 carb balancing
2 posters
cillasman
cillasman
carb balancing Empty
PostSubject: carb balancing   carb balancing Icon_minitimeSun Mar 20, 2016 10:25 pm
hi all ive got my engine back in and cleaned the carbs but I notice there isn't any plugs on the carb manifolds to connect my balancer, do I use the breather pipes ! looked on you tube but it dosent show you were to plug them only how to balance them. Thanks Ian
PostSubject: Re: carb balancing   carb balancing Icon_minitimeSun Mar 20, 2016 10:57 pm
If its the same as on my old VX800, you take a screw out on the side of the carb and screw in a brass tube that should come with the vacuum gauges and then connect the rubber pipe from the Vacuum Gauge.
This might help http://www.stevepedwards.com/MotorbikeTinkering/vx800-carb-balance/
cillasman
cillasman
PostSubject: Re: carb balancing   carb balancing Icon_minitimeMon Mar 21, 2016 7:26 pm
I think the carbs on that one are different to mine but I think I know what to do now cheers
cillasman
cillasman
PostSubject: Re: carb balancing   carb balancing Icon_minitimeWed Mar 23, 2016 8:48 pm
Hi I looked in my Haynes manual and it says remove vacuum hoses from the fittings on the carb and plug in gauge ! it that the hoses from the top of the carb that runs along the rubber boots, if so shouldn't they have plugged ends. ian
carb balancing
» Carb issues
» Rejetting Carb on VL800 Trike
» Carb spluttering, coughing...
» VS800 Carb Maintenance
» possible leakage at rear cylinder-carb joint
carb balancing Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
carb balancing Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
carb balancing Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
carb balancing Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
carb balancing Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
carb balancing Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
carb balancing Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
carb balancing Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
carb balancing Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
carb balancing Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
carb balancing Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
carb balancing Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
carb balancing Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
carb balancing Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
carb balancing Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
carb balancing Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
carb balancing Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
carb balancing Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
carb balancing Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
carb balancing Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
