 I made the cheapest driver backrest pad for the M800
DaveC
TaurusTuga
13 posters
TaurusTuga
TaurusTuga
I made the cheapest driver backrest pad for the M800 Empty
PostSubject: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeSun Sep 21, 2014 9:36 pm
Parts required for the project:
A pad from an old chair, a piece of chipboard cut foam to line the back with synthetic leather, stapler, screws, nuts, washers, 2 pieces of metal drilled and bolted to join the pad inside the spring that opens the seat, plastic bellows taken of an old office chair. A screw adjustment to tilt forward and serve as a stop for the pad.
Tip: Stapling the pad inside all the way around with a strip of leather folded for a more perfect union between the front and the rear seat. Don't forget the heat gun.
Then if needed, just unscrew the interior of the bank that leaves everything at once, without getting any marks or visible holes.
4 days to think about the material and look the parts needed, 1 full day to perform all the work and after test it on the road.
I did it today to make sure everything worked well or if i would need to make some adjustments on it.
Well 155 miles at once, without any back pain. Since it had a hinge with bolt inclination, if i wanted to change or adjust the driving position, the pad "adapts perfectly to all changes" and even with the imperfections of the road.
Both back pain and kidney disappeared as if by miracle. I made the cheapest driver backrest pad for the M800 586905
And i loved want i did. I made the cheapest driver backrest pad for the M800 3498837457
Let me show you people:
I made the cheapest driver backrest pad for the M800 Hpim2311
I made the cheapest driver backrest pad for the M800 Hpim2315
I made the cheapest driver backrest pad for the M800 Hpim2312
I made the cheapest driver backrest pad for the M800 Hpim2316
I made the cheapest driver backrest pad for the M800 Hpim2313
I made the cheapest driver backrest pad for the M800 Hpim2314
PostSubject: Re: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeSun Sep 21, 2014 9:49 pm
That looks fooking superb!  I made the cheapest driver backrest pad for the M800 2170595768  it looks well comfy! not only that? it doubles up as a picnic table in the folded down position too   ilis
DaveC
DaveC
PostSubject: Re: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeSun Sep 21, 2014 9:54 pm
Cracking job that Jose I made the cheapest driver backrest pad for the M800 2170595768
PostSubject: Re: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeSun Sep 21, 2014 10:13 pm
What a good job, love home engineering. I made the cheapest driver backrest pad for the M800 3005623951  I made the cheapest driver backrest pad for the M800 276246
PostSubject: Re: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeSun Sep 21, 2014 11:33 pm
Love the 'dual purpose' suggestion from Sim I made the cheapest driver backrest pad for the M800 428386 ilis
PostSubject: Re: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeMon Sep 22, 2014 12:02 am
Jose, that's really I made the cheapest driver backrest pad for the M800 3039991824  m8, I made the cheapest driver backrest pad for the M800 102087026  a lot I made the cheapest driver backrest pad for the M800 2170595768
PostSubject: Re: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeMon Sep 22, 2014 12:56 am
So duz me!  I made the cheapest driver backrest pad for the M800 428386 you certainly have some skills Jose and as for Sim's suggestion, I can certainly see a couple of steaming hot mugs of char on top of that in a layby somewhere! I made the cheapest driver backrest pad for the M800 102087026
PostSubject: Re: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeMon Sep 22, 2014 9:09 am
Well done Jose! cracking bit of improvisation that!  I made the cheapest driver backrest pad for the M800 3498837457 I made the cheapest driver backrest pad for the M800 3492671266
PostSubject: Re: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeMon Sep 22, 2014 10:44 am
good job. Where did you get your tank protector from? different  quite like it I made the cheapest driver backrest pad for the M800 3498837457
PostSubject: Re: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeMon Sep 22, 2014 10:46 am
Looking good I made the cheapest driver backrest pad for the M800 2170595768
Dont fall asleep riding now it is so comfortable I made the cheapest driver backrest pad for the M800 852880
TaurusTuga
TaurusTuga
PostSubject: Re: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeMon Sep 22, 2014 12:51 pm
Thank you all for your feedback. I made the cheapest driver backrest pad for the M800 3498837457 I made the cheapest driver backrest pad for the M800 3005623951 I made the cheapest driver backrest pad for the M800 3005623951
Hello Morgan (Fat Intruder) about the tank's cover was also made by me. I took a type of foam that is normally used for base for glasses, carpets, bathroom, etc..then i cut it to be molded to the tank. I folded and pressed down with two pieces of rubber and metal profile usually used to be placed on the door's cars to avoid damaging them.
P.S. One of my TV heroes ( if i may say so, was the MacGyver series) and from nothing he could do anything, only with this mind, skills and knowledge. I am only a "micro nano portion of it, of course) Embarassed .
Perhaps i will follow the Simbo's idea to turn it into a picnic or perhaps a poker one. I made the cheapest driver backrest pad for the M800 3213823784
But the problem is: "Where in the hell i put the chairs"??? hyst hyst hyst
PostSubject: Re: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeMon Sep 22, 2014 1:17 pm
cool looks good. So what's next then? lol
TaurusTuga
TaurusTuga
PostSubject: Re: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeMon Sep 22, 2014 7:01 pm
Hi Morgan, for know only ideas.
What is more difficult is to move from ideas to reality and use materials that are not just for a single role.And of course it takes time.
I don't want to go ahead with something and regret it later.
My only goal is to customize it and at any time (if i want), take everything out and stay as the original, unmarked.
Cheers I made the cheapest driver backrest pad for the M800 256401
PostSubject: Re: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeMon Sep 22, 2014 9:34 pm
Good mod Jose.You can never regret doing a mod,if it does not look right you just improve it.
PostSubject: Re: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeTue Sep 23, 2014 8:22 am
PostSubject: Re: I made the cheapest driver backrest pad for the M800   I made the cheapest driver backrest pad for the M800 Icon_minitimeTue Sep 23, 2014 10:38 pm
Damn clever, I bet it would even double as laptop table!! when stationary of course
» 2011 m50 driver backrest & passenger backrest?
» RE: Backrest for Suzuki M800 / M50
» Adjustable backrest mod (M1800 to fit M800)
» Hinged Riders Backrest, Suzuki M800 / M50
» Home made wind deflectors M800
I made the cheapest driver backrest pad for the M800 Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
I made the cheapest driver backrest pad for the M800 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
I made the cheapest driver backrest pad for the M800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
I made the cheapest driver backrest pad for the M800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
I made the cheapest driver backrest pad for the M800 Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
I made the cheapest driver backrest pad for the M800 Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
I made the cheapest driver backrest pad for the M800 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
I made the cheapest driver backrest pad for the M800 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
I made the cheapest driver backrest pad for the M800 Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
I made the cheapest driver backrest pad for the M800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
I made the cheapest driver backrest pad for the M800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
I made the cheapest driver backrest pad for the M800 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
I made the cheapest driver backrest pad for the M800 Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
I made the cheapest driver backrest pad for the M800 Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
I made the cheapest driver backrest pad for the M800 Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
I made the cheapest driver backrest pad for the M800 Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
I made the cheapest driver backrest pad for the M800 Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
I made the cheapest driver backrest pad for the M800 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
I made the cheapest driver backrest pad for the M800 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
I made the cheapest driver backrest pad for the M800 Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
