| Idle speed adjustment | |
Llaw1969 Member
| Subject: Idle speed adjustment Wed Sep 23, 2015 7:03 pm | |
| How do I adjust the warm idle speed on my fuel injected 2006 m800 | |
| Subject: Re: Idle speed adjustment Wed Sep 23, 2015 7:39 pm | |
| Hi Mike, there should be a idle adjustment thumb turn screw under the tank, it's been removed on later models as the idle is controlled by the ECU but I think that's 09 and later models. | |
| | | Llaw1969 Member
| Subject: Re: Idle speed adjustment Wed Sep 23, 2015 7:57 pm | |
| Ok, thanx simbo.
Err forgive my ignorance, but do you mean on the underside of the tank in position, or underneath the tank when lifted off the frame?????.........(this is my first fuel injected bike) | |
| Subject: Re: Idle speed adjustment Wed Sep 23, 2015 8:05 pm | |
| I'm not sure you can get to it from the left side of the bike (mine doesn't have an idle screw) if you can't? just lift the rear of the tank and prop it up while in place that should be fine. | |
| | | Llaw1969 Member
| Subject: Re: Idle speed adjustment Wed Sep 23, 2015 8:09 pm | |
| Subject: Re: Idle speed adjustment | |
