 Spring Clean Time
TaurusTuga
EazyDuz
shadycowboy
9 posters
shadycowboy
shadycowboy
Spring Clean Time Empty
PostSubject: Spring Clean Time   Spring Clean Time Icon_minitimeMon Apr 20, 2015 4:04 am
Time for my annual 8hr clean-a-thon.
I really have thought my cleaning to be above average for the bike. To most people it sparkles, but to me if its not mint its not clean.
I used some chrome polish last year from various outlets, it was clean, but never clean enough. But who is your fav? I considered Blue-Job until I saw the price!
Paint work is pretty solid. Clean, Polish, Wax. I have my routine for that,
Areas that I need to work on are. Engine fins, and wheels mainly. My exhaust needs a good scrub this year as well
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeMon Apr 20, 2015 9:21 am
Can't advise you on chrome cleaner as I ain't really got any on mine.  But this is my advice on engine fins & barrels - Fin Cleaning.  The polish I used (the photo has disappeared) is this stuff - HotSpot black Grate Polish - but like I said, it's messy stuff.
The shine on the casings came from this stuff - Black Spray Shine - it's expensive, but good
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeMon Apr 20, 2015 9:37 am
I have recently been using a spray can household polish on my bike, with gratifying results. I will von tine this.
EazyDuz
EazyDuz
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeMon Apr 20, 2015 10:02 am
My cleaning routine:
Clean all chrome/metal work with WD40 and a rag, if i see surface rust (sometimes on the rims) i use 0000 wire wool and more WD40. Once i've cleaned an area i then use a fresh microfibre cloth and rub Autosol all over it. Its a brilliant chrome/metal polish.
For plastics and paint work, Autosol is the last thing you want. I used to just get the bike all wet with a car sponge but dont do that anymore. Instead i use a wet rag or half a sponge and much less water, with a bit of car shampoo to remove dirt and dust. I then let it air dry or wipe it dry, and apply one or 2 coats of this:
http://www.ebay.co.uk/itm/Meguiars-Deep-Crystal-System-Step-3-Wax-Wax-A2216-/270691443486?pt=LH_DefaultDomain_3&hash=item3f0677a31e
The price is high but man is it worth it. It leaves the paint feeling like glass and the sparkle lasts for ages. A bottle will last a long time too if you only use it on the bike. Water beads and just runs off as well.
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeMon Apr 20, 2015 10:16 am
I have always been a major believer in using wd40 as a polish, need to order another gallon as I have run out.
TaurusTuga
TaurusTuga
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeMon Apr 20, 2015 10:39 am
Well folks about clean&polish, i only use this for 12 years ago in all my bikes with microfiber cloth:
http://www.scjohnson.ro/en/nqcontentcd7d.html?a_id=5398
In UK J&J named Pronto as Pledge:
http://www.scjohnson.co.uk/nqcontent682a.html?a_id=5846
Cheap enough and always applying after removing first the dust and dirty only with the microfiber cloth.
If you don't believe, check it yourselves and let me know, ok?
EazyDuz
EazyDuz
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeMon Apr 20, 2015 3:57 pm
This is why i love Meguiars wax, it makes the plastic panels look like metal, and Autosol turns chrome into a mirror with little effort:
Spring Clean Time ES0sMpZ
Spring Clean Time Xeu2N5y
Spring Clean Time LQ4YZUx
Spring Clean Time JQ9hCu9
After cleaning the bike with water first, the wax from last year still made the water bead, but it needed a spring time clean
BARNEY
BARNEY
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeMon Apr 20, 2015 4:14 pm
WOW !!!
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeMon Apr 20, 2015 5:17 pm
Shiny Shiny!  Spring Clean Time 2170595768
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeMon Apr 20, 2015 7:03 pm
That is mint looking.
For chrome, especially if it's a bit tarnished, I like a metal polish called PEEK.
Don't clean your teeth with it though
Spring Clean Time Peek_Metal_Polish_Cream
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeMon Apr 20, 2015 7:29 pm
Good tips on here guys. Spring Clean Time 3498837457
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeMon Apr 20, 2015 7:45 pm
wd40's good for giving black engines and cylinder fins a bit of a sheen, I use window spray on most of my bike to clean up and give a streak free finish.
shadycowboy
shadycowboy
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeMon Apr 20, 2015 10:43 pm
some great tips there! Think I'll invest in some Meg and some autosol although I heard its to abrasive?
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeTue Apr 21, 2015 12:48 am
Yeh - personally I'd stay off Autosol unless you have some serious shit to clear off your brightwork - use a hard-wax instead
EazyDuz
EazyDuz
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeTue Apr 21, 2015 8:04 am
Its bad on plastics, use Meg on things like the chrome coloured airbox.
Autosol for pipes and anything metal. Used it on all my bikes with no problems
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeTue Apr 21, 2015 4:21 pm
Autosol is abrasive so should be used for deep cleaning when you need it only but otherwise don't. I used to use Mr Sheen a while ago but then it was free from work but I have some spray I bought for the car so will give that a go.
EazyDuz
EazyDuz
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeTue Apr 21, 2015 6:56 pm
Fair enough all i can say is it has never damaged the chrome on any of my bikes or done any harm, anywhere, after repeated use.
Its very good at keeping rust at bay particularly on the oh so precious rims too, beads the water.
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeTue Apr 21, 2015 7:23 pm
The Autosol in a tube seems more abrasive than the one in a tin can, unless I didn't shake mine up enough?  Spring Clean Time 852880
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeTue Apr 21, 2015 7:56 pm
Didn't realise Autosol did so many types of cleaners / polish check this lot out !!!!
Personally, I'd use Autosol on areas of hard chrome eg wheel rims (as Duz says) fin ends etc, but I'd steer clear on areas with an easily marked surface
EazyDuz
EazyDuz
PostSubject: Re: Spring Clean Time   Spring Clean Time Icon_minitimeTue Apr 21, 2015 9:26 pm
Its the metal polish in the gold and black tube i use, lasts quite a while too.
The C800 is a pretty well made bike to be honest. It has better chrome than the Honda Shadow or Dragstar in my opinion. Vance and Hines pipes have awesome chrome too.
Though i always use ACF50 during the winter months which might be why ive never had a rust problem.
Spring Clean Time
» How do you clean your Cruiser
» The Big Clean
» How clean is clean?
» Best way to clean?
» Footboards clean up.
Spring Clean Time Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Spring Clean Time Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Spring Clean Time Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Spring Clean Time Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Spring Clean Time Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Spring Clean Time Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Spring Clean Time Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Spring Clean Time Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Spring Clean Time Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Spring Clean Time Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Spring Clean Time Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Spring Clean Time Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Spring Clean Time Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Spring Clean Time Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Spring Clean Time Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Spring Clean Time Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Spring Clean Time Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Spring Clean Time Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Spring Clean Time Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Spring Clean Time Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
