 o2 elimination or not
2 posters
mare1411
mare1411
o2 elimination or not Empty
PostSubject: o2 elimination or not   o2 elimination or not Icon_minitimeWed Aug 09, 2017 7:54 am
Hi guys..
I have on my bike already spike air filter and cobra fi2000r fuel proccessor.
I just ordered V&H slashcuts from metricruisers.co.uk
I read somewhere that in order to run fuel proccessor i have to eliminate o2 sensor?
in power commander pcIII pdf it says that you have to eliminate o2 sensor. but on cobra pdf says nothing about it
Is that true?
If it is .. is there a diy tutorial for this?
if i just unplug the sensor will it run normally ( except for fi light)? just to test
thank you
PostSubject: Re: o2 elimination or not   o2 elimination or not Icon_minitimeWed Aug 09, 2017 8:43 pm
Hi Marko, Yeah it should run normally if you unplug the o2 sensors and use the Cobra fi2000r, The FI light will come on as you say unless you use the sensor eliminators, The 'power commander' on the other hand uses the o2 sensors to read from them to adjust the mixture accordingly, That's why that unit needs them in.
mare1411
mare1411
PostSubject: Re: o2 elimination or not   o2 elimination or not Icon_minitimeFri Aug 11, 2017 10:19 am
ok
thanks
u cutted wire 23.. no errors...
i am not sure if the new exhaust comes with o2 plugs or not...
PostSubject: Re: o2 elimination or not   o2 elimination or not Icon_minitimeFri Aug 11, 2017 4:25 pm
Yeah I cut wire 23 to disable the o2 sensors.
mare1411
mare1411
PostSubject: Re: o2 elimination or not   o2 elimination or not Icon_minitimeMon Aug 28, 2017 12:21 pm
i did cut the sensor
everything is ok..
i mounted new exhaust
from before I already have spike filter and fi processor
Now i Just have to refine my fi2000 settings... still geting some pops on loosening throttle
o2 elimination or not Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
o2 elimination or not Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
o2 elimination or not Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
o2 elimination or not Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
o2 elimination or not Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
o2 elimination or not Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
o2 elimination or not Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
o2 elimination or not Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
o2 elimination or not Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
o2 elimination or not Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
o2 elimination or not Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
o2 elimination or not Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
o2 elimination or not Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
o2 elimination or not Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
o2 elimination or not Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
o2 elimination or not Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
o2 elimination or not Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
o2 elimination or not Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
o2 elimination or not Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
o2 elimination or not Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
