 2014 C800 Headlight query
oldtom
6 posters
oldtom
oldtom
2014 C800 Headlight query Empty
PostSubject: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeWed Oct 29, 2014 8:00 pm
I'm trying to get inside the headlight shell
In the handbook it shows
1  Remove the right and left bolts (done that)
    Unhook the hooks ( what hooks. I can't see any hooks) What should I be doing?
I am hoping to take a tapping off the "spare" socket in the headlight shell and feed a wire back to a relay and auxiliary fuse box so I can run satnav, phone charger,  heated grips and a powerful horn.
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeWed Oct 29, 2014 8:26 pm
Hi Tom, just pull it at the bottom to release it and then lift it up and off the bucket, It's sort of hooked on a lip at the top.
oldtom
oldtom
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeWed Oct 29, 2014 8:53 pm
Simbo - I've tried that and it won't budge. If I try to twist the outer rim it does move a fraction and I have run some ACF50 in the joint to try to free it. But no joy. I have removed the plastic cover from underneath and put gaffer tape on the rim for extra grip. I can now nearly pull the bike along but the rim will not pull off from the lower edge of the shell.
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeWed Oct 29, 2014 9:04 pm
I've just done mine to double check? remove phillips screw from either side then twist and pull the rim and it lifts off the lip at the top, there's little lips around the side area too but they're probably to stop it falling off if the screws come out whilst riding.
oldtom
oldtom
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeWed Oct 29, 2014 10:06 pm
Simbo - thanks for getting back on this. I'ts all tucked up for the night now so I'll try again in the morning
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeThu Oct 30, 2014 3:03 pm
Like Sim says but I use my pen knife or a small screwdriver to flick it off Tom.
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeThu Oct 30, 2014 5:07 pm
I undo the screws then I hold the front part of the headlight & wiggle as I pull.
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeThu Oct 30, 2014 6:02 pm
you can tell a lot about a man by the way he takes his headlight apart 2014 C800 Headlight query 3213823784
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeThu Oct 30, 2014 6:36 pm
Well my wife always gives it a good pull and I just followed what I was shown in the demonstration. 2014 C800 Headlight query 852880
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeThu Oct 30, 2014 6:56 pm
Oh god it's going down hill again, NURSE!!!!!!!!!!!  SUZUKI800.COM GIRL
oldtom
oldtom
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeThu Oct 30, 2014 7:39 pm
I  still can't get it to budge.
If I wiggle it it only moves a couple of thou but at least that shows it is not "stuck". I will have to take it back to the dealer and ask their workshop to shift it. Bahh! I hate it when I can't do stuff like this.
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeFri Oct 31, 2014 7:55 pm
If I wiggle it it only moves a couple of thou but at least that shows it is not "stuck". I will have to take it back  and ask their workshop to shift it. Bahh! I hate it when I can't do stuff like this.
after the last two posts I nearly wet meself  reading this 2014 C800 Headlight query 3213823784  hyst 2014 C800 Headlight query 3213823784  hyst 2014 C800 Headlight query 3213823784 2014 C800 Headlight query 852880 2014 C800 Headlight query 852880 2014 C800 Headlight query 852880 2014 C800 Headlight query 102087026
try some Viagra mate should get it moving more than a couple of thou  2014 C800 Headlight query 3213823784
maybe give it a bit more of a shake than a wiggle hyst hyst hyst
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeFri Oct 31, 2014 8:23 pm
"Suzuki Headlamp Removal Tool"
2014 C800 Headlight query Hammer_zps49e44753
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeFri Oct 31, 2014 8:32 pm
aaawwwwhhhhh good my bike didn't come with its tool kit but I've got some of those tools in my shed and garage lol
oldtom
oldtom
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeFri Oct 31, 2014 8:40 pm
Ha!
HA!
BLOODY HA!
Viagra and a Hammer ( I am not an elderly Ripper)
What I discovered:
The shell is plastic and so is the outer rim ( this is ok as it's lighter than steel and won't go rusty)
I put a piece of stiff plastic into the gap between the glass's bezel and the outer rim and levered it a little. Success.
In short I had it off this afternoon.
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeFri Oct 31, 2014 8:49 pm
I'm keeping out of this one so it's over to Sim.........   hyst 2014 C800 Headlight query 2740622253 2014 C800 Headlight query 3213823784 2014 C800 Headlight query 2343124779
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeFri Oct 31, 2014 8:57 pm
Good man! was that before or after?
2014 C800 Headlight query Bed_zps3986452a
oldtom
oldtom
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeSat Nov 01, 2014 12:57 pm
My sciatica is killing me just looking at that.
customerlin
customerlin
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeSun Jan 04, 2015 10:10 am
I don't know nothing about disassenble the C800 K14, I have the K7 and it is easy to do it
I only recommend you to connect the relay to the battery in case of high load... otherwise you can burn the Aux Wires of the Headlight
For the Navigator, USB connector or something with low load is ok!! Don't need the relay, only a 5 Amps fuse and connect directly to the terminal
In fact, I remove the original terminal on the headlamp and installed one electric of this kind for easily connection
2014 C800 Headlight query 150104111619439330
oldtom
oldtom
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeMon Jan 05, 2015 4:57 pm
Hope I'm not being too picky but the Suzuki year id. after 2009 (K9) swaps to index letter "L"
Hence:
2010 = L0
2011 = L1
2012 = L2
2013 = L3
2014 = L4
etc.
Quite why they did this I know not but it isn't  "Roman Numerals".
customerlin
customerlin
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeMon Jan 05, 2015 5:29 pm
Hence:
2010 = L0
2011 = L1
2012 = L2
2013 = L3
2014 = L4
etc.
LOL!
OK! I am obsolete!!! Still on Kx numeration  2014 C800 Headlight query 115684958
oldtom
oldtom
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeMon Jan 05, 2015 10:32 pm
I think their idea is to change it every 10 years so as to only use one letter and one digit.
Maybe for 2020 they change it to "M"
Hmmmm how about an M0M800. That won't be confusing !!!!
PostSubject: Re: 2014 C800 Headlight query   2014 C800 Headlight query Icon_minitimeMon Jan 05, 2015 11:19 pm
Nice one Tom. hyst
» Exhaust Query C800 - M800
» 2014 C800 headlight beam switch?
» sissy bag query
» VX 800 Suspension query
» pannier query
2014 C800 Headlight query Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
2014 C800 Headlight query Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
2014 C800 Headlight query Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
2014 C800 Headlight query Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
2014 C800 Headlight query Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
2014 C800 Headlight query Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
2014 C800 Headlight query Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
2014 C800 Headlight query Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
2014 C800 Headlight query Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
2014 C800 Headlight query Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
2014 C800 Headlight query Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
2014 C800 Headlight query Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
2014 C800 Headlight query Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
2014 C800 Headlight query Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
2014 C800 Headlight query Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
2014 C800 Headlight query Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
2014 C800 Headlight query Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
2014 C800 Headlight query Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
2014 C800 Headlight query Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
2014 C800 Headlight query Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
