 bag supports
rdt1157
6 posters
rdt1157
rdt1157
bag supports Empty
PostSubject: bag supports   bag supports Icon_minitimeSun Sep 14, 2014 8:21 pm
hi I bought saddleman cruiser bags for my 800 from metric cruisers. bolted them on. about 2.5 inches from the pipes been on for 6 months. noticed the other day the one on the pipe side had sagged on the bottom and stuck to the top pipe due to the heat. so now have a 2" burn on the bag and to ages to clean the pipe. is there a bag support I can get that supports the underneath of the bag from sagging
b
bag supports Empty
PostSubject: Re: bag supports   bag supports Icon_minitimeSun Sep 14, 2014 8:48 pm
Could you not fix a solid base inside to stop them sagging? bit late now but a layer of aluminium ducting tape on the bottom would have reflected the heat of the exhausts away and protected the leatherette in the case of it still sagging.
bag supports Empty
PostSubject: Re: bag supports   bag supports Icon_minitimeSun Sep 14, 2014 9:22 pm
I agree with Simbo,one way of doing it is to cut an old computer case to the shape you need,you can either rivet it to the base of your bag or zip tie it,or use a piece of plywood and either screw or zip tie it.
bag supports Empty
PostSubject: Re: bag supports   bag supports Icon_minitimeMon Sep 15, 2014 7:37 am
Happened to me back in the eighties on my Katana.  Got a piece of vinyl & glued it to a piece of ply that was cut to a tight fit.  Covered the hole & strengthened it enough to stop it sagging
bag supports Empty
PostSubject: Re: bag supports   bag supports Icon_minitimeMon Sep 15, 2014 8:09 am
Must agree with the others, strengthen up the bottom by putting a thin plate in. Even the apparently strongest & stiff leather will eventually bow.
bag supports Empty
PostSubject: Re: bag supports   bag supports Icon_minitimeMon Sep 15, 2014 10:18 am
I have used car engine panel heat reflective stick on panel to my offside bag but it still got hot enough to melt zip ties & plastic bags inside the bag!
I'll be raising the bags as far as I can when I get round to it probably next month?
bag supports Empty
bag supports
» Saddle bag Supports for Suzuki M800 / M50
» Poppy bike rear fender supports
bag supports Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
bag supports Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
bag supports Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
bag supports Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
bag supports Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
bag supports Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
bag supports Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
bag supports Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
bag supports Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
bag supports Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
bag supports Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
bag supports Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
bag supports Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
bag supports Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
bag supports Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
bag supports Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
bag supports Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
bag supports Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
bag supports Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
bag supports Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
