 Clunking and Rubbing!!!!
monty662
7 posters
monty662
monty662
Clunking and Rubbing!!!! Empty
PostSubject: Clunking and Rubbing!!!!   Clunking and Rubbing!!!! Icon_minitimeWed Oct 01, 2014 8:58 am
I have had my VZ800 Marauder for about a month now, and over the past few days there has been an increase in noise from the gear/chain housing.....
At low speeds it sounds like the chain is rubbing, and also there is a clunking noise coming from the same area.
I did read somewhere that the chain can become stiff in places and therefore not follow the sprocket...I don't know...
It has only done 20K Kms so things can't be wearing out already!!!!
PostSubject: Re: Clunking and Rubbing!!!!   Clunking and Rubbing!!!! Icon_minitimeWed Oct 01, 2014 1:18 pm
A chain can be stretched due to riding habits extremely quickly.
PostSubject: Re: Clunking and Rubbing!!!!   Clunking and Rubbing!!!! Icon_minitimeWed Oct 01, 2014 1:57 pm
Jack the rear wheel up off the floor and slowly turn the wheel to see if you have any tight parts in the chain,this is the easy way to check it.Also check the rear sprocket for hooked teeth,they should be straight,these are things you can do without getting your spanners out to delve further.
PostSubject: Re: Clunking and Rubbing!!!!   Clunking and Rubbing!!!! Icon_minitimeWed Oct 01, 2014 5:56 pm
Sounds like a Seized Link?
PostSubject: Re: Clunking and Rubbing!!!!   Clunking and Rubbing!!!! Icon_minitimeWed Oct 01, 2014 7:20 pm
20k on a chain wow that's good going my bike eats em up hahaha although it has a little bit more power than your vz I would agree with the others check your chain and sprockets do you keep the chain lube up? is the chain sagging you might need to adjust it  by putting the rear wheel back a bit
PostSubject: Re: Clunking and Rubbing!!!!   Clunking and Rubbing!!!! Icon_minitimeWed Oct 01, 2014 9:22 pm
I used to have to adjust my chains every dew rides, probably a cheap chains. Oh OK then they always were. Worked out expensive in the long run though as I would have to buy another cheap chain occasionally along with sprockets as well.
Two-Bears
* VZ Guru *
Two-Bears
PostSubject: Re: Clunking and Rubbing!!!!   Clunking and Rubbing!!!! Icon_minitimeThu Oct 02, 2014 4:07 am
Hello Ian,
I agree with the comments about the chain the guys have said,,, the chain on the VZ800 is quite long and if not maintained and the chain free play kept within spec it can have a lot of excess free play,,,,,, at the front of the swing arm on the left side is a shaped/moulded rubber buffer intended to stop the chain clattering the swing arm,,, at lower speeds stop start town riding speeds, if the chain is worn/loose it can flap around a lot as you go on/off the throttle the chain whips,,, I have replaced a few of the shaped/moulded rubber buffers as they ware through and also they appear to rot over time plus all the snot and clagg that gets deposited on it from the chain lube e.t.c speeds up the rubber decay,,,,, when this shaped/moulded rubber buffer wares through the chain can be heard rubbing and when the chain whips it wallops the swing arm giving a clunk,,,,, it is well worth checking this shaped/moulded rubber buffer mate,,, it tends to ware through at the top and can score the swing arm quite badly,,, if it is worn and you need to replace it you will also have to sort the chain,,, I have a quality DID chain and scott oiler on my VZ800.
Hope this is of some help mate.
monty662
monty662
PostSubject: Re: Clunking and Rubbing!!!!   Clunking and Rubbing!!!! Icon_minitimeThu Oct 02, 2014 9:03 am
Thanks for all the advice guys....I have taken it on board and I will look at it at the weekend...only time I have spare!!!!!
Will let you know the outcome...
Cheers
» Clunking noise from final drive
» Rear Wheel Rubbing Against Drive Shaft
Clunking and Rubbing!!!! Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Clunking and Rubbing!!!! Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Clunking and Rubbing!!!! Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Clunking and Rubbing!!!! Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Clunking and Rubbing!!!! Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Clunking and Rubbing!!!! Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Clunking and Rubbing!!!! Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Clunking and Rubbing!!!! Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Clunking and Rubbing!!!! Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Clunking and Rubbing!!!! Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Clunking and Rubbing!!!! Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Clunking and Rubbing!!!! Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Clunking and Rubbing!!!! Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Clunking and Rubbing!!!! Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Clunking and Rubbing!!!! Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Clunking and Rubbing!!!! Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Clunking and Rubbing!!!! Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Clunking and Rubbing!!!! Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Clunking and Rubbing!!!! Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Clunking and Rubbing!!!! Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
