Subject: Viking Bags added ................................ to 2013 Suzuki M800 Thu Jan 09, 2014 9:46 am
Look what arrived yesterday. wasn't in so just been too the PO to collect.
Amazing quality, nice and rigid, throwover mounts that detach by unscrewing from inside the bag, securing straps that can be clipped off when not required, hard mounts included. They are exactly as measured but a little smaller than I expected, but a good size for the bike. Need time this weekend to hard mount them. I paid £84 for these - yes by mistake but they should be £118 plus £16 delivery.
Lowey Valued Member
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Thu Jan 09, 2014 11:11 am
Good result in the end, nice looking bags.
azcam Valued Member
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Thu Jan 09, 2014 4:54 pm
Nice Bags.
Interested to see how they fit and if I can Mod my bags to do the same.
£84 !!! Bargain ill say.
Subject: Viking Bags added to Thu Jan 09, 2014 5:01 pm
I love a happy ending Nice bags at a bargain price!
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Fri Jan 10, 2014 1:09 pm
These are now on my wish list & will at some point replace the ones that I currently have. Excellent price, with excellent features. Amazing bags, thanks for sharing.
Bigredbus4468 Member
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Fri Jan 10, 2014 4:03 pm
Fitted one side today. Will do the 2nd this weekend. Have found 1 small downside but I can sort it out.
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sat Jan 11, 2014 5:52 pm
Finally fitted. It wasn't easy. Just need to blank the holes in the back of the bags where the throw over's straps went.
Jimmyboy Valued Member
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sat Jan 11, 2014 6:04 pm
They look well good mate, what issues did you have fitting them?
Jim.
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sat Jan 11, 2014 6:16 pm
There are 4 holes in the back fitted with a sort of rivitted grommet with 2 rubber bungs in. Several of the brass grommets have come out leaving holes in the back. The holes did not line up as expected, and they tell you to drill holes to fit the brackets. In also ended up drilling holes more than once as in struggled to line them up. I need to weather proof the additional holes lol.... Somebody at work suggested electrical insulating tape. Suggestions? The backs are hard plastic like abs.
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sat Jan 11, 2014 6:19 pm
Silicone in the hole then wiped off so its flush then when its dry black electrical tape as suggested should do the trick.
Jim.
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sat Jan 11, 2014 6:23 pm
The holes are quiet big - 10mm
Forgot to mention I had to purchase 2 additional fitting bolts to fit to the fender to replace the stock bolts. Front 2x 8 x 120 mm. Rear 2x 8 x 90 mm steel.
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sat Jan 11, 2014 6:41 pm
They look great Kevin Something like these would do for the extra holes. http://www.ebay.co.uk/itm/HOLE-PLUGS-PLASTIC-BLANKING-GROMMET-TRIM-SNAP-IN-CLIPS-KIT-CAR-BOAT-BIKE-BLACK-/171068863644?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27d47fb49c
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sat Jan 11, 2014 7:22 pm
Good find Sim.
Jim.
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sat Jan 11, 2014 7:39 pm
I'll get some cheers Sim. If I cut the backs off I can stick them over the holes
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sat Jan 11, 2014 8:23 pm
Those bags look excellent fitted, I am very impressed with them.
Twojobmick Valued VIP Member
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sun Jan 12, 2014 8:21 am
Very nice those Kevin ... if I didn't have Givi hard bags fitted, I'd have some of those
Psymon Member
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sun Jan 12, 2014 7:55 pm
They look very good indeed! Tempted to look into some for myself as riding with a bag on my back is not the most comfortable thing to do. I have to admit I'm a little put off by having to frill the holes myself. Do you need to fix them that way or can you just use the strap thing under the rear seat? or am I being stupid?
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sun Jan 12, 2014 8:00 pm
Yes the throw over mounts can be used but you must purchase saddlebag mounts to prevent them swinging into the rear wheel. These are typically £50+. I found a couple of grommets and fitted them. In will use electrical tape to close the 1 remaining hole in each side. Rigid mounting is the way to go.
