| Max height | |
Dj_Star Member
| Subject: Max height Tue May 23, 2017 12:23 pm | |
| Hey folks, What's the max height u can get away with without worrying about cable extensions? If found a cool set of bars with the measurements 560mm wide, Rise is 210mm Bar Diameter 27mm approx. Would this be to much?
Cheers Dj | |
| Subject: Re: Max height Tue May 23, 2017 12:50 pm | |
| Bikes vary - release bars with 4 bolts and see how much you have. About 10" I would guess. | |
| | | Dj_Star Member
| Subject: Re: Max height Tue May 23, 2017 1:18 pm | |
| | | KeithW Member
| Subject: Re: Max height Tue May 23, 2017 4:36 pm | |
| II've put Aeromach risers on mine and they raise the standard bars 40mm and pull back 45mm. I've had to remove the cable guide but the clutch and brake cables are ok and I've had to move the throttle cables to the inside of the yoke. Any more up or back and I would have needed new cables all round.
KeithW | |
| | | Dj_Star Member
| Subject: Re: Max height Tue May 23, 2017 5:21 pm | |
| - KeithW wrote:
- II've put Aeromach risers on mine and they raise the standard bars 40mm and pull back 45mm. I've had to remove the cable guide but the clutch and brake cables are ok and I've had to move the throttle cables to the inside of the yoke. Any more up or back and I would have needed new cables all round.
KeithW 40mm??? That it?? Bugger. Really liked the look of these... But good to know especially when u have the same bike. | |
| Subject: Re: Max height Tue May 23, 2017 9:32 pm | |
| I went with flat drags - 34" wide, 6.5" pullback. Sat them on 3" risers - standard cables fitted fine. Handles much better as well " /> | |
| | | Dj_Star Member
| Subject: Re: Max height Tue May 23, 2017 10:24 pm | |
| Cheers Dave. I'm thinking of getting the bars and just seeing. If they don't fit I will just have to re-home them.
Ps. That's a sweet ride! | |
| Subject: Re: Max height Tue May 23, 2017 11:29 pm | |
| Other tricks include re routing clutch cable and easing the electrics out of the hole in headlamp. Going the other side of the yoke has already been mentioned. These avoid having to cut wires or buy new cables. Where there is a will there is often a way. Best of luck! | |
| Subject: Re: Max height | |
| | | | Max height | |
