| which exhausts | |
+5Kfc1404 smart Mr Intruder simbo dilligaf 9 posters | Author | Message |
dilligaf Member
| Subject: which exhausts Mon Mar 17, 2014 6:00 pm | |
| Hi all , firstly sorry for the long absence , boy is 3 in june , say no more . good to be back and yes ive still got MY baby , 2010 c800 intruder with 2 oxygen censors is a effin nightmare to get aftermarket pipes for , im looking at cobra streetrods at the mo but would love any advice before I take the plunge , ie price , quality , sound and looks , cheers and sorry for the absence | |
| Subject: Re: which exhausts Mon Mar 17, 2014 6:21 pm | |
| Hi John, Get rid of the oxygen sensors, then you can have whatever pipes you desire | |
| | | | dilligaf Member
| Subject: Re: which exhausts Mon Mar 17, 2014 8:34 pm | |
| Roofers work with wood and stone, and ride bikes, not evolved enough to know about metal and snipping wires yet, I can get the cobra streetrod pipes from metric cruisers with 2 oxygen censor holes for £475 and my mot is due so I was gonna get York suzuki centre to kill 2 birds with one stone, Which one is quickest and easiest. | |
| Subject: Re: which exhausts Mon Mar 17, 2014 9:22 pm | |
| Quickest and easiest is?, Order pipes fitted with oxygen sensors, then take to main dealer and have them fitted whilst having the bike MOT'd, It'll just cost more though. | |
| | | dilligaf Member
| Subject: Re: which exhausts Mon Mar 17, 2014 10:05 pm | |
| I'll chew it over but really appreciate the advice, cheers, I'll let you know the outcome, Must get some updated pics of my bike on here, it's changed a bit since that pic | |
| Subject: Re: which exhausts Mon Mar 17, 2014 10:19 pm | |
| Looking forward to the updated pics John Probably meet up at Squires over the year if you get down there? | |
| | | dilligaf Member
| Subject: Re: which exhausts Mon Mar 17, 2014 10:22 pm | |
| Yeah no problem, be good to get A ride out again | |
| | | smart Valued Member
| | | | dilligaf Member
| Subject: Re: which exhausts Wed Mar 19, 2014 8:03 am | |
| hi smart , dilligaf all the way mate | |
| | | Kfc1404 Member
| Subject: Re: which exhausts Wed Mar 19, 2014 8:13 am | |
| | | oiler Saint Oiler the 1st
| Subject: Re: which exhausts Thu Mar 20, 2014 8:34 am | |
| I'm about to invest in Hard Krome all black pipes for my new baby. Can't find any heat shields in black to match pipes (and don't want to burn my trousers/legs again like I did on last 800 with HH pipes. Any ideas, where to go ? Thanks. ps The HK pipes are double skinned, but so are stock pipes, and they have a heat shield on upper pipe. Do I really need a heat shield ? | |
| | | Kfc1404 Member
| Subject: Re: which exhausts Thu Mar 20, 2014 8:49 am | |
| Have you looked at these? Maybe not the exact part for your bike but, I'm sure they are available.
