 Fitted suzuki seat cowl on M800 2013
Two-Bears
Doc Cox
Rob Reimer
Jimmyboy
Bigredbus4468
16 posters
Bigredbus4468
Bigredbus4468
Fitted suzuki seat cowl on M800 2013 Empty
PostSubject: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSat Feb 01, 2014 10:28 am
Well it finally came in in the right colour.  Very simple to remove the 2 m6 screwsand refit in the seat cowl.  £53 delivered colour matched.  Love it.  When the weather is better I can take better pics add not enough room or light in the garage.
Fitted suzuki seat cowl on M800 2013 20140201_100205
Fitted suzuki seat cowl on M800 2013 20140201_100305
Fitted suzuki seat cowl on M800 2013 20140201_100327
burgermog46 likes this post
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSat Feb 01, 2014 10:38 am
It looks great Kevin  Fitted suzuki seat cowl on M800 2013 2170595768  The later model m800 looks way better with the seat cowl fitted  Fitted suzuki seat cowl on M800 2013 102087026
Bigredbus4468
Bigredbus4468
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSat Feb 01, 2014 10:42 am
Thanks. The engine is still the same, the chassis is still the same, but this bike appealed to me because of its modern styling.  My buddies 2007 M800 is also a beauty and the speedo is way better as the newer model has a very smallneedle movement between 0 and 40 but I do love it's style.
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSat Feb 01, 2014 11:21 am
Ah yes now that I like. They look so good with the cowl on, very smart.  Fitted suzuki seat cowl on M800 2013 3498837457
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSat Feb 01, 2014 12:09 pm
Looks great Kevin,styling has improved greatly.
Jimmyboy
Jimmyboy
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSat Feb 01, 2014 3:09 pm
Very smart that mate.
Jim.
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSat Feb 01, 2014 4:43 pm
Lovely job Fitted suzuki seat cowl on M800 2013 184121345
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSat Feb 01, 2014 7:10 pm
I love the look so much more with the seat cowls on  Fitted suzuki seat cowl on M800 2013 102087026
Rob Reimer
Rob Reimer
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSat Feb 01, 2014 8:56 pm
Looks good! Fitted suzuki seat cowl on M800 2013 3498837457
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSat Feb 01, 2014 9:05 pm
Looking good Kev!  Fitted suzuki seat cowl on M800 2013 3492671266
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSat Feb 01, 2014 9:13 pm
I agree with the comments above. The M800 is really improved with the seat cowl; the flowing line of the rear is just perfect now.
Bigredbus4468
Bigredbus4468
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSun Feb 02, 2014 10:48 am
here we go its not raining.....
Fitted suzuki seat cowl on M800 2013 20140202_104203
Fitted suzuki seat cowl on M800 2013 20140202_104217
I could do with some 6mm screws with wingnuts on the top to aid quick fitment and swapover.
Found these on ebay but the postage is £10 ouch...
I know they fit as I measured the OEM screws and spoke to the guy...
http://www.ebay.co.uk/itm/161069970372?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSun Feb 02, 2014 11:02 am
Looking good Kevin  Fitted suzuki seat cowl on M800 2013 3492671266
http://www.ebay.co.uk/itm/Threaded-Bar-Studding-Threaded-BAR-ROD-ZINC-PLATED-Sizes-from-M4-upto-M20-/331037558183?pt=UK_DIY_Material_Nails_Fixing_MJ&var=&hash=item4d136045a7
http://www.ebay.co.uk/itm/Gibraltar-SC-13P3-6mm-Heavy-Duty-Wing-Nut-Pack-of-2-/191030011038?pt=UK_Musical_Instruments_Drums_Percussions_MJ&hash=item2c7a46a49e
Bigredbus4468
Bigredbus4468
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSun Feb 02, 2014 11:06 am
Ideal. How do I fix the wingnut to the thread bar so that it becomes a screw?
