 Rear Brake Drum to Hydraulic Conversion 1997 VZ800
5 posters
Fingers
Fingers
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Empty
PostSubject: Rear Brake Drum to Hydraulic Conversion 1997 VZ800   Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeMon May 11, 2015 2:11 pm
Hello All
In conjunction of heavy traffic riding and our hot weather I keep having to rely heavily on My front brake as the rear brake drum gets hot and breaking ability gets reduced and starts slipping.
I am playing with the idea of changing the rear brake drum to hydraulic disk brake.
Has anybody done this or have any information were I can start.
PostSubject: Re: Rear Brake Drum to Hydraulic Conversion 1997 VZ800   Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeMon May 11, 2015 3:29 pm
No but would definitely be an interesting idea to pursue, maybe even combination/linked brakes!! would make the heavy old bikes much better at stopping. hmmmmm
PostSubject: Re: Rear Brake Drum to Hydraulic Conversion 1997 VZ800   Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeMon May 11, 2015 7:14 pm
Interesting Idea, I've never seen it done though? You'd have to start by finding a doner wheel with a disc already fitted then look into having a caliper mount welded to the swing arm, then you'd have to look into master cylinder mounting points and how to connect it to your brake pedal, hopefully you'd be able to source all the parts from the same bike so as they match up pressure wise and made for each other, big job I'd have thought? but doable if you have any engineering friends to keep the costs down.
Two-Bears
* VZ Guru *
Two-Bears
PostSubject: Re: Rear Brake Drum to Hydraulic Conversion 1997 VZ800   Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeTue May 12, 2015 7:18 am
Hello Fingers,
The conversion can be done,, mostly as Sim has said. I`ve ridden a vz800 with twin front disc conversion but not a rear disc conversion but as I`ve said it can be done,, it was done fairly recently by a guy from Bulgaria.
"The rear wheel is from (1999–2002) Suzuki SV650.
The sprocket carrier is stock all the rest on the rear spindle is form the SV650 and you will need simple 4mm spacer between the brake caliper carrier and the swing arm".
"The rest is to find the place of the brake master cylinder but this depend of what kind of controls you use"
It would not be difficult to get the rear brake master cylinder e.t.c from the sv650 as well.
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Vz800%20sv650_zpstr6jgnmv
P.S ( Hello Hawkthe slayer) just as a point of reference the vz800 is not a heavy bike,, it was initially marketed as the sporty bike in the early intruder range ( intruder, volusia, boulevard, and marauder ) it only weighs 207kg,, vl800 2013 I believe 277kg and my 2007 m800 is 245Kg so the vz800 marauder isn't that heavy really.
Hope this is of some help mate.
Fingers
Fingers
PostSubject: Re: Rear Brake Drum to Hydraulic Conversion 1997 VZ800   Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeTue May 12, 2015 7:46 am
Thanks Chaps
Many Thanks John. Much appreciated. I now have a starting point.
I will investigate and if the pocket allows I will do the conversion and post the project.
PeatedFumes
PostSubject: Re: Rear Brake Drum to Hydraulic Conversion 1997 VZ800   Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeFri Jun 02, 2017 10:09 pm
Has anyone else successfully done this conversion? Curious to give it a try
» VZ800 Rear Tire to VS800 1997-
» Unusual Rear Brake Problem
» 14/1500 Rear Brake idea???
» Rear brake shoes
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Rear Brake Drum to Hydraulic Conversion 1997 VZ800 Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
