| | Handle bar weights | |
shwb01 Member
| Subject: Handle bar weights Fri Mar 28, 2014 2:39 pm | |
| My Handle bar weight is damaged, an ideas where I can get replacements? Where would I find a suzuki part number? Also Headlight cowl damaged OMFG £110 for a replacement. | |
| Subject: Re: Handle bar weights Sun Mar 30, 2014 7:16 pm | |
| My apologies for not seeing this post before now Steve, the part number you require is 56200-10890. Just pop into your local dealer and give them that number and they will order it for you, might be better than sources it yourself, it will cost you about £40, they are also known as balancers. Hope this has helped. | |
| | | shwb01 Member
| Subject: Re: Handle bar weights Mon Mar 31, 2014 6:36 pm | |
| Many thanks, I have now lined some up, again these are quite pricey at £46.00 I had forgotten how expensive Japenese spares were, in the early seventies I remember a honda indicator set was 25% of my weekly wage. | |
| Subject: Re: Handle bar weights | |
Latest topics | » Hello by PETE.MARTIN Mon Sep 02, 2024 12:19 pm
» New Member by LordSweeteffall Fri Aug 23, 2024 1:58 am
» Howdy by Philly_pa800 Fri May 24, 2024 8:16 pm
» VZ 800 K7 by Barwise92 Tue May 21, 2024 2:53 pm