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSun Feb 02, 2014 11:12 am
A drop of threadlock  Fitted suzuki seat cowl on M800 2013 3498837457
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSun Feb 02, 2014 4:16 pm
Or drill it through & use a split pin or R clip, job done but then thats my look on it obviously.
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSun Feb 02, 2014 6:49 pm
I would probably go with Peters idea ideally but ease would probably send me Sim's way, both good suggestions though.  Fitted suzuki seat cowl on M800 2013 3498837457
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSun Feb 02, 2014 10:16 pm
I think threadlock would be the way to as if it was drilled and split pinned or an "R" clip there is a possibility of it rusting, but, make sure you wipe any excess threadlock off if you go that way  Fitted suzuki seat cowl on M800 2013 696333
Two-Bears
* VZ Guru *
Two-Bears
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeMon Feb 03, 2014 7:12 am
Hi kevin,
If you had some Plastic Shapelock Instamorph Pellets  you could have made your own thumb bolt,
http://www.ebay.co.uk/itm/Friendly-Plastic-Shapelock-Instamorph-Pellets-500g-Easy-To-Colour-Reusable-/170720943663?pt=UK_Crafts_Other_Crafts_EH&hash=item27bfc2de2f
If you know the thread size you want try these people, I`ve used them before and you can get a pack of 6 for £9 free post,
http://stores.ebay.co.uk/RGS-Technical-Services/Wing-Knobs-Thumb-Screws-/_i.html?_fsub=3228460014&_sid=439016934&_trksid=p4634.c0.m322
Hope it`s of some helps mate.
Bigredbus4468
Bigredbus4468
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeMon Feb 03, 2014 7:26 am
John you are a star. Looked very close and after measuring, I ordered these
offset wingnut
Two-Bears
* VZ Guru *
Two-Bears
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeMon Feb 03, 2014 8:46 am
Good for you mate,, will make things a little easier for you.
Keith81
Keith81
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeFri Jan 16, 2015 7:31 pm
Hi Kevin, I know this is an old post but can you remember where you bought the seat cowl from? I am after one in the same colour. I think your bike looks great by the way. Thanks in advance, Keith
Bigredbus4468
Bigredbus4468
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeFri Jan 16, 2015 8:32 pm
Its a Suzuki cowl at about £50 colour matched from any dealership.
Keith81
Keith81
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeFri Jan 16, 2015 9:46 pm
Thanks for the info Kevin, that sounds great Fitted suzuki seat cowl on M800 2013 3498837457
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeFri Jan 16, 2015 10:06 pm
I notice that you are a full member now Keith, have you tried going into the site shopping mall yet? Click on the Member Discount area and then Metric cruisers as they sell them too. Don't know if they do them in the blue you are after, but its worth a look see!  Fitted suzuki seat cowl on M800 2013 3498837457
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeSat Jan 17, 2015 2:57 pm
Beat me to it Skid!
Keith81
Keith81
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeMon Jan 26, 2015 5:25 am
Thanks for the advice, I have tried the Member Discount area but it looks as though its still restricted to my level of membership. I will look into upgrading my account.
burgermog46
PostSubject: Rear seat cowl.   Fitted suzuki seat cowl on M800 2013 Icon_minitimeFri Oct 30, 2020 8:59 pm
I have just fitted one on my m800 but there is about half inch gap all the way round.any ideas.steve.
hazqaz
PostSubject: Re: Fitted suzuki seat cowl on M800 2013   Fitted suzuki seat cowl on M800 2013 Icon_minitimeMon Feb 01, 2021 11:33 am
Hi guys, can anyone share the link to buy the Cowl for my M800 2014. I Just cant find it !!
» Single seat cowl 2011 Suzuki M800 / M50
» M800 seat cowl.
» New m800 seat cowl
» Rear Seat Cowl for M800 and M50
» New Seat for Suzuki M800
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Fitted suzuki seat cowl on M800 2013 Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
