 CLUTCH LEVER SPAN REDUCTION MOD
5 posters
Rick9000
Rick9000
CLUTCH LEVER SPAN REDUCTION MOD Empty
PostSubject: CLUTCH LEVER SPAN REDUCTION MOD   CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeWed Sep 10, 2014 11:29 am
Having the same problem as a few others in that the clutch lever is too far from the bar with no adjustment to make operation comfortable I have come up with a simple mod for our bikes.
On the clutch lever there is a metal tab on the underside which operates the clutch interlock switch. What I have decided to do is to drill a small hole in the tab and insert a machine screw with a nut either end to secure. In hindsight it would probably be better to tap this hole for easier adjustment. The screw can then be used to move the clutch lever nearer the bar.
You need to loosen the clutch cable off then readjust when you find a comfortable lever span. I moved mine 1/4 " and it is now so much easier to operate.
The clutch friction zone only takes up a small amount of the lever movement so I have had no problems with slippage or gear shifting.
I may not have explained this very well but have attached a few images which may help
CLUTCH LEVER SPAN REDUCTION MOD Imagejpg1_zpsc66c4881
This shows the adjustment screw from the top
This shows the underside with the adjustment screw sitting above the plunger to operate the clutch switch.
CLUTCH LEVER SPAN REDUCTION MOD Imagejpg5_zpsc8e6cf06
This show the amount of adjustment I made.
This is a quick and simple mod which I have found works perfectly well
Rick9000
Rick9000
PostSubject: Re: CLUTCH LEVER SPAN REDUCTION MOD   CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeWed Sep 10, 2014 11:32 am
Sorry underside photo attached.
CLUTCH LEVER SPAN REDUCTION MOD Imagejpg4_zpsbd0481ce
PostSubject: Re: CLUTCH LEVER SPAN REDUCTION MOD   CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeWed Sep 10, 2014 11:49 am
Hey Ricky,
Sound idea ! ... I fully understand what you have done & why. nicely illustrated with helpful photos. I agree with your comment re-possibly better to tap a thread in the tab, but it would be best to keep a lock nut on the machine screw you made your adjuster from.
You've covered the angle of clutch actuation range so all should be well.   lgd
In the olden days people use to go to dog leg levers to achieve the same ends !
CLUTCH LEVER SPAN REDUCTION MOD 3005623951 Yam
PostSubject: Re: CLUTCH LEVER SPAN REDUCTION MOD   CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeWed Sep 10, 2014 4:55 pm
Nice one Ricky  CLUTCH LEVER SPAN REDUCTION MOD 184121345
PostSubject: Re: CLUTCH LEVER SPAN REDUCTION MOD   CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeWed Sep 10, 2014 6:17 pm
Good thinking Ricky, good 1  CLUTCH LEVER SPAN REDUCTION MOD 2170595768
brains
brains
PostSubject: Re: CLUTCH LEVER SPAN REDUCTION MOD   CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeMon Nov 10, 2014 5:27 pm
quicker solution is to fit a rubber grommet over the cable between the lever & the mount to act as a buffer
» Black clutch lever
» adjustable clutch lever.
» Help with clutch - C50
» Gear lever
» vs800 Clutch
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
CLUTCH LEVER SPAN REDUCTION MOD Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