http://www.ebay.co.uk/itm/VZ800-Marauder-SHAFT-M800-Intruder-BLACK-SLASHCUT-EXHAUST-Vance-Hines-48293-/131072300418?pt=UK_Motorcycle_Parts_13&hash=item1e84849582 | |
| Subject: Re: which exhausts Thu Mar 20, 2014 9:01 am | |
| Thanks for that, Graham. Those V&H pipes are exactly what I wanted, but the Suzuki dealer says they're not made for the 2014 C800. So Hard Krome is my second best choice. Thanks tho. | |
| | | Kfc1404 Member
| Subject: Re: which exhausts Thu Mar 20, 2014 9:13 am | |
| I got them on my 2013 M800 | |
| Subject: Re: which exhausts Thu Mar 20, 2014 9:32 am | |
| What a difference a year makes. ! | |
| Subject: Re: which exhausts Thu Mar 20, 2014 10:15 am | |
| Those pipes will fit your bike Clive. | |
| Subject: Re: which exhausts Thu Mar 20, 2014 5:52 pm | |
| :what1: Tell the dealer to learn what he is talking about before teaching grannies how to suck eggs. Of course the will fit. Right the only thing he can be talking about is the fact that they don't have a CO2 sensor boss. Well if you really want the CO2 sensors fitted, simply have a boss welded on to the pipes. Normally I would say get the dealer to do that but I think if that is what you want, I would be inclined to go elsewhere because they obviously have untrained monkey's working for them. What I would do is simply have them fitted either but a trained monkey or fit them yourself & then simply cut wire #23 at the ECU so that the bike doesn't think there is a fault with the CO2 sensors & illuminate the FI light by mistake. Then simply unplug the CO2 sensor cables. | |
| | | Kfc1404 Member
| Subject: Re: which exhausts Thu Mar 20, 2014 6:31 pm | |
| Mine came with the sensor fittings already in place. Talk to Metric Cruisers. They are good guys. | |
| | | azcam Valued Member
| Subject: Re: which exhausts Thu Mar 20, 2014 6:53 pm | |
| K02 Silvertails. Come with the O2 ports and blanking Bolts if you decide to get rid of them. | |
| Subject: Re: which exhausts Thu Mar 20, 2014 7:53 pm | |
| Lot's of pipes come with them already fitted but if the pipes anyone decides to fit do not have them fitted and they are pre CO2 sensor pipes, a boss is easily fitted or the removal of the CO2 sensors is very easy. It can work out a darn site cheaper in some cases to buy pipes that have no CO2 sensor bosses fitted and have them fitted ones self if a user requires on a personal level to keep the CO2 sensors rather than remove the CO2 sensor. | |
| Subject: Re: which exhausts Thu Mar 20, 2014 10:12 pm | |
| Many thanks for all the advice | |
| | | dilligaf Member
| Subject: Re: which exhausts Fri Mar 21, 2014 10:14 pm | |
| gone for the vance and hines staggered slash cuts , getting fitted on Thursday , ill let you know if they are grin factor or frown factor | |
| Subject: Re: which exhausts Sat Mar 22, 2014 7:09 am | |
| They will be grin factor 10. | |
| | | Kfc1404 Member
| Subject: Re: which exhausts Sat Mar 22, 2014 7:45 am | |
| Mine are superb, although I did fit the quiet baffles, gives a lower, softer note which I prefer! | |
| Subject: Re: which exhausts Sat Mar 22, 2014 11:39 am | |
| Those pipes look superb. I'm getting a problem with sourcing the Hard Krome pipes, so if these come in black,and fit my 2014 800 !! | |
| | | Kfc1404 Member
| Subject: Re: which exhausts Sat Mar 22, 2014 11:41 am | |
| Metric Cruisers in Bournemouth did have the black ones in stock! http://www.metriccruisers.co.uk
Actually, I think these are the ones you are looking for!
http://www.metriccruisers.co.uk/acatalog/exhausts_vz800_marauder.html
Good luck!
Regards
Graham | |
| Subject: Re: which exhausts Sat Mar 22, 2014 1:50 pm | |
| Ta for info, will talk to them | |
| Subject: Re: which exhausts Sat Mar 29, 2014 9:39 am | |
| Oxygen sensors v No oxygen sensors. What's the difference ? | |
| Subject: Re: which exhausts Sat Mar 29, 2014 1:53 pm | |
| Subject: Re: which exhausts Sat Mar 29, 2014 7:11 pm | |
| Yes it is has a tiny effect on the emissions and I do mean tiny but only on tickover and low revs and it also reduces the power a tiny amount at low revs as well. | |
| Subject: Re: which exhausts Sat Mar 29, 2014 9:29 pm | |
| Fekin EU doing a bit of serious over kill, waist of friggin metal. :moon: | |
| Subject: Re: which exhausts Sat Mar 29, 2014 9:47 pm | |
- Fekin EU doing a bit of serious over kill, waist of friggin metal. :moon:
That's not actually true Dave? The o2 sensors are actually the same thread as a 800 sump bolt, So as a desperate measure they could be used as an emergency substitute | |
| Subject: Re: which exhausts Sun Mar 30, 2014 4:29 pm | |
| Sim sounds like a genius. Bet he understands e=mc2 as well | |
| Subject: Re: which exhausts Sun Mar 30, 2014 4:56 pm | |
| Well if he doesn't Doc Cox will. | |
| Subject: Re: which exhausts | |
| | | | which exhausts | |
