 Exposed shocks and Pipe Wrap....2002 Marauder VZ800
5 posters
CanadianCruiser
CanadianCruiser
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Empty
PostSubject: Exposed shocks and Pipe Wrap....2002 Marauder VZ800   Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeThu May 15, 2014 1:18 am
Well Gents it's been awhile... Hope everyone is doing good and enjoying some ride time...anyways thought I would post some minor things I've done...
First off Exposed shocks... Love them, Don't know why we don't have them... So I made them!  Really easy..
1) Adjust shock to the lowest (softest) setting, and remove shock assembly.
2) The top of the shock is just screwed on the shaft with a lock nut keeping it in place. Somehow wedge the cover down a bit, and shove a 17mm box end wrench in there and loosen the lock nut. Then spin off the top.
3) Now chase down the parts that shot all over the garage. :) You will have the following parts;
- The shock with the bottom mount on the shock body, and a threaded shaft coming up.
- The spring. Late models are painted black and tight. Early models are not painted, and a little looser.
- The top chrome cover. This will be removed.  It makes a very cool chrome beer holder.
- The bottom chrome cover. It is slightly smaller than the top, and slides inside it.
- The chrome adjuster cover. About an inch and a half tall. Covers the adjuster.
- The top mount, and lock nut. (Actually the lock nut is probably still on the threaded shaft...)
Remove the big top cover. You will use the small cover in it's place. This is because the lip on the top mount is not solid enough to hold the spring. The chrome covers are also spring mounts... So with the bottom on the top,(I cut it to the same length as the Adjuster sleeve just to match.) and the adjuster cover on the bottom, you still have solid mounts, but just over half the spring is not exposed.
4) Reassemble, and tighten the lock nut.
5) Reinstall.
6) Have beer in new chrome beer holder lol...
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Img_0811
Some other mods... Forward controls and pipe wrap...
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Img_0812
PostSubject: Re: Exposed shocks and Pipe Wrap....2002 Marauder VZ800   Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeThu May 15, 2014 7:49 am
Looking real good CC, love it.  Exposed shocks and Pipe Wrap....2002 Marauder VZ800 3498837457
PostSubject: Re: Exposed shocks and Pipe Wrap....2002 Marauder VZ800   Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeThu May 15, 2014 6:12 pm
That looks very nice, great job and well explained. Interesting read  Exposed shocks and Pipe Wrap....2002 Marauder VZ800 2170595768  Exposed shocks and Pipe Wrap....2002 Marauder VZ800 3322349030
PostSubject: Re: Exposed shocks and Pipe Wrap....2002 Marauder VZ800   Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeThu May 15, 2014 7:02 pm
Good job CC I prefer the look of the exposed shock  Exposed shocks and Pipe Wrap....2002 Marauder VZ800 2170595768  3) chase down parts that shot all over the garage  Exposed shocks and Pipe Wrap....2002 Marauder VZ800 2740622253
PostSubject: Re: Exposed shocks and Pipe Wrap....2002 Marauder VZ800   Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeThu May 15, 2014 7:37 pm
Fine work done.
PostSubject: Re: Exposed shocks and Pipe Wrap....2002 Marauder VZ800   Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeThu May 15, 2014 10:03 pm
Very well done.  Exposed shocks and Pipe Wrap....2002 Marauder VZ800 996187811
» clutch slip - 2002 Suzuki VZ800 Marauder
» Pics of my bike...... 2002 Suzuki VZ800 Marauder
» Installed custom made MB shocks to Suzuki Marauder VZ800Y
» VZ800 rear shocks
» 2002 Marauder Rider from Canada
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby Jack70 Yesterday at 4:35 pm
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Exposed shocks and Pipe Wrap....2002 Marauder VZ800 Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
