in the shaft slides in and then there should be a bolt? Well mine doesn't have one, the spring just slides out. Also the spring I ordered for to replace is nothing like the one on the 800. It's much larger in circumference and shorter in height.
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Dec 20, 2013 8:37 am
I've not dismantled the VS1400 drive yet so can't compare but if it is wrong I can just use the original VS1400 spring yeah.
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Dec 20, 2013 8:40 am
If you have ordered the VS1400 spring as a replacement for the VL800 spring, yes it is much larger and should be used if you have it.
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Dec 20, 2013 11:27 am
How does it fit in the end of the shaft? It's way too big.
Also when shortening the shaft should it have the slight taper on the very end that it has stock?
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Dec 20, 2013 11:59 am
It just fits in the the gap (stopper bearing) you have removed the drive shaft end from and the drive shaft pushes against it.
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Dec 20, 2013 3:18 pm
Ok nice one Dave.
When the length of the shaft is shortened does there need to have the taper like when it's stock? The photos look to be without it but others look like they may have it.
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Dec 20, 2013 3:21 pm
I had mine tapered slightly, to make it slip into the universal joint easier.
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Dec 20, 2013 3:25 pm
That's included in the length that's left then yeah after the correct amount is removed?
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Dec 20, 2013 4:39 pm
Have it milled back by 3"/16th's so it's the correct length, and then just round the edge off the end of the splines slightly so it slides into the universal joint easier, no where near as much as stock though, like the top one in the pic.
 VS1400 drive fitting soon IMG_1135_zps2fdf7f03
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Dec 20, 2013 7:46 pm
Which end of the spacer gets the length taken off? The thinner part drops into the drive.
VS1400 drive fitting soon 20131220_191723
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Dec 20, 2013 7:50 pm
I've dropped the shaft and spacer off. The guy was saying that with the description in this image it says that 3/8" is taken back and 3/8" forward into the spline to make the 3/16". Is that correct?
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Dec 20, 2013 8:32 pm
The thin end of the spacer is easiest but any end will do, Machine the "end" of the shaft back 3/16ths and the shoulder back 3/16ths, don't mill into the splines! Mill them both in the same direction! towards the end that goes into the drive. There's an arrow between the two lines pointing in the direction it needs milling in the photo above, where it says machine shoulder back! "NOTHING" should be 3/8ths "NOTHING" or it'll be wrong.
DaveC
DaveC
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Dec 20, 2013 8:52 pm
Bloody hell!  if i attemped owt like this, the bugger would never run again  VS1400 drive fitting soon 3213823784
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Dec 20, 2013 9:11 pm
Fuck that, you are allowing a fucking idiot that can not read simple instructions and drawings to do your modification. We have not said that anywhere & if you are getting instructions & pictures from elsewhere then ask them & not us as it is making a simple job sound harder than it is.
I do not want anyone put off doing this easy modification that I have explained in full in the "Modifications Done" section due to there lack of ability to understand what both myself & Sim have written in the other thread.
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeSat Dec 21, 2013 11:34 am
Like this.
VS1400 drive fitting soon 3d057322-bf68-461b-83f5-8655769753a8_zps0a420682
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeSat Dec 21, 2013 2:19 pm
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeSat Dec 21, 2013 4:45 pm
I only have Internet access on my phone. Images on here don't always show up for whatever reason. Yes I have instructions but not always images. I managed to email the pics to my mrs at work to print off so I had a couple of things with instructions to give him. I got the other image from the VR forum where I could see the image.
Typical as right now they are all showing up.
I text him last night and he knows he misread what it says.
I sometimes over think things which do complicate things and I know that.
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeSat Dec 21, 2013 4:57 pm
Rattler just keep asking the questions mate, as people don't always have the patience & respond in the best ways and have the courtesy & consideration we always should. I would rather you keep asking the questions and get it right & enjoy the end product in the way you should.
Better to over think an issue than not think enough, I would rather you ask the questions that make it clear in your own mind.  VS1400 drive fitting soon 3498837457
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeSat Dec 21, 2013 5:03 pm
Cheers Dave. Took the 1400 drive apart today. Took about 20 seconds in total to get seal and circlip out lol.
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeSat Dec 21, 2013 6:00 pm
You are so close now & are going to love it. funny how something can give you a headache and then then you have a eureka moment.  VS1400 drive fitting soon 852880
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeSun Dec 22, 2013 2:15 pm
An exceedingly good modification that I have previously read about at some point. Is there a recommended thread area to show the final example or findings in full? My apologies as after searching this area, I have not as yet been able to re-find the one that had been written.
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeSun Dec 22, 2013 5:09 pm
Have a look at this LINK Ken  VS1400 drive fitting soon 184121345
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeThu Jan 02, 2014 10:48 pm
Picked up the shaft and spacer today. Changed the rear shoes too so really it should be just elongating the holes and finished but I got home to find my Mrs had been tidying..emptied my bag of parts on the side and threw the bag away. Now I'm a seal missing  VS1400 drive fitting soon 122716118
Dave..sent you a PM mate.
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeThu Jan 02, 2014 10:55 pm
Got the PM & just replied but nothing in it?
Which seal are you missing?
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeThu Jan 02, 2014 10:58 pm
The one that goes over the top of the circlip mate. Gonna order another tomorrow.
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeThu Jan 02, 2014 11:15 pm
Bugger I have several spare ones but not that one. At least the come very quickly & then your going to be so pleased that we will be able to see your smile from here.  Very Happy
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Jan 03, 2014 12:14 am
Got one in the garage Rattler  VS1400 drive fitting soon 3498837457  Send me your address and I'll post it tomoz, Or pick it up over the weekend if your in a hurry?
Rattler
Rattler
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Jan 03, 2014 8:38 am
Simbo have you got my PM? They seem to be storing in the outbox.
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Jan 03, 2014 10:09 am
Yeah mate, just got them  VS1400 drive fitting soon 3498837457
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Jan 03, 2014 12:56 pm
Elongate the holes and test fit the drive a few times before fitting the shaft and seal in the drive, It makes for final fitting without hiccup  VS1400 drive fitting soon 3498837457
PostSubject: Re: VS1400 drive fitting soon   VS1400 drive fitting soon Icon_minitimeFri Jan 03, 2014 1:11 pm
FYI, message will appear in your outbox until it's been read by recipient.
» VS1400 Drive
» vs1400 drive mod
» VS1400 drive conversion ..................................... FINISHED
» VS1400 drive axle cover
» VS1400 Drive & Shaft Modification ......................How To Thread.
VS1400 drive fitting soon Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
VS1400 drive fitting soon Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
VS1400 drive fitting soon Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
VS1400 drive fitting soon Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
VS1400 drive fitting soon Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
VS1400 drive fitting soon Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
VS1400 drive fitting soon Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
VS1400 drive fitting soon Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
VS1400 drive fitting soon Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
VS1400 drive fitting soon Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
VS1400 drive fitting soon Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
VS1400 drive fitting soon Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
VS1400 drive fitting soon Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
VS1400 drive fitting soon Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
VS1400 drive fitting soon Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
VS1400 drive fitting soon Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
VS1400 drive fitting soon Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
VS1400 drive fitting soon Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
VS1400 drive fitting soon Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
VS1400 drive fitting soon Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
