 Front brakes
Steen G
TwinDad
9 posters
TwinDad
TwinDad
Front brakes Empty
PostSubject: Front brakes   Front brakes Icon_minitimeMon Mar 24, 2014 8:49 am
Hi all anyone thought about changing front calliper? Putting twin discs on?
Many thanks Front brakes Imagegif
Sorry if this has been done to death!
Steen G
Steen G
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeMon Mar 24, 2014 10:38 am
Yes, I've started collecting parts to do it. Only needs a few bolts and some custom made brake lines.
I'm a Tool-maker so I don't think the machining will cause any trouble  8)
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeMon Mar 24, 2014 4:35 pm
er I think you'll find it hard to do on a VL as the hub won't take another disc. You may have to look out for a 1500 etc front end complete with wheel, disc's, forks etc... Could be expensive!
Steen G
Steen G
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeMon Mar 24, 2014 6:41 pm
Didn't notice it was for a VL800. I've got a VZ 800 Marauder that makes it a lot easier.
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeMon Mar 24, 2014 8:11 pm
can i ask how Steen? i ask as i have just bought a vz front wheel for my c800/vl800.
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeMon Mar 24, 2014 9:43 pm
Sorry if I'm missing something obvious but why the heck would you need a second disc on the front?  Front brakes 1337224149
TwinDad
TwinDad
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeMon Mar 24, 2014 10:17 pm
Just seen the light and moved over from sports bikes not trying to do stoppies but as vl only has drum  and twin pot front single disc was just a thought
Thanks
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeMon Mar 24, 2014 10:31 pm
Fair play Sir :]
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeMon Mar 24, 2014 10:43 pm
To stop the bloody thing! lol The brakes on the Intruder aren't know for their stopping power at all  Front brakes 249703  fitting double discs is something that's way beyond my capabilities but I'd certainly have a go if it was a proven mod, All things come from idea's  Front brakes 3993731222
TwinDad
TwinDad
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeMon Mar 24, 2014 10:57 pm
Thought you may have to give the VL800 a written invite to stop. Nothing wrong with that just have to adjust my riding style, or look at a three pot brembo on the front
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeMon Mar 24, 2014 11:10 pm
Thinking about it I don't think I ever had to emergency brake so far.
I ride calmly, brake with engine and always leave ton of space up front.
Need to try to proper stop and see what the brake is like if you're saying it's so bad.
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeMon Mar 24, 2014 11:56 pm
Squeeze the front brake to hard and it will lock up, how much more braking does someone need  :what1:
Steen G
Steen G
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeTue Mar 25, 2014 6:59 am
You need to drill holes in the front wheel and the left fork leg. Discs comes from a VZ 800/GSXR400(GK76)/RGV250 and the left caliper from a SV 650.
Why I'm doing it?
Because it's my bike and I like the looks of the dual discs and it makes it more symmetrical.
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeTue Mar 25, 2014 2:52 pm
Good answer Steen,straight to the point. Front brakes 2645662097  Front brakes 2215087486
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeTue Mar 25, 2014 4:01 pm
Makes sense to me  Front brakes 184121345
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeTue Mar 25, 2014 5:17 pm
I'll wait till you put some pictures up of the conversion Steen before I make anymore comments.
TwinDad
TwinDad
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeTue Mar 25, 2014 5:29 pm
Steen, good to know someone feels the same way! Front brakes 1218875559
Would like to hear how things go.
Good luck
raffaele.negrin
raffaele.negrin
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeThu Dec 11, 2014 10:17 am
Hey there, I was thinking of doubling the discs on my M800 (2012) too, I'd like some expert comments on what I thought:
front fork on my bike has 41mm inverted fork, so my first idea was to only change the left tube with one that allows the fitting of a disc, caliper, etc.
I assume this would mean changing the wheel as well, along with brake line (to double it etc). So that requires finding the damned tube, but I can't - not on the 'net, at least -_-'
Second idea: find an old bike with 41mm inverted fork and double disc, remove both tubes + front brake circuit (assuming the discs are 300mm) and install on my bike (with new wheel). Trouble is: I fail to find this information. I found a few places listing bike with 41mm forks, but they don't specify if they're regular, inverted, or something entirely different. Plus I would have to look at each and every one to find which ones have double discs (so two cross-referencing "trips" for each bike).
One more problem: I would assume that tube length is also an issue - enduro and trial bikes, for instance, would have longer tubes, right? - but that's another piece of information that's hard to find (I don't even know how long the tubes are on my own ride!!!)
So, what do you all think?
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeThu Dec 11, 2014 8:02 pm
I tried to figure some of the same info as You Raph but gave up in the end!
I feel you will have to look around bike breakers yards for a complete front end off something else OR look to the bigger twins as they have twin disk set ups already & you may come across a wrecked bike with a complete front end???
raffaele.negrin
raffaele.negrin
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeThu Dec 11, 2014 11:15 pm
Thanks Peter, I was afraid of that. I've asked my mechanic for more ideas (and/or parts that he may be able to get from Suzuki...), we'll keep looking.
BTW Steen, have you finished modifying your Marauder? Pictures, maybe?
Steen G
Steen G
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeMon Dec 15, 2014 7:50 pm
Haven't even started modifying it yet, wife thinks a new kitchen is more important Front brakes 3213823784
Winter is long in Denmark so it wont be ready before spring, I'll try to remember capturing some pictures while converting the bike.
raffaele.negrin
raffaele.negrin
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeTue Dec 16, 2014 12:14 am
Front brakes 3768075377
81ker
Front brakes Empty
PostSubject: Re: Front brakes   Front brakes Icon_minitimeMon Jul 05, 2021 5:11 pm
Used to own a 1997 vz800 that someone had done a twin disc conversion on,would stop on a penny. looking to do the same on my new marauder       Front brakes 11280911Front brakes 11280910
Front brakes Empty
Front brakes
» M50 - changed brakes
» vz800 front brakes
» New rubber and brakes for safety this season...
Front brakes Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Front brakes Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Front brakes Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Front brakes Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Front brakes Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Front brakes Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Front brakes Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Front brakes Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Front brakes Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Front brakes Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Front brakes Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Front brakes Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Front brakes Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Front brakes Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Front brakes Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Front brakes Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Front brakes Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Front brakes Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Front brakes Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Front brakes Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
