 Large home made screen
10 posters
Large home made screen Empty
PostSubject: Large home made screen   Large home made screen Icon_minitimeWed May 28, 2014 9:30 pm
Admin - Topic made by splitting it from another so that the thread would not get lost in time
Was looking at screens on Egay...my screen is a bit on the small side and doesn't give much protection.
But all very pricey.
So  had a Google  and found a supplier of cut to size plastic in Leeds  ( 12 miles away ). £10 for a piece of 500mm x 500mm x 3mm polycarbonate.
Couple of hours drilling, sawing and filing and now have larger screen using original frame
If its dry I'll test it tomorrow ( hope 3mm in thick enough )
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeWed May 28, 2014 9:52 pm
Sounds like a good call! Does the metalwork pull the Perspex into a slight curve? If so that would make it  stronger than just a flat plane I'm guessing....
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeWed May 28, 2014 10:08 pm
Photos please,could be a good mod to copy.
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeWed May 28, 2014 10:20 pm
Mal...yes the frame has a slight curve.
Alfie you are stretching my technological skills...I'll ask the daughter to show me how to do it  ( again )
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeThu May 29, 2014 3:52 pm
Cheers Alan.
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeThu May 29, 2014 4:22 pm
Alfie heres hoping....
Large home made screen Screen1002_zpsf2d3e814
shows old screen on top of new.
Took old screen off the frame and used it to mark out mounting holes for drilling.
Used various paint tins and pans to draw round to get the curves and cut them out with a coping saw with fine teeth.
Then various files to clean up the cuts and finally sandpaper to smooth ( dont get sanpaper in wrong place as leaves a horrible scratch.
Note should have asked Sim at the start 4mm would have been better than the 3mm...but I'll see how it goes. If I have to redo it 4mm at £10 its not the end of the world.
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeThu May 29, 2014 5:03 pm
Nice job Alan! I'm impressed  Large home made screen 2170595768 Should be far more effective than your old screen.
PostSubject: Larger home made screen   Large home made screen Icon_minitimeThu May 29, 2014 5:58 pm
Great great job.... Boy that shows some patience doing it old Skool with a coping saw!!
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeThu May 29, 2014 7:41 pm
Ace job being done Alan, good thinking  Large home made screen 2170595768  Large home made screen 276246
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeThu May 29, 2014 10:29 pm
Well done Alan,thanks for sharing,certainly must of took some patience
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeFri May 30, 2014 10:04 am
Looking good Alan, be interesting the differences found after a test run. Fitting some home made lowers to that screen will stop any wind in a massive way. Good thinking that.  Large home made screen 2170595768
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeFri May 30, 2014 1:04 pm
Cheers Mr Intruder and Co...........Had the test run....better than small screen...less wind on chest and arms plus no dreaded head rattling.
Screen vibrates at tick over but o.k. at speed... 70 on motorway...no flexing or bending...I think I will get away with the 3 mm thickness.
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeFri May 30, 2014 3:09 pm
That sounds a brilliant result, nice one Alan  Large home made screen 184121345
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeFri May 30, 2014 4:44 pm
That's good to read that your test run was favourable, nice job. Never thought of changing the screen & using the mountings off an existing one. Simple but affective mod, might change mine on a black black bike for a dark tinted screen in time after you have done that & got me thinking for the future.  Large home made screen 3498837457
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeFri May 30, 2014 7:00 pm
Very clever thinking, must make a big difference.
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeFri May 30, 2014 9:53 pm
, might change mine on a black bike for a dark tinted screen in time after you have done that & got me thinking for the future.  Large home made screen 3498837457
Now that's an interesting idea! Black screen! or dark lower half! I wonder if it would reduce the refection in sunny weather? Interesting thoughts there Dave  Large home made screen 3498837457
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeFri May 30, 2014 11:17 pm
Look forward to seeing that on Sunday Al !
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeFri May 30, 2014 11:22 pm
And I thought you only had eyes for me?? Huh! Your such a slag Mick!  Large home made screen 852880
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeFri May 30, 2014 11:27 pm
I wonder how would a DIY screen work if it was cut out in a pattern... ie. flames :)
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeSat May 31, 2014 8:22 am
Guilty as charged, yer 'onour  lol!
Asmotsat
PostSubject: Re: Large home made screen   Large home made screen Icon_minitimeWed Jun 18, 2014 3:34 pm
Good looking screen Yorky.
» Home made ape hanger handle bar screen, possible idea.
» Home made Ape Hanger wind Deflector / Screen - 2010 Suzuki C800 / C50
» Home Made Aluminum Lowers
» Home made brackets for panniers on C50
» Home made Flag & Pole
Suzuki 800 Intruder Club & Forum :: The Garage :: Screens, Lowers & Wind deflectors.-
Large home made screen Icon_minitimeby Jack70 Today at 4:35 pm
Large home made screen Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Large home made screen Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Large home made screen Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Large home made screen Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Large home made screen Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Large home made screen Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Large home made screen Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Large home made screen Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Large home made screen Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Large home made screen Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Large home made screen Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Large home made screen Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Large home made screen Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Large home made screen Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Large home made screen Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Large home made screen Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Large home made screen Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Large home made screen Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Large home made screen Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
