 Camshaft timing VZ800
2 posters
scubadogs
Camshaft timing VZ800 Empty
PostSubject: Camshaft timing VZ800   Camshaft timing VZ800 Icon_minitimeWed Oct 14, 2015 1:52 am
Hello , this forum looks great. I have a 1997 VZ800 which I just torn down the motor to replace crank and rod bearings because the last owner ran it with low to no oil.  I have a question about camshaft timing.  the front#2 cylinder and the back #1 cylinder have and arrow on the cam shaft.  This is to be pointed towards the front of the engine when the generator rotor aligns up with T.D.C. The book shows TDC of No.1 cylinder is the RIF I T marking aligned with the mark on the generator cover.  Do I use the FIF I T marking for the front #2 cylinder?  Or do I use the RIF I T marking for both cylinders?  They use both of these marking per the book when adjusting the valves but they only mention the RIF I T when setting the camshaft timing.  Can someone help me out??
scubadogs
PostSubject: Re: Camshaft timing VZ800   Camshaft timing VZ800 Icon_minitimeWed Oct 14, 2015 6:04 pm
OK I think I just use the RlF l T marking then make sure each front and back cam has the arrow point forward parallel with the top or the head.  Just would like to make sure before I put this back in the frame.  Any confirmations???
PostSubject: Re: Camshaft timing VZ800   Camshaft timing VZ800 Icon_minitimeWed Oct 14, 2015 7:03 pm
In the VL800 manual it says RIT and lines on cams parallel to the heads, I'm not sure for the pre 2005 VZ's though? sorry.
» hello camshaft timing vz800
» Engine timing
» Need some technical help with cam timing....
» Can't find valve timing marks
» cam chain timing marks on stator ?
Camshaft timing VZ800 Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Camshaft timing VZ800 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Camshaft timing VZ800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Camshaft timing VZ800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Camshaft timing VZ800 Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Camshaft timing VZ800 Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Camshaft timing VZ800 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Camshaft timing VZ800 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Camshaft timing VZ800 Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Camshaft timing VZ800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Camshaft timing VZ800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Camshaft timing VZ800 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Camshaft timing VZ800 Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Camshaft timing VZ800 Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Camshaft timing VZ800 Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Camshaft timing VZ800 Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Camshaft timing VZ800 Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Camshaft timing VZ800 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Camshaft timing VZ800 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Camshaft timing VZ800 Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