Psymon Member
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sun Jan 12, 2014 11:07 pm
Yeah I have spotted that they're not particularly cheap either.
Might be a silly idea but could you not just attach the mounts that come with it but not bolt them through the bags, then use the over mount strap thing?
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sun Jan 12, 2014 11:10 pm
The way they are mounted is the best way, looks great without any compromise in style.
Psymon Member
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sun Jan 12, 2014 11:16 pm
Not denying this at all! They look absolutely cracking mounted properly. I'm just doubting my own ability to do anything whatsoever!
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Mon Jan 13, 2014 12:24 am
Yeah it could be done like that Dave, Just use 2 of the bars vertically to keep them away from the wheel and the over the fender strap to hold them up height wise, you might need longer fender strut bolts though? to go through the chrome rail and vertical bars, but that's not a problem as most hardware stores will have them in.
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Mon Jan 13, 2014 7:48 am
Don't get hung up about the holes. I haven't. I have removed all of the brass rivets around the holes and ordered rubber blanking grommets to fill in the holes. Will probably just insert and forget.
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Tue Jan 14, 2014 7:56 pm
Depends who's doing it, I suppose.
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Tue Jan 14, 2014 9:06 pm
I would fuck it up Even after watching the video I would still get it wrong. The only way I could do it would be to do one hole at the top first and the put in a temporary bolt just to hold it and then mark around the other top bolting area then find the center of that and keep going. So yeah it does depend on who is doing it but we aint all called Mr I or Simbo or Alfie, some of us are just normal
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Tue Jan 14, 2014 9:11 pm
Normal?????????
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Tue Jan 14, 2014 9:32 pm
Well we like to think we are normal ish
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Tue Jan 14, 2014 9:41 pm
Didn't the original picture of the bags have a lock on them at the top? No big deal, as you could use small pad locks if desired.
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Tue Jan 14, 2014 10:25 pm
Yes i noticed that. No deal breaker. 3 mini brass padlocks for £1 purchased today at land of quid.
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Tue Jan 14, 2014 10:44 pm
I like add ons and I have to say that this is one set of bags that I will certainly buy. Watch this space. Thanks for the heads up Kev. Or should I be cussing you for emptying my wallet? Either way I am so impressed that as soon as I am able to work again, I will have them.
yorky VIP Member
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sun Jan 19, 2014 10:05 pm
Kevin are these bags imported or can we get them in the uk
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sun Jan 19, 2014 10:14 pm
Yes they are ordered and despatched from the UK with no import charges
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sun Jan 19, 2014 10:22 pm
They show a key lock In the advert?
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Mon Jan 20, 2014 6:16 am
Yes mine were probably old stock. I'm not bothered.
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Mon Jan 20, 2014 5:08 pm
Nice bags
DaveC Member
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Mon Jan 20, 2014 6:09 pm
Look very nice fitted
trspsantos Prospect
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sat Apr 01, 2017 3:55 pm
Hey guys!
Does anyone know where can I order these bags?? They seem to out of stock in the UK and they don't ship to Portugal from the US.
Thanks!
P.S.- Does anybody know where the windscreen is from? tks
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sat Apr 01, 2017 9:10 pm
Hi Tiago, Try these? www.motorcyclehouse.co.uk/suzuki-boulevard-m50-saddlebags.htm
Not sure on the screen? Looks like a Memphis Shades going off the brackets?
trspsantos Prospect
Subject: Re: Viking Bags added ................................ to 2013 Suzuki M800 Sat Apr 01, 2017 9:42 pm
Hi Amir, I guess you're right, the screen does look like a Memphis Shades.
I've seen the web site you sent before, they say they are out of stock. The say, 2 to 3 months until restock, but from the replies I saw to someones question, that was long ago already...
I really like the bags (price and stile), but I can't seem to get them anywhere but the US.
