 Led turn signals!
6 posters
Led turn signals! Empty
PostSubject: Led turn signals!   Led turn signals! Icon_minitimeSat Jun 06, 2015 11:28 am
Hi, I've ordered some clear lens for the m800, can I change the bulbs to amber led's or will I need replacement flasher unit or resistors, I can of course just replace with stock amber bulbs, help much appreciated Led turn signals! 3498837457
PostSubject: Re: Led turn signals!   Led turn signals! Icon_minitimeSat Jun 06, 2015 11:36 am
Amber lamps - minimum work.
If you fit LED, you will need either resistors or change the flasher unit
PostSubject: Re: Led turn signals!   Led turn signals! Icon_minitimeSat Jun 06, 2015 12:55 pm
Hi John go for the chrome bulbs that flash amber, these look better with a clear lens. You can find them on ebay.
rossmofo
rossmofo
PostSubject: Re: Led turn signals!   Led turn signals! Icon_minitimeSat Jun 06, 2015 1:05 pm
If you must have LED bulbs ( much better IMO) then don't waste your time and money on resistors, they heat up ,take up space ,need wired in and after all that the flash rate might still not be quite right .Go for the 7pin LED relay its plug n play and will give you factory flash rate ...
PostSubject: Re: Led turn signals!   Led turn signals! Icon_minitimeSat Jun 06, 2015 11:37 pm
Go for the LEDs & fit this relay LED Relay.  Just remove your original relay & slit this in it's place - works fine
PostSubject: Re: Led turn signals!   Led turn signals! Icon_minitimeSun Jun 07, 2015 11:58 am
Thanks guys for all your suggestions, my stepson had 4 amber bulbs which I have put in for now, not sure yet about leds, I think I might order the chrome amber ones. £20 for the flasher unit plus the cost of the led's makes it a bit of an expensive 'mod'.
Paid £36, that was with 10% off and free postage for the clear lenses from 'metric cruisers'. Led turn signals! 3498837457
mhicks2517
PostSubject: Re: Led turn signals!   Led turn signals! Icon_minitimeTue Feb 11, 2020 5:37 pm
Installed new LED turn signals, the bike was never wired to have running/turn at same time for rear. I can only get one or the other to work not both at same time. Any help, please.
mhicks2517
PostSubject: Re: Led turn signals!   Led turn signals! Icon_minitimeTue Feb 11, 2020 5:38 pm
Sorry its a 93 intruder 800
Led turn signals!
» Who's Marauder is this and where can I find these rear turn signals?
» need sone help wiring front turn signals
» Installed Saddlemen bullet style rear turn signals
» Turn signal help
» Turn out tips
Led turn signals! Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Led turn signals! Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Led turn signals! Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Led turn signals! Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Led turn signals! Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Led turn signals! Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Led turn signals! Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Led turn signals! Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Led turn signals! Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Led turn signals! Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Led turn signals! Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Led turn signals! Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Led turn signals! Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Led turn signals! Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Led turn signals! Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Led turn signals! Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Led turn signals! Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Led turn signals! Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Led turn signals! Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Led turn signals! Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
