 Dayton rev counter wiring problem
4 posters
G.Terence
G.Terence
Dayton rev counter wiring problem Empty
PostSubject: Dayton rev counter wiring problem   Dayton rev counter wiring problem Icon_minitimeMon Jul 04, 2016 5:47 pm
Good evening all,
Just fitted a Dayton rev counter. I think my problem is the pulse pick up point. The instrument comes to life, has a quick flash around the dial and settles at about 660 rpm. As soon the throttle is bliped the needle goes to zero.
I have tried the white pulse wire to a coil white first, then the  pulse lead to the orange lead on the coil and finally using the plug lead.
All produced very much the same results.
It could be a case of just not using the right coil, so the question is which coil should I be using and where the hell is it?
G.Terence
PostSubject: Re: Dayton rev counter wiring problem   Dayton rev counter wiring problem Icon_minitimeTue Jul 05, 2016 11:29 am
Hi Terry, shouldn't make any difference which coil you use, as each one fires at the same interval as the other.
My rev counter isn't a Daytona one but as far as the signal cable is concerned it should be the same connection I would think ?
I simply soldered a spade terminal on to my signal cable from the tachometer and connected the white cable of the coil on to the piggy back, then connected that to the + connection on the primary side of the coil ( white cable - the orange / black is the negative ). It sound like you have the live and negative for the instrument correctly wired as the needle is doing a "sweep" around the dial when you power it up.
Not sure what's going on with yours ..... When you say you tried the "plug lead" ..... Have you made a physical connection to that or just wrapped the signal cable around the HT lead ?
PostSubject: Re: Dayton rev counter wiring problem   Dayton rev counter wiring problem Icon_minitimeTue Jul 05, 2016 5:45 pm
Terry - the white wire is the pulse wire.  I piggy-backed mine onto the white wire coming off the left-hand coil (as you're sitting on it).  Bear in mind that mine is an '01 model, so check the wiring diagram for your year - you're looking for the non-common colour - from what I remember, both coils have an orange/white, which is the negative.  It's a bit of a pig to get to, but I had no luck on the plug lead either.  Did you remember to set the pulse mode to "1 pulse to 2 revolutions" on the unit ?
G.Terence
G.Terence
PostSubject: Re: Dayton rev counter wiring problem   Dayton rev counter wiring problem Icon_minitimeThu Jul 07, 2016 8:53 am
Good day all,
System now up and running, not to sure about the Pulses per revolution setting. Am I correct in thinking that some where on this site I have read that in fifth gear 600 rpm gives 10 mph.
Therefore  1800 rpm =30 mph / 2400 rpm = 40 mph / 3000 rpm = 50 mph / 3600 = 60 mph etc.
The only way I can achieve there results is by having the rev counter pulse rate set at 2 pulses per revolution. Is this any thing to do with each cylinder having two sparking plugs? I am really out of my depth on this one!
G.Terence
PostSubject: Re: Dayton rev counter wiring problem   Dayton rev counter wiring problem Icon_minitimeThu Jul 07, 2016 9:55 am
Hi Terry, if you have a look at the "cheap electronic tacho " thread it gives the settings for the pulses for twin Spark plug models.
PostSubject: Re: Dayton rev counter wiring problem   Dayton rev counter wiring problem Icon_minitimeThu Jul 07, 2016 10:30 am
Terry - OOPS - it's 1 pulse per 2 rev - just checked on mine.  Feel like a right fookin muppet now !!!   Sorry to have misled you.
 Sim, or anyone else in admin - can you allow me to edit my original post (or could you do it) so that anyone else following my instructions will not be pulling their hair out?  It need to read "1 pulse per 2 revolution"
Terry - sorry for the distress I've caused you
G.Terence
G.Terence
PostSubject: Re: Dayton rev counter wiring problem   Dayton rev counter wiring problem Icon_minitimeThu Jul 07, 2016 10:42 am
Hi Dave,
Not a problem, I do think one of the great benefits of this site is the exchange of information. If we were not able to rapidly seek advise and share experiences we really would be tearing our hair out. I have always had gold plated advice on this forum. In this case you have been down graded to silver. Never the less I owe you and Twojobs Mick a pint each.
G.Terence
PostSubject: Re: Dayton rev counter wiring problem   Dayton rev counter wiring problem Icon_minitimeThu Jul 07, 2016 11:17 am
Wot - no redemption for fessing up to my fuck up. !  What you set at now ?
PostSubject: Re: Dayton rev counter wiring problem   Dayton rev counter wiring problem Icon_minitimeSat Jul 09, 2016 1:38 pm
Used to getting gold myself ..... Wife tells me I always come first !!
» wiring problem please help....
» Post counter
» Rev counter for M800 K5
» Daytona Velona Rev Counter
» REV Counter stops when lights are on???
Dayton rev counter wiring problem Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Dayton rev counter wiring problem Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Dayton rev counter wiring problem Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Dayton rev counter wiring problem Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Dayton rev counter wiring problem Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Dayton rev counter wiring problem Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Dayton rev counter wiring problem Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Dayton rev counter wiring problem Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Dayton rev counter wiring problem Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Dayton rev counter wiring problem Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Dayton rev counter wiring problem Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Dayton rev counter wiring problem Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Dayton rev counter wiring problem Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Dayton rev counter wiring problem Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Dayton rev counter wiring problem Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Dayton rev counter wiring problem Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Dayton rev counter wiring problem Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Dayton rev counter wiring problem Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Dayton rev counter wiring problem Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Dayton rev counter wiring problem Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
