Subject: straight through pipes diy Sat Dec 03, 2016 2:26 pm
hi all i thought i would post a couple of pics of this mornings project of home made straight through pipes i removed the old silencers and capped the balance tube on the upper header pipe. then slid some new gaskets from a honda nx650 j-r 88-94 which have the correct i.d and an o.d of 34mm. i then cut and notched the end of 2 300mm pieces of 38mm o.d 316 stainless tube with a 1.5mm wall thickness and slid it over the gasket and clamped it up. then cut and notched 2 pieces of 2 inch 316 stainless tube and notched it to clear the clamps and slid over the 38mm tube and bolted it through the 38mm and 2 inch pipe. then mirror polished it all.
im going to cut off the balance tube and weld the hole up when i get some gas for my mig.
cost of whole job £29
i hope this makes sense it does to me !! some pics of end product and it now sounds like it should, going to fettle the carb settings this afternoon.
Subject: Re: straight through pipes diy Sat Dec 03, 2016 4:54 pm
They look good, bargain price too!
Subject: Re: straight through pipes diy Sat Dec 03, 2016 7:31 pm
..... Post a video so we can hear them roar when you have jetted the carb.
Subject: Re: straight through pipes diy Sat Dec 03, 2016 8:52 pm
I'll get my ear defenders ready now!
Vert neat looking job that Scott.
bigmal Very Valued VIP Member
Subject: Re: straight through pipes diy Sat Dec 03, 2016 11:56 pm
Amazing! You've sure got some skills
vlforrest Member
Subject: Re: straight through pipes diy Sun Dec 04, 2016 12:20 pm
a short video (taken with iphone so not the best) i hope this works
Subject: Re: straight through pipes diy Sun Dec 04, 2016 4:23 pm
Sounds good! was that a little flame coming out at 34 seconds
Subject: Re: straight through pipes diy Sun Dec 04, 2016 8:06 pm
