 2 Stroke help please.
4 posters
2 Stroke help please. Empty
PostSubject: 2 Stroke help please.   2 Stroke help please. Icon_minitimeThu Aug 14, 2014 7:07 am
Not sure if anyone knows about 2 strokes but my son has a 50cc 2 stroke Derbi Senda X-Treme SM, for the moment we are using pre-mix as I am not convinced the oil pump is working properly for the 2t oil.
The oil pump is on the side of the engine and is controlled by the throttle cable (comes from the throttle and then splits into two, one cable goes to the carb and the other to the oil pump).
To prime the oil line you let the engine tick over and manually operate the cable, you can see the oil going up the tube to the carb a little bit at a time which is fine , you do this until it is all the way to the carb. Problem is that when you come back to it a couple of days later it needs priming again which is not so good. I can not see any oil leaks, any ideas?
PostSubject: Re: 2 Stroke help please.   2 Stroke help please. Icon_minitimeThu Aug 14, 2014 7:36 am
no idea at all just a complete gess is there an air lock in the tube? try bleeding it and see what happens soory not a lot of use bin a long long time since I had a 2 stroke lol RD125 what a bike  2 Stroke help please. 852880
PostSubject: Re: 2 Stroke help please.   2 Stroke help please. Icon_minitimeThu Aug 14, 2014 7:16 pm
Hi Andrew, after starting the bike, how long does it take for the oil to reach the end of the pipe after it's rested a couple of days?, Things to check are..Oil hose blocked or kinked? release it and see if oil flows freely, air hole in oil cap blocked causing a vacume? try it with cap released to allow air in the tank , Have you bled the pump properly till all air bubbles have gone? Is there a bleed screw on the pump as well as letting it pump out of the end of the pipe?
PostSubject: Re: 2 Stroke help please.   2 Stroke help please. Icon_minitimeThu Aug 14, 2014 7:25 pm
It takes about 5 min to fill the tube, I have ordered some new pipe and found a secondhand pump on ebay (I can keep it as a spare or whack it back on ebay if I get it sorted), Its off the road at the moment as the water pump srung a leak, which is now fixed.
Pulled the pump oil feed and it flows freely, bleed screw was removed etc and the pump primed.
Good shout re oil tank cap, I will have to check that, I have had that on a petrol cap before, but it was obvious when you undone the cap as it started hissing!!
PostSubject: Re: 2 Stroke help please.   2 Stroke help please. Icon_minitimeThu Aug 14, 2014 7:42 pm
Keep us informed  2 Stroke help please. 3498837457   It's nearly30 yrs since I had my grubby little fingers on an auto lube system  2 Stroke help please. 852880
rossmofo
rossmofo
PostSubject: Re: 2 Stroke help please.   2 Stroke help please. Icon_minitimeWed Apr 01, 2015 8:46 am
Stick a malossi cylinder kit on it and keep mixing in the tank ....I always disconnected the auto lube systems on all my 2/strokes ...had one fail on a vespa and never trusted them since... always use a quality oil like silkolene and not that castrol rubbish ....
» * White Wall Tyres At The Stroke Of A Brush Suzuki C800 / C50 *
Suzuki 800 Intruder Club & Forum :: The Garage :: Non Suzuki-800 related Bikes, Mod's & Project's-
2 Stroke help please. Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
2 Stroke help please. Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
2 Stroke help please. Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
2 Stroke help please. Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
2 Stroke help please. Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
2 Stroke help please. Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
2 Stroke help please. Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
2 Stroke help please. Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
2 Stroke help please. Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
2 Stroke help please. Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
2 Stroke help please. Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
2 Stroke help please. Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
2 Stroke help please. Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
2 Stroke help please. Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
2 Stroke help please. Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
2 Stroke help please. Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
2 Stroke help please. Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
2 Stroke help please. Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
2 Stroke help please. Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
2 Stroke help please. Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
